Torsten Weber, Engineer Process Integration, Heliatek
The paper will discuss the application of JMP at Heliatek in terms of process monitoring in a pilot production environment. In a running production it is a challenge to keep track of multiple control charts simultaneously. The contribution describes an alarm dashboard compiled in JSL, which monitors multiple process parameters and visualizes critical limit exceedings in a simple way. The application counts the limit violations in a defined time frame of multiple components and depicts the results in a heat map. Database queries continuously update the data.
This presentation will explain in detail:
- How to run this application in a loop to react as soon as possible to critical process variations.
- How to solve issues regarding automatic alarm emails without using the „mail()“ or „alarm script()“ function of JSL
- How to share this alarm board in a network via customized HTML report to minimize interrupting „hangover“ while updating the data.
This application helps to enhance the production yield of organic-PV products by a simple visualization of multiple process parameters and therefore shortens the response time.
