New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
I am having trouble in a data set getting the best line of fit. I am able to get the smooth line in graph builder but when I click "best fit" icon nothing happens. Then when I run fit Y by X, I don't see anywhere I can select the best fitting line. Do I need to change something in my settings maybe?
Your time variable has the nominal modeling type. That means JMP thinks it is categorical, therefore regression (or best fit line) is not appropriate. Change the time to have the continuous modeling type.
Here is a picture of the example. As you can see in the picture I have both the smooth line and the best line of fit selected, however, I only see the smooth line.
Dan Obermiller
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '229369' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '229369') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '229369') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
