Hadley Myers, JMP Systems Engineer, SAS
Chris Gotwalt, JMP Director of Statistical Research and Development, SAS
The need to determine confidence intervals for linear combinations of random mixed-model variance components, especially critical in Pharmaceutical and Life Science applications, was addressed with the creation of a JMP Add-In, demonstrated at the JMP Discovery Summit Europe 2020 and available at the JMP User Community . The add-in used parametric bootstrapping of the sample variance components to generate a table of simulated values and calculated “bias-corrected” (BC) percentile intervals on those values. BC percentile intervals are better in accounting for asymmetry in simulated distributions than standard percentile intervals, and a simulation study using a sample data set at the time showed closer-to-true α-values with the former. This work reports on the release of Version 2 of the Add-In, which calculates both sets of confidence intervals (standard and BC percentiles), as well as a third set, the “bias-corrected and accelerated” confidence interval, which has the advantage of adjusting for underlying higher-order effects. Users will therefore have the flexibility to decide for themselves the appropriate method for their data. The new version of the Add-In will be demonstrated, and an overview of the advantages/disadvantages of each method will be addressed.
Speaker |
Transcript |
Hello, my name is Chris Gotwalt | |
00 | 08.966 |
3 | |
has been developed for variance | |
components models, we we think | |
00 | 25.566 |
7 | |
statistical process control | |
program, one has to understand | |
00 | 40.466 |
11 | |
ascertain how much measurement | |
error is attributable to testing | |
00 | 55.500 |
15 | |
there might be five or 10 units | |
or parts tested per operator, | |
00 | 10.766 |
19 | |
different measuring tools is | |
small enough that differences in | |
00 | 26.033 |
23 | |
measurement to measurement, | |
repeatability variation, or | |
00 | 39.900 |
27 | |
measurement systems analyses, as | |
well as a confidence interval on | |
00 | 52.766 |
31 | |
interval estimates in the report | |
and obtain a valid 95% interval | |
00 | 07.033 |
35 | |
calculate confidence intervals, | |
because we believed it would be | |
00 | 23.400 |
39 | |
and the sum of the variance | |
components. Unfortunately, the | |
00 | 38.266 |
43 | |
r&r study. So because variance | |
components explicitly violate | |
00 | 57.300 |
47 | |
you were to use the one click | |
bootstrap on variance components | |
00 | 10.566 |
51 | |
less. So when we were designing | |
fit mixed, and the REML | |
00 | 27.933 |
55 | |
independent. So back to the | |
drawing board. So it turns out | |
00 | 44.666 |
59 | |
in JMP. One approach is called | |
the parametric bootstrap that | |
00 | 01.333 |
63 | |
comparison of the two kind of | |
families of bootstrap. So the | |
00 | 18.333 |
67 | |
they're, they're not assuming | |
any underlying model. And it's | |
00 | 37.200 |
71 | |
the rows in the data table are | |
independent from one another. | |
00 | 52.766 |
75 | |
values, it has the advantage | |
that we don't have to make this | |
00 | 09.866 |
79 | |
bootstrap simulation. The | |
downside to this is that you | |
00 | 25.133 |
83 | |
do a quick introduction to what | |
the bootstrap...the parametric | |
00 | 41.966 |
87 | |
to identify or wanted to | |
estimate the crossing time of a | |
00 | 04.733 |
91 | |
162.8. Now, we want to use a | |
parametric bootstrap to to go | |
00 | 22.466 |
95 | |
has the ability to save the | |
simulation formula back to the | |
00 | 35.933 |
99 | |
that uses the estimates in the | |
report as inputs into a random | |
00 | 53.300 |
00.666 | |
104 | |
And we take our estimates and | |
pull them out into a separate | |
00 | 17.666 |
108 | |
And then what we have can be | |
seen as a random sample from the | |
00 | 37.000 |
112 | |
formula column for the crossing | |
time. And that is automatically | |
00 | 53.900 |
116 | |
those...on the crossing time, or | |
any quantity of interest. When | |
00 | 15.366 |
120 | |
simulation, create a formula | |
column of whatever function of | |
00 | 28.366 |
124 | |
derive quantity of interest and | |
obtain confidence intervals | |
00 | 47.233 |
128 | |
the add in so that you're able | |
to do this quite easily for | |
00 | 05.033 |
132 | |
133 | |
we'll start by showing you how | |
to run the add in yourself once | |
00 | 25.500 |
137 | |
first version was presented at | |
the JMP 2020 Discovery Summit | |
00 | 42.566 |
141 | |
overview, but we'll show you the | |
references where you can dive in | |
00 | 58.866 |
145 | |
perfectly fine as well. So I'm | |
going to go ahead and start with | |
00 | 14.700 |
149 | |
makes use of the fit mixed | |
platform, right, created from | |
00 | 31.333 |
153 | |
the add in will only work with | |
JMP Pro. So someone might, | |
00 | 49.066 |
157 | |
want some measure like | |
reproducibility. So that would | |
00 | 10.166 |
161 | |
as we said, to calculate the | |
estimate for these, there's no | |
00 | 26.066 |
165 | |
columns here. The reality is | |
much, much, much more | |
00 | 43.066 |
169 | |
of the estimate without | |
considering the worst case | |
00 | 59.233 |
173 | |
production that the actual | |
variance is higher than they have | |
00 | 19.733 |
177 | |
don't risk being out of spec in | |
production. So to run the add in | |
00 | 35.700 |
181 | |
From here, I can select the | |
linear combination of confidence | |
00 | 55.266 |
185 | |
simulations, you get a better | |
estimate of the confidence | |
00 | 10.500 |
189 | |
2500. I'm going to leave it as | |
1000 here just for demonstration | |
00 | 28.733 |
193 | |
operator or the batch variable, | |
and then press perform analysis. | |
00 | 45.533 |
197 | |
purpose of this demonstration, I | |
think I will stop it early. | |
00 | 07.733 |
201 | |
calculated confidence limits, the | |
bootstrap quantiles, which are | |
00 | 28.933 |
205 | |
these two tabs. But if you'd | |
like to see how those compare, | |
00 | 42.366 |
209 | |
so what does enough mean, enough | |
for your confidence limits to | |
00 | 57.400 |
213 | |
stopped it before a thousand. So | |
that's how the add in works. And | |
00 | 15.466 |
217 | |
distributed around the original | |
estimate, they are in fact | |
00 | 37.366 |
221 | |
relaunch this analysis. So | |
you'll see that when the | |
00 | 56.433 |
225 | |
European Discovery, required | |
bounded variance confidence | |
00 | 16.766 |
229 | |
that, if that happens for some | |
of the bootstrap samples or for | |
00 | 40.466 |
233 | |
early, again, I'll just let it | |
run a little bit. Yeah, so I, as | |
00 | 00.966 |
237 | |
the samples are allowed, in some | |
cases, to be below zero. So in | |
00 | 28.400 |
242 | |
simulation column here, this | |
column of simulated | |
00 | 49.100 |
246 | |
see them both at the same time. | |
It's a bit... it's a bit tricky, | |
00 | 16.300 |
252 | |
right components, it's a good | |
idea to run the add in directly | |
00 | 31.766 |
256 | |
that column is then deleted. So | |
one thing to to mention, before | |
00 | 50.500 |
260 | |
accounts for the skewness of the | |
bootstrap distributions, right, | |
00 | 14.200 |
264 | |
that. And then the accelerated | |
takes that even further. So here | |
00 | 27.200 |
268 | |
thing to mention is that the | |
alpha in this represents the | |
00 | 43.700 |
272 | |
value for which it's been | |
calculated? And what can we do to | |
00 | 03.233 |
276 | |
up to investigate the four | |
different kinds of the variance | |
00 | 24.700 |
280 | |
method, the bias corrected | |
method and the BCa. We also | |
00 | 43.000 |
284 | |
study. So for all 16 | |
combinations of these three | |
00 | 01.566 |
288 | |
combinations of confidence | |
intervals, and kept track of how | |
00 | 20.400 |
292 | |
293 | |
coverage as we're varying these | |
three variables, and we see here | |
00 | 45.300 |
297 | |
298 | |
techniques. And the second best | |
is the bias corrected and | |
00 | 09.966 |
302 | |
the best one. Now, if you turn | |
no bounds on, which means that | |
00 | 28.433 |
306 | |
variance components with a | |
pretty close to 95% coverage. | |
00 | 48.200 |
310 | |
intervals are performing | |
similarly at about 93%. But | |
00 | 02.200 |
07.800 | |
315 | |
to what a master's thesis paper's | |
research would have, would | |
00 | 27.966 |
319 | |
potentially more work to be | |
done. There's other interval | |
00 | 42.566 |
323 | |
things like generalized | |
confidence intervals. General | |
00 | 59.466 |
327 | |
intervals might also do the | |
trick for us as well. Hadley's | |
00 | 19.966 |
331 | |
so that you can now do | |
parametric bootstrap simulations | |
00 | 37.566 |
335 | |
16. When you bring that up, you | |
can enter the linear combination | |
00 | 51.766 |
339 |
