We have a built-in command to save a JMP report to a JMP data table so that the customer can rerun the report. However, if a customer wants to save the report as a journal, customize it, and then save it to the data table, JMP currently does not have the build-in UI command to do so. As a tester on the JMP journal, I see customers' needs for this function.
My poster will show how to write an add-in to save a journal to a data table so that customers can rerun it in future JMP sessions.
Hi, my name is Hoi Dee. I'm working in JMP.
I'm working in JMP system testing group.
One of my responsibility is testing journal.
So this brings the introduction of my poster.
JMP has a function to save our JSL  or the report to data table,
which is very convenient for users
to access previously generated reports.
A s a journal tester, I'm thinking,
is it possible to save a journal to a data table?
And not only me think about that,
we have some customers thinking of that, too.
And even our customer requested
the function of save journal to a data table.
So because we have customer requesting that,
I began to look into the ways in JSL,
how do we do it to save a journal to a data table?
So this poster is to study their JSL commands
and how do I put them together to save journal to a data table.
Methods and objectives.
Objectives, as introduction said, as I planned, or as customer requested,
is to save journal to a data table
so that in a data table, users can launch other report or journal.
So that they don't need to have a separated journal
associated with the data table.
Then the second method,
and the objectives we are thinking is how to deliver this small application.
Because JMP has an add- in, I used this add- in to deliver
this small piece of JSL command for easier delivery.
The last one I want to mention is that
since we want to save the journal  to the data table,
we need the data table to be current.
That means we need existing data table in the JMP to save the script, too.
Then let's talk about results.
After user creates a new journal
or attached piece of the report to an existing journal,
by running the add- in save journal to data table,
user can save journal to the data table.
When a user send or share the file to another user,
then another person can launch the journal from her or from his desktop.
Similarly, a user may use this method to save file,
s ave other file formats  inside the data table,
to wrap other files inside a data table.
Then I will show you a case study how to use this add-in.
On the poster, I have show you multiple steps how to do that.
But in a little while, I will show you how to use it,
how do we save the journal to a data table in real JMP session.
Let me briefly introduce the steps how to use this command.
First of all, either we want to bring in a template to journal,
like in this case,
I use our marketing department's journal template from Hyde Miller
as a template because I want to insert report to his journal template.
On this template, we can see they have the company's JMP logo,
and a title for their journal and some other land separators there.
After we bring up our journal template, we need a data table and a report,
especially a report, because we want  to insert report to the journal.
After we insert, let's move on to the step number three.
After we attach a part of or a whole part of the report to journal,
then we move on to the last step, which is run add- in.
Since we are on the journal, then we move on to the last step -
to run the add- in save journal to data table.
The result, as I shown before, is that we have viewed in JSL scripts
in the data table on the left panel of the table.
Then if we launch it, we get the journal template and the report.
So the conclusion of this poster is that
we can use the save journal to do the table add- in to fill the gap in JMP,
where we have no command you to save journal to your data table.
Besides, we can save journal to a data table.
Similarly, we can use this method to apply to other file formats.
So we can wrap other file formats inside the JMP data table
so that when we share the data table, it comes with the JSL scripts
and other file formats  could be launched from JMP.
Let's go, for example, HTML5, PDF, etc.
Last part is that I want to say some thanks
for the people who contribute to this presentation.
Of course, the first one who come to my mind is Hyde Miller,
whose journal template is used in my case study.
Now, let's move on to the journal to see...
Let's move on to the real-time JMP to see how do I use this function
or this save journal to data table add-in.
First of all, let's bring up JMP application.
Now, we open the data table, for example, Big Class.
First, let me demonstrate the first scenario.
The first case study where a report was inserted into a journal template.
Let me bring up a journal.
Here is an existing journal template from Hyde.
Then user bring up a JMP data table.
Then he or she may run testing scripts or his own customized JSL l aunched report.
In my case, in this example, let me run this one,
bar chart, and the land chart.
From here, we may copy or paste part of the display boxes.
This report made up of display boxes.
We may copy parts or copy a whole display boxes or reports to this journal.
To make it easy, let me use [inaudible 00:10:08]
to journal this report to existing journal template.
Now, this is the journal.
Then here, we can go to the add- in, then we click save journal to data table.
Now...
Let me close all this so that we may see clearly.
Here on the data table, we have viewed in JSL script AsJ ournal.
When we run it,
we have a general template  at beginning of the journal,
and we have the journal of the report inserted into it.
This is the one scenario which we insert a report or part of report
to an existing journal and save the journal to the data table.
Now, let me demo another one, which is the case where the user
do not want to use the template, but want to save the journal to the data table.
Let me bring up Big Class again.
We may want to run a report,
then we may want to Control- J to make a journal.
Here, this is the journal.
Then go to the add- in to save journal to the data table.
So to see clearly, we close all the other windows.
So now we have this viewed in JSL script AsJ ournal.
Then when we ran it, this is the journal we captured from our report.
I put this journal as a label to see, to identify that this is a journal window.
Journal is different from a report. It's a static image.
So it's not affected by the changing of their development.
It's like a camera. It takes the picture there.
For example, here on journal,
we don't have the two tapes showing up here.
So this is a journal.
The good thing about journal is that it won't change.
It's static.
It's a screenshot of the report at that moment.
Okay, let's go back to the PowerPoint.
The whole poster, I want to summarize the poster again.
Here, we have a new add- in save journal to data table
enabled for user to use if they want to save a journal to a data table.
The journal is a static image of different display boxes in nature.
And it can include image or different display boxes.
So from this add- in, user can add a script,
viewed in script to a data table to keep their report or their journal.
S imilarly, to save a JSL of a report to a data table,
we can do save a journal to a data table
to capture the journal users want to keep.
So the good thing is that, once again, as a conclusion,
people can share this data table so that people can run their journal
to bring up their static image of their report at that time.
So this is the poster of save journal to a data table.
Let me know if you have any questions.
Again, there are many user cases possible still to explore.
I've just researched and studied some simple cases
for saving journal to a data table.
I'm looking for your feedback.
Thank you.
Bye. Bye.
0 Comments
Published on ‎05-20-2024 07:55 AM by Staff | Updated on ‎07-23-2025 11:12 AM
like in this case,
Now...
When we run it,
It's static.
Thank you.
Bye. Bye.
