prossman
Adding Constraints to Coefficients in Regression Models
I am working on a market mix model and the impact of promotions on sales. I would expect the coefficients to be positive or 0, but some of the models are producing negative coefficients.
Is there a way to add a constraint to the coefficients of some variables to force them to be positive?
Paul
Kevin_Anderson
Re: Adding Constraints to Coefficients in Regression Models
Paul, you can use the Parameter Bounds pulldown in the Nonlinear platform, specify the bounds you wish, and then iteratively fit a linear model.
The Nonlinear platform will make you specify a model in the Formula Editor and supply some Initial Values for the parameters.  You won't enjoy some of the model diagnostics you might be using in another platform (R^2, for instance, is not provided for nonlinear models), but at least you can constrain the parameters appropriately and (if your model converges) get a hopefully useful answer.
Kevin_Anderson
prossman
Thanks. This worked perfectly.
