helga55
Axis in Loading plot of PCA in JMP
Hi, I am relatively new to PCA analysis as well as to JMP. How can I change the PCA loading values on the x and y axis of the plot that JMP rovides when you do a PCA analysis? Right now the default is PCA1 on x axis and PCA 2 on y axis. I would like to plot PCA3 on y axis and get a similar plot with the vectors showing in diff directions, labels etc.
Re: Axis in Loading plot of PCA in JMP
In the lower left hand area of the display window there are the options to select whatever x and y display values you want to use
helga55
Hi, thanks a lot but as I have an older version (JMP 9.02) i couldnt see the same options as you have shown in your screen plot. however realizing that it can be done I looked at the drop down menu of the Principal Components (red arrow) and used the option of Loading plot and was able to get plots with PCa1, 2, 3 as  axes.
I am glad you figured out a solution.
To assist yourself in getting questions answered from the Discussion Community, I suggest that you include the version # you are using, when you ask you questions.
helga55
Yes that is a good idea! Thanks a lot once again.
