dlemieu1
Add Rows question
New JSL scripter here. Trying to get 5 new rows added after every existing row, 25 rows in the data table. No issues while debugging, i changes from 25 to 1 in increments of 1 as expected, but no new rows are added to my data table at any point during/after the For loop. Not sure what I'm doing wrong, any help would be appreciated!
dt=current data table();
For(i=N Rows(dt),i>=1, i--,
	dt << Add Rows( 5, i );
Re: Add Rows question
I've never used the 2-argument form, but the scripting index shows this example, using a keyword to specify the meaning of the 2nd arg
dt << Add Rows( 3, after( 5 ) );
I am a bit confused.  Given the below table
Your script creates
Which is what my understanding is what you want.
Here is my script, using your code that creates the above data table and it's expansion
// Create a table with 25 rows
dt = New Table( "Example",
	Add Rows( 25 ),
	New Script( "Source", Data Table( "Untitled 97" ) << Subset( All rows, Selected columns only( 0 ) ) ),
	New Column( "Column 1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25]
Wait( 5 );
// Now create the new rows
For( i = N Rows( dt ), i >= 1, i--,
Your script creates
	Add Rows( 25 ),
		Numeric,
		"Continuous",
		Set Values(
Wait( 5 );
dlemieu1
I think this was a simple case of "close it and open it again". My data table must have gotten corrupted somehow because when I closed and reopened it, my code worked fine. Sorry for any inconvenience.
