jkimmich
Best Fit Line
I am having trouble in a data set getting the best line of fit.  I am able to get the smooth line in graph builder but when I click "best fit" icon nothing happens.  Then when I run fit Y by X, I don't see anywhere I can select the best fitting line.  Do I need to change something in my settings maybe?
Re: Best Fit Line
Your time variable has the nominal modeling type. That means JMP thinks it is categorical, therefore regression (or best fit line) is not appropriate. Change the time to have the continuous modeling type.
Dan Obermiller
jkimmich
Re: Best Fit Line
Here is a picture of the example.  As you can see in the picture I have both the smooth line and the best line of fit selected, however, I only see the smooth line.
Re: Best Fit Line
Dan Obermiller
