NBrammer
Add date and file name into any graph
Just wondering if anyone has written an addin or some script that will add the current date and file name (of the source data table) onto any graph/report generated?
I've turned on preferences<reports to make it appear at the top of the report window, but would like it actually on the graph so that when the these are copied and pasted into PP, for example, these details are clearly visible.
thanks
Level XIII
Re: Add date and file name into any graph
Without the references to the data table and to the plot, you can access the gb Object via the report / get scriptable object()  - and the data table via << get data table().
Maybe add some code to skip the LDF and Column Switcher ...
open("$SAMPLE_DATA/Big Class.jmp");
Graph Builder(
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
fbs = current report() << XPath("//FrameBox");
nfbs = N items(fbs); // add the info to the last FB
OBs= current report() << XPath("//OutlineBox");
gb = OBs[1] << get scriptable Object; // add some code to skip LDF and Column Switcher
str = Char(As Date(Today())) || " " || ((gb << get data table()) << getname);
Eval(EvalExpr(
	fbs[nfbs] << Add Graphics Script(
		Text Color("Red");
		Text(Right Justified, {X Origin() + X Range(), Y Origin()}, Expr(str));
NBrammer
Brilliant - thanks
It isn't really that simple to create a script which would work with any graph/report.
The basic idea could be something like this but this makes already assumptions that you have a reference to the table and the analysis object. It also assumes that all frameboxes are based on the same table
dt = open("$SAMPLE_DATA/Big Class.jmp");
gb = dt << Graph Builder(
str = Char(As Date(Today())) || " " || (dt << getname);
fbs = Report(gb) << XPath("//FrameBox");
Eval(EvalExpr(
	fbs << Add Graphics Script(
		Text Color("Red");
but figuring out which is the correct table for example can get fairly complicated.
Level XIII
Graph Builder(
Eval(EvalExpr(
		Text Color("Red");
NBrammer
Brilliant - thanks
