Randal Munroe publishes one of my all time favorite comics, xkcd. Last week's comic was on curve fitting, and was, arguably kind of hilarious. @Randal Munroe, dude you're hilarious. Anyone who was a discovery and heard about his Thing Explainer concept would surely agree.
So anyway, I read the comic and then dove into the data. There is an amazing tool that @brady_brady originally published for generating Homerian distributions that can be found buried in this tremendous add-in (which is a collection of other useful scripts and add-ins, a must-have). With the "Get Data Points By Clicking On Image" tool I extracted the exact data from the comic (data attached below) and then started fitting all kinds of conventional and less conventional models and some possibly dishonest models with no regard for how badly overfit the models were (even though I could/should have, with JMP Pro.)
Quick Note on Axis Scale. This one seemed good to me, although it was
missing on the original figure. I could have done that too, but they there
would have been a lot of clicking and I just didn't have it in me today.
Here is a ranked table of fits
Measures of Fit for Y sorted by RSquare
Predictor
Creator
RSquare
RASE
AAE
notes
regression 10 lags
Fit Least Squares
0.9808
2.9103
2.3275
not legal, fit X along with a series of 10 sequential lags to the data. Works great when there is any hint of a trend in the data, might over fit, but only just a little, plus there are 11 parameter and I didn't bother to report adjusted r-square here.
partition BF
Bootstrap Forest
0.8469
7.4494
5.4207
500 trees, and some of them fell in the right direction
partition BT
Boosted Tree
0.6737
10.876
8.1600
50 layers, used defaults, un-tuned
partition over fit
Partition
0.6607
11.091
8.3713
made the minimum split size small and split to the end
regression ^10
Fit Least Squares
0.5687
12.505
9.3912
10th order polynomial, kind of wiggly
regression ^8
Fit Least Squares
0.5479
12.803
9.6483
8th order polynomial, not quite as wiggly as 10th order
regression 2 pieces
Fit Least Squares
0.4459
14.173
9.8317
used partition to split the data in two and fit two regression models
fit curve 4pR
Fit Curve Logistic 4P Rodbard
0.4277
14.404
10.496
4 parameter logistic regression, Robard model
partition 2s
Partition
0.4249
14.439
10.745
partition with only one split, results in two levels, not likely over fitted.
fit curve 5p
Fit Curve Logistic 5P
0.4104
14.620
10.826
5 parameter logistic regression
regression ^4
Fit Least Squares
0.3932
14.832
10.402
4th order polynomial
regression ^2
Fit Least Squares
0.3682
15.134
10.541
regular old 2nd order polynomial
fit curve 3p growth
Fit Curve Mechanistic Growth
0.3393
15.477
11.080
fancy non-linear model
regression
Fit Least Squares
0.2779
16.180
12.209
straight line
regression log
Fit Least Squares
0.2472
16.520
12.695
X is log transformed
regression exp
Fit Least Squares
0.0691
18.371
15.429
X is exponentiated (exp transform)
You might expect to find some rationale behind why I tried each of the different models but at the end of the day this is a blog not an academic paper, so don't burn too much time looking for that. I got this table from the Model comparison tool in JMP Pro, all I had to do was find all the methods and then save the prediction formula, the fancy platform did all the math.
Just in case you wanted to play with the data (and seriously, I do mean play), it should be attached below this article.
