CLECIM ® Laser Welding Machines
Finding the optimal parameters for laser welding of steel plates with JMP
Stéphane GEORGES
R&D and Data Science Project Manager, Dept. of Technology and Innovation Clecim SAS., 41 route de Feurs, CS 50099, 42600 Savigneux Cedex, France
Purpose To be considered good, a weld bead must meet two criteria: it must be free of defects (such as spatter, humpings, underfill, holes, etc.) and resistant (assessed by means of an Erichsen-type cupping test). The search for the optimal parameters for laser welding steel plates is already extremely demanding due to this double constraint. But if, on the top of that, you consider the productivity of the processing line and the quality of the incoming material, then the task becomes a challenge!
Approach And that is precisely this challenge that was overcome with the use of JMP. To achieve this result, many steps were implemented, all of them requiring the use of a JMP platform or feature:
  1. Base material strength analysis, qualification of the two plates to be welded [Graph builder, Map shape, ANOVA, Dashboard]
  2. Synthesis of the visual observations, production of the weld defects map, which determines a study area of irregular shape where the weld seam is flawless. [Graph builder, Multiple pictures hover label]
  3. Weld strength analysis and optimization on a non-homogeneous material and on the defined defect-free zone, given as a set of candidate points. [Custom design, Split-plot, Covariates, Uncontrolled factor, Fit model, Prediction and Contour profilers]
Findings and Value For the given material, the objective was achieved since all the steps allowed to propose and validate a set point with a maximum productivity and a good weld, both defect-free and resistant, JMP being pliable and able to adapt to all the constraints of the process and the material.
Key words : JMP, laser welding, design of experiments, DoE, covariates, LW21M, LW21H
Hello everyone.
Thank you for attending this experience sharing session on JMP.
My name is Stephane Georges,
I'm R&D Project Manager at Clecim, and I'm very keen on data science.
Today, we'll talk to you about the design of experiment methodology,
and more specifically, about the case we encountered when trying to find
optimal parameters for laser welding process.
During this presentation, I will show you how we use JMP for various platform
and how JMP adapted to the reality of the field by taking into account
a very irregular study area and a very imperfect study matter.
Without further delay, I will start my presentation
by telling you who we are and what we do.
Clecim is an engineering and production company of equipment
for the steel industry.
We are located in Montbrison in France in the surrounding of Lyon.
The history of Clecim is not new,
as we celebrated five years ago our 100th anniversary.
The area of the site is about 12 soccer field where work 230 employees,
mainly composed of managers and technicians.
A s we like statistics when working with JMP, here is the first one.
Our population is composed mainly of men, about 80 percent and 20 percent of women.
Concerning Clecim activities:
Our first activities is studies and consulting activities
for our flat steel producer customer.
We supply individual machine, or we supply a complete production line
such as pickling line, annealing line, galvanizing line, painting line and so on.
We also have an activity of services
for the furniture or spare parts, for export missions, maintenance,
and so on.
I put on this picture a typical layout of a galvanizing line.
This is to give you an idea of such processing line.
This one is dedicated to the automotive market
and the length of such an equipment is about half a kilometer,
so a very huge industrial plant.
When I talk previously about a machine,
I had in mind rolling equipment such as rolling mill, plate levellers,
automated strip surface inspection system, and even laser welding machine.
This is on this last equipment that we are going to focus on right now.
I will now talk to you about autogenous laser welding process.
Autogenous means without filling wire.
I will talk also about the parameter and factors that govern this process.
But first of all,
I would like to introduce our machine, the subject of our study.
On the left part of the slide, you can see our welding machine.
In fact, not only our welding machine but it's containment,
the machine is inside the containment
for safety reasons because we are using laser.
The dimension here
of the door gives you an idea of this welding machine of scale one.
This is a huge industry, our welding machine.
On the right part of this presentation, you can see a partial inside
of this welding machine, where you can see the clamps
and the [inaudible 00:04:37] of the machine.
Inside, you see the top portion of the strip,
the head and the tail of the strip,
that will be, first of all, cut also with laser and finally brought together
in order to be welded.
I will now talk to you about our target and constraint.
Of course,
our objective, our target is to have a good weld.
To do that, we need to achieve two objectives.
The first one is to have a weld seam which is defect- free.
Here on this slide, I put you an example of such a weld.
This is picture number one.
You can see on this picture that this whole thing is quite nice
without any defect.
When I talk about defect, here is a list of the typical defect
that we encounter when trying to weld with a laser.
Typically, we could have some patterns.
This is picture number two.
This is a top view.
In such a case, this is the molten material,
which is ejected from the top of the weld.
We could have also chain of pearls.
This is picture number three.
This time this is a bottom view,
and this is some droplets at the bottom of the weld seam.
We could have also
other defects, such as humpings, underfillings, or even holes.
This is picture number four here.
And here, typically, this is the case
when we have a very low travel speed and a very high power density.
Instead of welding, we are drilling at the material
and we create some holes.
Of course, this is we absolutely want to avoid.
Otherwise, we will decrease the resistance
of our weld.
This is a transition for the second objective
because we want not only the weld seam to be p erfect,
but we want it also to be resistant.
This is evaluated via an Erichsen type cupping test,
so this I will describe it a little bit later.
Our target is to have a trend as close as possible
to the one of the base material.
I will now talk to you about the last welding parameters,
the factor governing the process.
On this left part of this slide,
I put you a very schematic view of the process.
In gray at the bottom,
you can see the two pieces of material that we want to weld together
that can be of the same nature and thickness on it.
In yellow, this is laser welding head
that is connected in blue to its laser source.
In order to imagine
the kind of power that we use
for such an application, imagine that when you use a laser pointer,
typically for a presentation,
such kind of device has a power of just one milliwatt.
Here the last source we use has a power of 12 million times.
It is 12 million times more powerful that's such a small device.
Just to explain that we have a very huge power.
We need very little power to cut our material
and to weld also this material.
I could use the process parameter, the typical process parameter,
which can be, first of all, the laser power,
the travel speed of the welding carriage,
the focusing distance, the gap between the plates,
the thermal treatment that we can apply afterwards, and so on.
But in fact,
for simplicity reason, in the rest of this presentation,
we will focus only on the two main one,
which is the laser power and the travel speed.
We will also consider
that the materials are identical and of the same thickness.
You will see that just with these two parameters we will have enough to do.
Okay, so the picture is set.
We have two targets.
One is to have a weld seam free of defect
and we want also to have its resistance.
We are now going to focus on our case study towards a good weld.
Our first target is to have a weld , which is defect- free.
We are going to search for what is called weldability lobe.
To do that, we need to get some data.
To get some data we will use the so called Power JMP procedure.
In that case, nothing to do with JMP, even if JMP is a powerful software.
But
this is how the procedure is called.
The picture on the bottom gives you an example of such a procedure.
At a fixed speed, we will perform 11 successive Power JMP.
In that case, we will switch from two kilowatts to eight kilowatts
to three kilowatts and so on.
The target is to reduce the number of options we have to do,
and in just one weld, we will have 11 sample
and we will have 11 observations to do.
Afterwards, we will visually examine
the upper part of our bead, the lower part of our bead
for each slot of this sample.
All of these data are collected into JMP
and we will use the Graph Builder platform in order
to display this map.
This is what I'm going to show you right now.
I go to my JMP journal here.
We will have four steps to follow.
This is our first step, building the welding format.
I will open
my table.
I collected all the data in this table.
I have all my parameters here, so the laser power, the welding speed.
In this column, I inserted my visual observation.
Is there any penetration? Yes/N o.
Do we have material loss? Yes/N o.
Humping? Yes/No, and so on.
A t the end of this file, I also put, as you can see,
I had two additional columns
of expression vector type where I have inserted
the picture of all my observations.
As you can see here also, I requested to have this information
displayed in the study area.
Now, we are ready to open our Graph Builder.
Here
I can learn it, okay?
All the data has been collected in this map.
Here you can see that on the X- axis, I put my welding speed.
On the Y- axis, I have my laser power.
I have associated for each defect color or shape.
A lso, we can have an association of the color and shape in that way,
which is a convenient way because we can overlay
four different type of defects at the same time for each point.
This is what I'm going to show you.
For instance, if I take this blue point here,
according to the legend, we have top spatters.
This is exactly what my pictures show you.
Here, this is the picture of the upper part of my weld,
here is a picture of the lower part of my weld.
Here we can see that we have effectively top spatters,
whereas the bottom part is defect- free.
For instance, if I take another one, if I take this purple one here.
So purple, this is the association of the blue defect and the red defect.
We have top spatters and bottom spatters,
which is effectively what we can see here on that picture.
This is a convenient way to see if effectively.
I have no mistake in order to know the magnitude of the defect.
This feature using the pictures is also very convenient because, for instance,
if I take this point here and I lock the pictures,
and if I take this additional point here and I lock also the pictures,
we can see that for constant laser power, I can compare the pictures
and see what are the effects when varying the welding speed.
In that case,
when we increase our welding speed, we can see that the width of our weld seam
decrease both on the top and both on the bottom.
This is a convenient way, let's say,
to dip into the understanding of our process.
I will close that.
I'll come back to my study case.
We are interested in the good weld area.
This is the area that I'm going to highlight here.
This is the black area.
Okay, like that.
Okay, this is our area of interest.
Now, what we want to do,
let's say, to investigate
the behavior of our weld seam
from the resistance point of view on that typical area.
Of course, we want to do it with a minimum number of tests
and we will perform a design of experiment
on this very
irregular study area.
Okay, so I go back to my presentation.
But
before answering into the conception of the design of experiment,
we have another interesting topic to do with JMP,
because we have, first of all, to study the strength of our base material.
We have to evaluate
the basic strength of the material via an Erichsen- type cupping test.
Why are we doing that?
We have three targets, three objectives.
The first one this is to establish
a reference from the strength point of view.
In that way, we will be able to compare
the resistance of our base material with the resistance of our weld seam.
This is the first point.
The second point is to be able to compare the two pieces of material
that our customer sends us.
We want to be sure that these two pieces
have the same behavior.
For that, we have to ensure
that they can be comparable.
The last point is that we want also to check that the plates are homogeneous
from the resistance point of view and that they do not present
any resistance profile in their widths or in their lengths.
To do our Eric hsen-type cupping test, we will do that on the base material.
This is what is mentioned,
what is highlighted here in the three first pictures.
We do not have any weld.
We're just performing this Erichsen- type cupping test.
For simplicity reason
I will call this procedure ball test in the remaining part of the presentation.
These three ball tests, we do them on three different positions
of the material, one located at the center of our sample,
one located on what we call the drive side on the machine,
and one located on the operator side of the machine.
For one sample, we do free tests.
What is a ball test?
In fact, this is explained
in the pictures located at the bottom of this slide.
We simply take
a bowl made in titanium, and we will press it from the bottom
and we will register the deformation of the material,
the breakage force.
We do that for our two plates,
and we register all of that in JMP and analyze the results in JMP.
We will use the distribution platform and the Fit X by Y platform.
I go back to my JMP journal.
This is our second step, analyzes the base material.
I will open my file.
Here, I put all my data.
My plate ID, plate number 1 and 2.
For each plate I do that twice.
For each sample, we perform the measurements
at three different locations,
and here are the recorded value, the recorded strength.
We will analyze all of that and I store everything into a dashboard.
First of all, this is interesting to see visually our result.
I will focus, first of all, on this custom map shape.
In blue, you have the data for the first plate,
where I have my first sample and second sample.
For each sample, I have my free ball test, one located on the operator side,
one located in the center, and one located here on the drive side.
We have the same for the second piece of material.
What we can see here is that the resistance
goes through the following rates, so from nine to 10.4 tons.
Nothing really particular to see, except maybe that
here in the operator side, we can see that we have on the same side
the external value.
Here is the lowest value and here is the maximum value,
so maybe that will be something to look at
but we will come to this a little bit later.
Our target is to perform an ANOVA in order
to see if our two plates can be considered as comparable.
But before doing an ANOVA,
we need to ensure that our data follow a normal distribution
and that our variances can be considered as equal,
so this is what we are going to do right now.
Here are the distribution for plate number 1, for plate number 2.
Okay, I know that I do not have a lot of data,
but we will consider that we have enough to perform the test.
We will look at the two Anderson-Darling coefficients here.
What the p-value tells us is that we cannot reject the hypothesis
that the two plates can be comparable so that's good.
Then concerning the variances, so here we use another platform,
but we first go at the end, we perform the variance analysis here,
and we will look at the F Test, and the F Test tell us
that we can consider as our variance are equal.
As our data are normally distributed on our variant article,
we can apply safely our ANOVA.
This is what is mentioned here.
On the top part, you have the drawing.
Here are the associated data.
I will not focus on the data.
We will just have a look at the pictures.
Here, what we can see,
this is the extremities of the two diamonds overlap.
We cannot reject the hypothesis that our two plates are different,
so this is good.
We will now reach the conclusion that our two plates are equivalent.
We can now aggregate all the data.
This is what is done here in the distribution.
We put all our data together,
and finally, we have a global resistance of our plate of 9.76 tons
plus or minus 0.17 at two standard deviations.
This is the first point and we will use this information a little bit later.
Another interesting thing,
so this is what is mentioned here.
We can also perform the ANOVA taking into account the position.
And this as we have previously observed,
we can see that the run variation on the operator side
is a little bit higher
compared to the drive side and the center of our plate.
We want to understand a little bit why such things happen.
To do that, I will come back to my presentation,
we will have a look at the plate.
We are studying at the moment.
Here is the appearance of our sheet metal.
What we can see is that on the drive side here,
our plate is nearly flat, I would say.
But on the contrary,
on the operator side, we clearly see that the plates have some waves.
I do not know exactly what is the history
of this material, but we can clearly imagine that
there was a trouble at the rolling m ill or the plate leveller
and that the higher force has been applied on the operator side,
leading to this kind of periodic modification of the resistance.
This is a new constraint because we have to take into account
this new information in our design of experiment.
I will sum up all the information we have before building our design of experiment.
First of all, I remind you that we have a very irregular study area.
This is a black area that is mentioned here
in the drawing.
The traditional way
to deal with such things in JMP would be to fill up a linear constraint.
But here due to the shape of this area, it's a little bit difficult.
Instead, we prefer to use the Candidate Points technique,
which is called also Covariates engine.
I remind you also that we have an inhomogeneous plate
and to deal with this phenomenon, we will have to introduce a few parameters
into our design of experiment.
First of all, we have to take into account the strength variation in the width.
To do that, we will introduce a categor ial parameter,
a 3 levels- categorial parameters,
and the three levels are drive side, center, and operator sides.
In order to deal with the periodic variation of the resistance
along the length of the plate, well, this is a little bit difficult,
because, in fact, we do not control this parameter.
We have to be on
this variation.
For that, we will introduce the weld position
from the head of the plate, or in millimeter,
and we will introduce it as an uncontrolled parameter.
Finally, this is not finished.
This is what you can realize, what you can see
in the last picture at the bottom.
This is typically here a picture of a weld,
where are located above three ball tests.
Well, these ball tests are not independent.
They belong to the same treatment.
They belong to the same weld.
They are at the same weld position.
We are
in the presence of split/ plot design,
where we have hard and easy- to- change parameter.
This is a lot of constraints we have to take into account.
Now, I will show you how to do that with JMP.
I can go back to my JMP journal, so this is our first step.
But I will show you from the beginning and I will go back here
to this step.
I come back to the file I had previously.
I will select here
all the rows with a Good Weld.
I will also select
another power column, my welding speed column.
In the table here, I will extract a subset of this table.
I will extract selected line.
I will extract the selected column here.
Okay, I will build my subset of Candidate Points.
But here is the tricky thing because, in fact,
as we have a design also, I need to tell them that
you will have the possibility to select three times each point.
I will multiply by three this number of points.
There is probably a lot of way to do that.
In my case, I will just create three columns,
one call it drive side,
one call it center,
one call it operator side,
and I will just stack all these
using that three columns.
Here I have created my set of Candidate Points.
With the Graph Builder, I will check that everything is okay.
In the Y- axis, I will put the laser power. On the X- axis, I will put the laser speed.
Here, we can recognize the shape of our irregular study area.
I will also put here the label into the color sections.
Each of my points has been multiplied by three.
This is exactly what I wanted.
I can use this as a starting point.
This is a set of my Candidate Points.
I could have additional points.
I could have done a little bit all of that.
I could have added some points here, for instance, and so on.
But to be honest, the discretization steps are fine for me.
I will keep all the points like that.
I will open now my design of experiment menu,
go to my Custom Design platform.
In the response, I want to measure the strength of the material.
In the Factors, I will add my first parameter,
Laser power and welding speed as Covariate.
I select Covariate, I select laser power and Welding parameter.
Automatically, JMP fills up the lowest and highest value for these two parameter.
I will add also my 3-level categorial parameter.
I call it side,
and my level drive side,
center, and operator side.
I do not forget also to add my uncontrolled parameter.
This is the position of the weld.
This is an uncontrolled parameter.
I do not know the limits, so I put nothing in these boxes.
I also do not forget to change here
in order to take it into account the speed/plot feature.
I mentioned here that my laser power and welding speed are hard-to-change
compared to the side.
Everything is correct here, so we can run.
Concerning the constraints, I do not need this area,
because I already took into account my constraints
when selected my covariate, so I do not need here.
Concerning the model, I immediately choose RSM.
But in that RSM, I will suppress the interaction of the laser power
with the position and the interaction of the position
with the welding speed
because there is clearly no interaction at all.
I will immediately click on the Make Design button
because it will take some moment.
Here we can see that JMP proposed me
to perform eight tests with 24 measurements.
This is fine for me.
I keep this default parameter.
I make my table here.
Okay.
This is the defect concerning to laser power, welding speed, side.
I have the column ,
I will record the position of my welding speed,
where I will record the strength, so everything is okay.
I will never visualize the point into the Graph Builder.
I put, once again, the laser power in the Y- axis,
the welding speed will in the X -axis.
Perfect, and we read curve.
I will also put the side here into the Color area.
I will add some details.
Okay, here we can see that this is the point
that has been selected by JMP within the framework of our Candidate set.
For each point, I have to perform three measurements,
on drive side, center, and operator side,
and JMP wants me to perform this test twice.
Okay , so this is what we have done.
I will now show you the result.
I go back to my JMP journal here.
This is our last step, the result analysis.
I will open the associated table.
Here, this is the same table as previously.
I have recorded the positions.
I have recorded the strength in absolute value in terms.
I have inserted two columns here.
This is our
reference strength,
the strength of our base material that we have previously determined.
This is 9.76 tons,
because, in fact, I will use it in order to create this extra column,
this is the strength, but in percent compared to the base material.
This is on this last column.
This is the first column that we will take into account in our optimizations.
I store my analysis into each column here.
Here are the results.
As a reminder, I put on the right part.
the irregular area as a reminder.
Here are the experimental points that we have performed.
I have colored the point using the strengths in percent.
I use the Fit Model platform in order to create my model.
Step by step, I have suppressed the non-significant interaction
of our parameter
using the p-values here.
Finally, I have a model
with an explicative power of two of 96 percent,
which is quite good because, in fact, it means
that only four percent of the wall variation
escape to our prediction power.
Concerning the collinearities , if I look to our VIF,
our variance inflation factor, all of them are below three.
We can be now confident
in our model and we can use it in prediction.
We can go to the prediction profiler here.
First of all, I will focus on this part,
on the interaction of the position with the side.
What you can see here,
if I move the position of the weld,
it seems that the resistance is not sensitive
to the positions on the drive side and center.
But on the contrary, on the operator side, this one is clearly
influenced by the positions.
This is exactly what we have seen in our plate.
This is a modeling of our waves.
Here we do not see this kind of shape because this can be easily explained.
Our weld are not so huge.
It's only a sample of six centimeters.
We do not consume a lot of material.
We do not go along the wall
with that shape.
We go from the bottom to the top only.
We are quite happy because we were able
to analyze and to model correctly this behavior.
This is interesting because
we can now have access to the pure effect of the laser power and welding speed.
For this particular material,
we can conclude that we can increase the resistance of this material
by decreasing the laser power or by increasing the welding speed.
Now what we have to do
this is to determine an optimal point using all the information we have.
To do that, we prefer to do it using the control profiler.
This is what I have mentioned here.
In this control profiler, once again, I put in the X- axis,
the welding speed, in the Y- axis, I have the laser power.
I have reproduced
my area, my irregular area
where I am defect- free.
To do that,
I have simply
implement a script.
Here is a list of points,
and I just asked JMP to use this point and to draw a polygon.
I have my black area where I am defect- free.
On that drawing, I have also inserted the ISO resistance curve.
Here in red, you can see the values of this ISO resistance.
We can see that, here, we go from 50 percent to nearly 100 percent.
Before doing the optimization, I will add another constraint.
It's not enough.
From the productivity point of view,
we want, of course, to go as fast as possible and we want to have
the highest welding speed.
Using all that information, we have selected
the point at six kilowatts and 11 meters per minute.
This is the point that has been located here.
Why?
Because this point is located in the black area,
where the w eld seam is free of defect.
We can see using our model that we expect this point
to have at least a resistance of 90 percent of the resistance
of the best material.
What is interesting also is at this point
we have enough safety merging around this point.
Of course, we have tested this point and this is the result.
But I'm going to show you right now.
I go back to my presentation, which is located here.
This is the result of the optimal point we are choosing.
First of all, on this slide, you can see on the left part,
the upper w eld bead pictures,
on the right side, the lower weld bead pictures.
You can see that the weld seam are free of defect.
We have no patterns, we have no droplet, no chain of pearl, no holes, et cetera.
This is what we wanted.
From a resistance point of view, first of all, if we focus on the pictures,
we can see that this is the material that breaks
and this is not the weld seam that opens, so this is the first good point.
Concerning the resistance, we can see that each of them
are higher than 90 percent.
This is exactly what we wanted,
let's say that we have achieved our target.
This is the end of this presentation. This is now time to conclude.
First of all, I go back to my JMP journal, I would like to mention that
with this presentation, you have the possibility to download an article
that will be located
on the website.
Here you have a full article explaining all the case studies.
I have added additional material.
If you are interested in knowing more, please feel free to download it.
A s a conclusion, I would like to mention
that if some of you are interested in knowing more about covariates,
I would like to mention two available sources.
The first one is an article that you can find
on the JMP user community
entitled
"What is a covariate in design of experiments?"
Also from the same offer,
you have a webinar entitled "H andling Covariates E ffectively
when Designing Experiments."
To conclude, I put here a quote from Mark Twain
that humorously tells us that
"Facts are stubborn things, but statistics are pliable"
Inspired by Mark Twain,
I would like to say that facts are certainly stubborn things,
meaning complex, but don't panic
because, in fact, JMP can easily adapt to the reality of the field.
In my case,
he was able to adapt to a very irregular study area
and also to a very imperfect study material.
This is the end of my presentation.
I will now answer your question, so please feel free to ask.
If we run out of time, I mentioned here my contact information,
so please feel free to contact me,
and so I'm waiting now for your question.
Thanks a lot. Bye bye.
1. Background and introduction
Steel strip manufacturing ever reinvents itself by propositing new metallurgical concepts, requiring to tackle technical limitations of production systems. As a provider of mechatronic solutions for steel plate processing, Clecim SAS recently expanded its laser welder line with a next-generation machine capable of cutting and welding heavy plate using a 12kW laser source. Addressing the usual drawbacks in maintenance, operation and safety of current welding system based on mechanical cutting and CO 2 laser welding, the newly developped LW21H (Heavy) welding machine benefits from a smarter approach by processing thicker strips up to 9 mm with solid-state laser cutting and welding. This new generation of welders, heir to Clecim SAS' 20 years of experience in welding and in particular its little sister - the LW21M (Medium) - pushes back the current limits of performance and technological drawbacks observed in solutions for thicker materials. It is materialized by a 1:1 scale pilot designed, manufactured and tested in Clecim SAS workshops [ Figure 1 .]
Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together.Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together. Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together. Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together.
Figure 1a –  An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder.Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder. Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder. Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder.
In 2019, the laser cutting process was extensively studied and the use of Machine Learning techniques allowed for the conception of a model able of delivering robust cutting presets across the thickness range. Today, the focus is on the laser welding process and the acquisition of high-quality data that will soon allow the creation of a welding model, the final step for a completely automated machine. To achieve a good weld, two criteria must be met: a weld seam free of defects (such as spatters, droplets, etc.), and a good strength. To reach this result on a given material, many steps have been followed:
  • The determination of the welding flaws map and the weldability lobe, area where the weld seam is defect-free
  • The determination of the base material strength to ensure that the pieces of material are identical and homogenous
  • The analysis and modeling, via a DoE of the weld seam strength on the previously determined weldability lobe, which usually has a highly irregular shape
    Let’s now dive into the details of these exciting steps, all of them requiring the use of a JMP platform.
Notation
M Material type
F Focusing distance
H Material thickness
G Gap between the plates
P Laser power
T Thermal treatment
V Travel speed of the welding carriage
2. Laser welding process and factors
The welding process is made of 3 parts: the two plates to be welded which can be of the same nature and thickness or not, the laser welding head mounted onto a travelling carriage and connected to its 12kW laser source. To give an idea of the delivered power, a classic laser pointer used for a presentation has typically a power of 1mW. In comparison, the laser source used by Clecim SAS to cut and weld the pieces of material is 12 million times more powerful.
Generally speaking, the influencing parameters of laser welding belong to two categories, namely those related to the material to be welded itself, such as its nature M and thickness H , and those related to the process, such as the laser power used P , the speed of the welding carriage V , the focusing distance F , the heat treatment T or the spacing between the sheets G . To a lesser degree, other parameters are involved such as the inclination of the laser welding head, the type of shielding gas, its pressure, etc. Within the framework of this paper, only the used laser power P and travel speed of the welding carriage V will be considered. The materials to be welded will be identical and of the same thickness.
To put it in a nutshell, for the given pieces of material (M, H), two factors (P, V) have to be optimized with the goal of getting a flawless and resistant weld seam.
3. Weldability lobe
Figure 2 – Welding flaws map –  JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over.Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. The first step of the experimental approach consists in performing tests in order to build a map of welding defects and thus determine the weldability zone, i.e. the defect-free zone. Depending on the thickness of the material, the number of tests to perform can quickly become important. In effect, the goal is to test all the pairs (P, V) and to visually observe the quality of the weld bead to know if the combination (P, V) generates a defect or not. In order to drastically reduce the number of tests and to save time, the so- called “power jumps” procedure is used. In a single trial, at fixed speed, 11 power jumps, from 2 to 12kW in 1kW steps, are carried out giving the possibility to perform 11 tests in one. Regarding the welding speed, steps of 2 m/min were used from 3 to 18 m/min. In the end, the upper and lower parts of 88 weld seams were visually inspected and qualified.
The results were stored in a JMP table and evaluated using the Graph Builder platform [ Figure 2 .] The welding speed V is shown on the x-axis and the used laser power P on the y-axis. For a given speed, we find the 11 visual observations corresponding to the 11 power jumps of the test protocol. Thanks to the association of a color and a shape, in one combined, it is possible to represent four welding flaws at the same time and to visualize hence the major defect areas in this way. For each pair (P, V), pictures from the top and bottom weld seam have also been taken and stored into two expression/vector columns so that they can simultaneously appear in the tooltip area. By moving the mouse over the points, the pictures are displayed. This functionality allows to easily compare the influence of a factor change on the weld bead facies and thus to progressively enter into the understanding of the laser welding process.
4. Base material strength analysis
Before going further in the analysis of the welds, it is necessary to evaluate the strength of the base material, and this for 3 reasons:
  • The first reason is to establish a reference strength so that we can make comparisons.
  • The second one is to make sure that the 2 plates sent to us by our customer are comparable.
  • And the third one is to make sure that the plates are homogeneous and that they do not have any resistance profile in their width for instance.
To do that, Erichsen-type cupping tests on plates without any welds. Stamping is done via a ball and the breakage resistance is automaticallyrecorded. The protocol provides for three measurements in the width of the plate. Positions are respectively DS (drive side of the welding machine), C (center) and OS (operator side). The various results are stored in a JMP table and summarized in a dashboard [ Figure 3 .]
Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ).Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ). Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ). Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ).
In summary, the two plates to be welded can be considered identical, but further investigations are needed to understand why the strength variance is higher on the operator side.
Figure 4 – Appearance of the plate –  The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength.Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength. Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength. Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength.
To understand the differences in resistance on the operator side, it is necessary to pay attention to the visual aspect of the plate [ Figure 4.] Due to potential force variations during its treatment, the plates are inhomogeneous in term of strength in their width and length.
4. Weld bead strength analysis
The construction of the test plan requires taking into account all the various constraints, 4 in number:
  • The first constraint is related to the irregularly shaped
    region [4-Ch.5] of the weldability lobe. The traditional way to do it would be to delimit the study area using multiple linear constraints. Although possible, it is the technique of the candidate points, also called covariates [2,3,4-Ch.9] in JMP, that has been chosen for the simplicity sake.
  • The second one, due to the plate inhomogeneity, is related to the strength changes in the width. To take this effect into account, a 3 levels (DS, C, OS) categorical parameter is envisaged.
  • The third one, also due to plate inhomogeneity, is related to the periodic and incurred strength changes in the length. This parameter cannot be controlled but it must nevertheless be considered in the future test plan.
  • Finally, the fourth one is related to the fact that the 3 values of the categorical parameter are not independent since they belong to the same treatment (i.e. weld). Subsequently, a split-plot design [4-Ch.10] with parameters hard or easy to change has to be considered.
Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements.Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements. Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements. Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements.
The creation of the custom design of experiments is explained in [ Figure 5 .] A total of 8 tests and 24 measurements is lastly considered. The test plan is executed and for each triplet (P, V, Side) the following data are recorded: the position of the weld (in mm, from one end of the plate), the value of the strength (in absolute and in percent of the base material strength). The strength of the welds is then modeled using the Fit Model platform [ Figure 6 .]
Figure 6 – Building of the custom design of experiments –  The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists).Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists). Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists). Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists).
The resulting model being of good quality, it can be used in prediction. After correcting for the effects of weld position and sides, the trends attributable to laser power and traveling speed are clearly visible in the Prediction Profiler [ Figure 7 .] Figure 7 – Checking the model's behavior with the Profiler –  The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases.Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. For the considered material, there does not seem to be any interaction between the laser power and the welding speed. The weld strength therefore increases with the travelling speed and when the laser power decreases.
However, that being said, the work is not over yet. The limits of the weldability lobe must also be carefully considered in the search for an optimum. On the basis of the Prediction Profiler alone, this is not easy, so it is the Contour Profiler's turn to play!
The use of the Contour Profiler allows to superimpose the iso-resistance curves from the strength model with the weldability lobe [ Figure 8 .] Finding the optimal point requires locating a point that is not only within the weldability lobe but that also has the highest strength.
Figure 8 – Optimization with the Contour Profiler –  The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph.Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph. Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph. Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph.
If we add to this the fact that the welding speed should be as fast as possible for a maximum productivity, the coordinate spot (11 mpm, 6kW) proves to be ideal. Not only does it meet all the above criteria, but it also offers a satisfactory safety margin for an industrial process.
Of course, these settings have been tested. The results are presented [ Figure 9 and Figure 10 .] In summary, the weld seam has a defect-free surface with a strength across the entire width comparable to that of the base material. The objective has been achieved!
Figure 9 – Optimum preset and weld seam appearance –  The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects.Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 10 – Optimum preset and weld strength –  The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one.Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one. Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one. Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one.
5. Conclusion
Finding the optimal laser welding parameters for a given material is not easy. Fortunately, JMP offers a suite of platforms that, in one combined, provide a rigorous approach to achieving our goal.
The use of the Graph Builder, Personal Map Shape and Dashboards allowed us to visually organize our data both in terms of welding defects (welding flaws map, weldability lobe) and strength (Erichsen-type cupping tests).
The ANOVA and Distribution platforms were used to make informed decisions about the equivalence of the plates to be processed and their level of strength.
Once the weldability zone was determined (zone where the weld beads are free of defects), the strength of the weld bead was studied using the design of experiments methodology. In this paper, only 2 parameters were considered (laser power, welding speed).
The Custom Design platform allowed for a high degree of customization of the tests in relation to the encountered constraints. The highly irregular shape of the study area gave the opportunity to use the candidate point method (covariates), in addition to other features such as split-plot design and uncontrolled factors.
The modeling of the weld strength via the Fit Model platform allowed not only to understand the involved physical phenomena but also to proceed to a multi-criteria optimization via the Contour Profiler. Finally, the objective was achieved since all the steps allowed to propose and validate a set point with a maximum productivity and a good weld, both defect-free and resistant.
This step is part of an extensive, very high-value data acquisition program that will allow, just as it did in 2019 with the laser cutting process, the development of a laser welding model that will provide robust welding instructions, regardless of the incoming product, the final step to fully automate the machine.
6. About Clecim SAS
Clecim SAS, based in Montbrison (Loire), joined the Mutares group on April 1, 2021. It is an engineering and production company, bringing its expertise in services and manufacturing in particular for the metallurgical industry. Its main activity is the operational support of the performance of its flat steel producer customers, in particular for the automotive market. This support takes the form of studies and advice on the improvement of their production tools, the supply of special machines to optimize performance and, if necessary, the supply of complete production lines based on the latest technologies.
For decades, Clecim SAS has been promoting innovation in the steel industry and is constantly looking for new solutions to provide metal producers with state-of-the-art equipment, allowing them to gain a competitive advantage. Our latest areas of focus include new technologically differentiated solutions, advanced process analysis and optimization. Of particular note in this area are world-renowned high-level solutions such as special laser welding machines, surface inspection systems, rolling equipment, and galvanizing lines for flat steel for the automotive market.
With its own factory, Clecim SAS is able to manufacture and test complete machines. The company has many skills (engineering, manufacturing, testing) allowing it to master the entire value chain. Clecim SAS can also provide its customers with a pilot rolling mill for the development and confirmation of flattening, rolling and tribology models.
Figure 11 – Clecim SAS (Montbrison city, France)Figure 11 – Clecim SAS (Montbrison city, France) Figure 11 – Clecim SAS (Montbrison city, France) Figure 11 – Clecim SAS (Montbrison city, France)
About the author
Stéphane Georges.png Graduated from Grenoble INP in Materials Science and Process Engineering, Stéphane GEORGES (47y) joined Clecim SAS in 2001. After holding several positions in the Automation, Modeling and Process Control department, and after 3 years of expatriation in Erlangen at Siemens in Germany, Stéphane moved to the position of R&D Project Manager. His various missions related to industrial processes lead him to use his skills in smart experimentation, statistical analysis and modeling, coding, machine learning and deep learning to make the most of data.
Acknowledgment
We would like to express our thanks and gratitude to Florence Kussener of JMP for her support in using the software and preparing us for our first ever participation in the Discovery Summit.
References
[1] André Augé, JMP Addict: Tips and Tricks Workshop: Customize Your Reports and Chart Builder Tips, Webinar, 2021, shorturl.at/jqAZ2
[2] Lekivetz Ryan, What is a covariate in design of experiments, article, JMP Community, 2021, shorturl.at/hqvH4
[3] Lekivetz Ryan, Developer Tutorial - Handling Covariates Effectively when Designing Experiments, webinar, JMP Community, 2021, shorturl.at/fvEZ0
[4] Peter Goos, Bradley Jones, Optimal Design of Experiments: A Case Study Approach, Wiley, 2011
CLECIM ® is an internationally registered trademark owned by company Clecim SAS.
Clecim SAS all rights reserved 2022-feb-02
0 Comments
Published on ‎05-17-2024 02:08 PM by Staff | Updated on ‎07-23-2025 11:15 AM
CLECIM ® Laser Welding Machines
Finding the optimal parameters for laser welding of steel plates with JMP
Stéphane GEORGES
R&D and Data Science Project Manager, Dept. of Technology and Innovation Clecim SAS., 41 route de Feurs, CS 50099, 42600 Savigneux Cedex, France
Purpose To be considered good, a weld bead must meet two criteria: it must be free of defects (such as spatter, humpings, underfill, holes, etc.) and resistant (assessed by means of an Erichsen-type cupping test). The search for the optimal parameters for laser welding steel plates is already extremely demanding due to this double constraint. But if, on the top of that, you consider the productivity of the processing line and the quality of the incoming material, then the task becomes a challenge!
Approach And that is precisely this challenge that was overcome with the use of JMP. To achieve this result, many steps were implemented, all of them requiring the use of a JMP platform or feature:
  1. Base material strength analysis, qualification of the two plates to be welded [Graph builder, Map shape, ANOVA, Dashboard]
  2. Synthesis of the visual observations, production of the weld defects map, which determines a study area of irregular shape where the weld seam is flawless. [Graph builder, Multiple pictures hover label]
  3. Weld strength analysis and optimization on a non-homogeneous material and on the defined defect-free zone, given as a set of candidate points. [Custom design, Split-plot, Covariates, Uncontrolled factor, Fit model, Prediction and Contour profilers]
Findings and Value For the given material, the objective was achieved since all the steps allowed to propose and validate a set point with a maximum productivity and a good weld, both defect-free and resistant, JMP being pliable and able to adapt to all the constraints of the process and the material.
Key words : JMP, laser welding, design of experiments, DoE, covariates, LW21M, LW21H
Hello everyone.
Thank you for attending this experience sharing session on JMP.
My name is Stephane Georges,
I'm R&D Project Manager at Clecim, and I'm very keen on data science.
Today, we'll talk to you about the design of experiment methodology,
and more specifically, about the case we encountered when trying to find
optimal parameters for laser welding process.
During this presentation, I will show you how we use JMP for various platform
and how JMP adapted to the reality of the field by taking into account
a very irregular study area and a very imperfect study matter.
Without further delay, I will start my presentation
by telling you who we are and what we do.
Clecim is an engineering and production company of equipment
for the steel industry.
We are located in Montbrison in France in the surrounding of Lyon.
The history of Clecim is not new,
as we celebrated five years ago our 100th anniversary.
The area of the site is about 12 soccer field where work 230 employees,
mainly composed of managers and technicians.
A s we like statistics when working with JMP, here is the first one.
Our population is composed mainly of men, about 80 percent and 20 percent of women.
Concerning Clecim activities:
Our first activities is studies and consulting activities
for our flat steel producer customer.
We supply individual machine, or we supply a complete production line
such as pickling line, annealing line, galvanizing line, painting line and so on.
We also have an activity of services
for the furniture or spare parts, for export missions, maintenance,
and so on.
I put on this picture a typical layout of a galvanizing line.
This is to give you an idea of such processing line.
This one is dedicated to the automotive market
and the length of such an equipment is about half a kilometer,
so a very huge industrial plant.
When I talk previously about a machine,
I had in mind rolling equipment such as rolling mill, plate levellers,
automated strip surface inspection system, and even laser welding machine.
This is on this last equipment that we are going to focus on right now.
I will now talk to you about autogenous laser welding process.
Autogenous means without filling wire.
I will talk also about the parameter and factors that govern this process.
But first of all,
I would like to introduce our machine, the subject of our study.
On the left part of the slide, you can see our welding machine.
In fact, not only our welding machine but it's containment,
the machine is inside the containment
for safety reasons because we are using laser.
The dimension here
of the door gives you an idea of this welding machine of scale one.
This is a huge industry, our welding machine.
On the right part of this presentation, you can see a partial inside
of this welding machine, where you can see the clamps
and the [inaudible 00:04:37] of the machine.
Inside, you see the top portion of the strip,
the head and the tail of the strip,
that will be, first of all, cut also with laser and finally brought together
in order to be welded.
I will now talk to you about our target and constraint.
Of course,
our objective, our target is to have a good weld.
To do that, we need to achieve two objectives.
The first one is to have a weld seam which is defect- free.
Here on this slide, I put you an example of such a weld.
This is picture number one.
You can see on this picture that this whole thing is quite nice
without any defect.
When I talk about defect, here is a list of the typical defect
that we encounter when trying to weld with a laser.
Typically, we could have some patterns.
This is picture number two.
This is a top view.
In such a case, this is the molten material,
which is ejected from the top of the weld.
We could have also chain of pearls.
This is picture number three.
This time this is a bottom view,
and this is some droplets at the bottom of the weld seam.
We could have also
other defects, such as humpings, underfillings, or even holes.
This is picture number four here.
And here, typically, this is the case
when we have a very low travel speed and a very high power density.
Instead of welding, we are drilling at the material
and we create some holes.
Of course, this is we absolutely want to avoid.
Otherwise, we will decrease the resistance
of our weld.
This is a transition for the second objective
because we want not only the weld seam to be p erfect,
but we want it also to be resistant.
This is evaluated via an Erichsen type cupping test,
so this I will describe it a little bit later.
Our target is to have a trend as close as possible
to the one of the base material.
I will now talk to you about the last welding parameters,
the factor governing the process.
On this left part of this slide,
I put you a very schematic view of the process.
In gray at the bottom,
you can see the two pieces of material that we want to weld together
that can be of the same nature and thickness on it.
In yellow, this is laser welding head
that is connected in blue to its laser source.
In order to imagine
the kind of power that we use
for such an application, imagine that when you use a laser pointer,
typically for a presentation,
such kind of device has a power of just one milliwatt.
Here the last source we use has a power of 12 million times.
It is 12 million times more powerful that's such a small device.
Just to explain that we have a very huge power.
We need very little power to cut our material
and to weld also this material.
I could use the process parameter, the typical process parameter,
which can be, first of all, the laser power,
the travel speed of the welding carriage,
the focusing distance, the gap between the plates,
the thermal treatment that we can apply afterwards, and so on.
But in fact,
for simplicity reason, in the rest of this presentation,
we will focus only on the two main one,
which is the laser power and the travel speed.
We will also consider
that the materials are identical and of the same thickness.
You will see that just with these two parameters we will have enough to do.
Okay, so the picture is set.
We have two targets.
One is to have a weld seam free of defect
and we want also to have its resistance.
We are now going to focus on our case study towards a good weld.
Our first target is to have a weld , which is defect- free.
We are going to search for what is called weldability lobe.
To do that, we need to get some data.
To get some data we will use the so called Power JMP procedure.
In that case, nothing to do with JMP, even if JMP is a powerful software.
But
this is how the procedure is called.
The picture on the bottom gives you an example of such a procedure.
At a fixed speed, we will perform 11 successive Power JMP.
In that case, we will switch from two kilowatts to eight kilowatts
to three kilowatts and so on.
The target is to reduce the number of options we have to do,
and in just one weld, we will have 11 sample
and we will have 11 observations to do.
Afterwards, we will visually examine
the upper part of our bead, the lower part of our bead
for each slot of this sample.
All of these data are collected into JMP
and we will use the Graph Builder platform in order
to display this map.
This is what I'm going to show you right now.
I go to my JMP journal here.
We will have four steps to follow.
This is our first step, building the welding format.
I will open
my table.
I collected all the data in this table.
I have all my parameters here, so the laser power, the welding speed.
In this column, I inserted my visual observation.
Is there any penetration? Yes/N o.
Do we have material loss? Yes/N o.
Humping? Yes/No, and so on.
A t the end of this file, I also put, as you can see,
I had two additional columns
of expression vector type where I have inserted
the picture of all my observations.
As you can see here also, I requested to have this information
displayed in the study area.
Now, we are ready to open our Graph Builder.
Here
I can learn it, okay?
All the data has been collected in this map.
Here you can see that on the X- axis, I put my welding speed.
On the Y- axis, I have my laser power.
I have associated for each defect color or shape.
A lso, we can have an association of the color and shape in that way,
which is a convenient way because we can overlay
four different type of defects at the same time for each point.
This is what I'm going to show you.
For instance, if I take this blue point here,
according to the legend, we have top spatters.
This is exactly what my pictures show you.
Here, this is the picture of the upper part of my weld,
here is a picture of the lower part of my weld.
Here we can see that we have effectively top spatters,
whereas the bottom part is defect- free.
For instance, if I take another one, if I take this purple one here.
So purple, this is the association of the blue defect and the red defect.
We have top spatters and bottom spatters,
which is effectively what we can see here on that picture.
This is a convenient way to see if effectively.
I have no mistake in order to know the magnitude of the defect.
This feature using the pictures is also very convenient because, for instance,
if I take this point here and I lock the pictures,
and if I take this additional point here and I lock also the pictures,
we can see that for constant laser power, I can compare the pictures
and see what are the effects when varying the welding speed.
In that case,
when we increase our welding speed, we can see that the width of our weld seam
decrease both on the top and both on the bottom.
This is a convenient way, let's say,
to dip into the understanding of our process.
I will close that.
I'll come back to my study case.
We are interested in the good weld area.
This is the area that I'm going to highlight here.
This is the black area.
Okay, like that.
Okay, this is our area of interest.
Now, what we want to do,
let's say, to investigate
the behavior of our weld seam
from the resistance point of view on that typical area.
Of course, we want to do it with a minimum number of tests
and we will perform a design of experiment
on this very
Okay, so I go back to my presentation.
But
before answering into the conception of the design of experiment,
we have another interesting topic to do with JMP,
because we have, first of all, to study the strength of our base material.
We have to evaluate
the basic strength of the material via an Erichsen- type cupping test.
Why are we doing that?
We have three targets, three objectives.
The first one this is to establish
a reference from the strength point of view.
In that way, we will be able to compare
the resistance of our base material with the resistance of our weld seam.
This is the first point.
The second point is to be able to compare the two pieces of material
that our customer sends us.
We want to be sure that these two pieces
have the same behavior.
For that, we have to ensure
that they can be comparable.
The last point is that we want also to check that the plates are homogeneous
from the resistance point of view and that they do not present
any resistance profile in their widths or in their lengths.
To do our Eric hsen-type cupping test, we will do that on the base material.
This is what is mentioned,
what is highlighted here in the three first pictures.
We do not have any weld.
We're just performing this Erichsen- type cupping test.
For simplicity reason
I will call this procedure ball test in the remaining part of the presentation.
These three ball tests, we do them on three different positions
of the material, one located at the center of our sample,
one located on what we call the drive side on the machine,
and one located on the operator side of the machine.
For one sample, we do free tests.
What is a ball test?
In fact, this is explained
in the pictures located at the bottom of this slide.
We simply take
a bowl made in titanium, and we will press it from the bottom
and we will register the deformation of the material,
the breakage force.
We do that for our two plates,
and we register all of that in JMP and analyze the results in JMP.
We will use the distribution platform and the Fit X by Y platform.
I go back to my JMP journal.
This is our second step, analyzes the base material.
I will open my file.
Here, I put all my data.
My plate ID, plate number 1 and 2.
For each plate I do that twice.
For each sample, we perform the measurements
at three different locations,
and here are the recorded value, the recorded strength.
We will analyze all of that and I store everything into a dashboard.
First of all, this is interesting to see visually our result.
I will focus, first of all, on this custom map shape.
In blue, you have the data for the first plate,
where I have my first sample and second sample.
For each sample, I have my free ball test, one located on the operator side,
one located in the center, and one located here on the drive side.
We have the same for the second piece of material.
What we can see here is that the resistance
goes through the following rates, so from nine to 10.4 tons.
Nothing really particular to see, except maybe that
here in the operator side, we can see that we have on the same side
the external value.
Here is the lowest value and here is the maximum value,
so maybe that will be something to look at
but we will come to this a little bit later.
Our target is to perform an ANOVA in order
to see if our two plates can be considered as comparable.
But before doing an ANOVA,
we need to ensure that our data follow a normal distribution
and that our variances can be considered as equal,
so this is what we are going to do right now.
Here are the distribution for plate number 1, for plate number 2.
Okay, I know that I do not have a lot of data,
but we will consider that we have enough to perform the test.
We will look at the two Anderson-Darling coefficients here.
What the p-value tells us is that we cannot reject the hypothesis
that the two plates can be comparable so that's good.
Then concerning the variances, so here we use another platform,
but we first go at the end, we perform the variance analysis here,
and we will look at the F Test, and the F Test tell us
that we can consider as our variance are equal.
As our data are normally distributed on our variant article,
we can apply safely our ANOVA.
This is what is mentioned here.
On the top part, you have the drawing.
Here are the associated data.
I will not focus on the data.
We will just have a look at the pictures.
Here, what we can see,
this is the extremities of the two diamonds overlap.
We cannot reject the hypothesis that our two plates are different,
so this is good.
We will now reach the conclusion that our two plates are equivalent.
We can now aggregate all the data.
This is what is done here in the distribution.
We put all our data together,
and finally, we have a global resistance of our plate of 9.76 tons
plus or minus 0.17 at two standard deviations.
This is the first point and we will use this information a little bit later.
Another interesting thing,
so this is what is mentioned here.
We can also perform the ANOVA taking into account the position.
And this as we have previously observed,
we can see that the run variation on the operator side
is a little bit higher
compared to the drive side and the center of our plate.
We want to understand a little bit why such things happen.
To do that, I will come back to my presentation,
we will have a look at the plate.
We are studying at the moment.
Here is the appearance of our sheet metal.
What we can see is that on the drive side here,
our plate is nearly flat, I would say.
on the operator side, we clearly see that the plates have some waves.
I do not know exactly what is the history
of this material, but we can clearly imagine that
there was a trouble at the rolling m ill or the plate leveller
and that the higher force has been applied on the operator side,
leading to this kind of periodic modification of the resistance.
This is a new constraint because we have to take into account
this new information in our design of experiment.
I will sum up all the information we have before building our design of experiment.
First of all, I remind you that we have a very irregular study area.
This is a black area that is mentioned here
in the drawing.
The traditional way
to deal with such things in JMP would be to fill up a linear constraint.
But here due to the shape of this area, it's a little bit difficult.
Instead, we prefer to use the Candidate Points technique,
which is called also Covariates engine.
I remind you also that we have an inhomogeneous plate
and to deal with this phenomenon, we will have to introduce a few parameters
into our design of experiment.
First of all, we have to take into account the strength variation in the width.
To do that, we will introduce a categor ial parameter,
a 3 levels- categorial parameters,
and the three levels are drive side, center, and operator sides.
In order to deal with the periodic variation of the resistance
along the length of the plate, well, this is a little bit difficult,
because, in fact, we do not control this parameter.
We have to be on
this variation.
For that, we will introduce the weld position
from the head of the plate, or in millimeter,
and we will introduce it as an uncontrolled parameter.
Finally, this is not finished.
This is what you can realize, what you can see
in the last picture at the bottom.
This is typically here a picture of a weld,
where are located above three ball tests.
Well, these ball tests are not independent.
They belong to the same treatment.
They belong to the same weld.
They are at the same weld position.
We are
in the presence of split/ plot design,
where we have hard and easy- to- change parameter.
This is a lot of constraints we have to take into account.
Now, I will show you how to do that with JMP.
I can go back to my JMP journal, so this is our first step.
But I will show you from the beginning and I will go back here
to this step.
I come back to the file I had previously.
I will select here
all the rows with a Good Weld.
I will also select
another power column, my welding speed column.
In the table here, I will extract a subset of this table.
I will extract selected line.
I will extract the selected column here.
Okay, I will build my subset of Candidate Points.
But here is the tricky thing because, in fact,
as we have a design also, I need to tell them that
you will have the possibility to select three times each point.
I will multiply by three this number of points.
There is probably a lot of way to do that.
In my case, I will just create three columns,
one call it drive side,
one call it center,
one call it operator side,
and I will just stack all these
using that three columns.
Here I have created my set of Candidate Points.
With the Graph Builder, I will check that everything is okay.
In the Y- axis, I will put the laser power. On the X- axis, I will put the laser speed.
Here, we can recognize the shape of our irregular study area.
I will also put here the label into the color sections.
Each of my points has been multiplied by three.
This is exactly what I wanted.
I can use this as a starting point.
This is a set of my Candidate Points.
I could have additional points.
I could have done a little bit all of that.
I could have added some points here, for instance, and so on.
But to be honest, the discretization steps are fine for me.
I will keep all the points like that.
I will open now my design of experiment menu,
go to my Custom Design platform.
In the response, I want to measure the strength of the material.
In the Factors, I will add my first parameter,
Laser power and welding speed as Covariate.
I select Covariate, I select laser power and Welding parameter.
Automatically, JMP fills up the lowest and highest value for these two parameter.
I will add also my 3-level categorial parameter.
I call it side,
and my level drive side,
center, and operator side.
I do not forget also to add my uncontrolled parameter.
This is the position of the weld.
This is an uncontrolled parameter.
I do not know the limits, so I put nothing in these boxes.
I also do not forget to change here
in order to take it into account the speed/plot feature.
I mentioned here that my laser power and welding speed are hard-to-change
compared to the side.
Everything is correct here, so we can run.
Concerning the constraints, I do not need this area,
because I already took into account my constraints
when selected my covariate, so I do not need here.
Concerning the model, I immediately choose RSM.
But in that RSM, I will suppress the interaction of the laser power
with the position and the interaction of the position
with the welding speed
because there is clearly no interaction at all.
I will immediately click on the Make Design button
because it will take some moment.
Here we can see that JMP proposed me
to perform eight tests with 24 measurements.
This is fine for me.
I keep this default parameter.
I make my table here.
Okay.
This is the defect concerning to laser power, welding speed, side.
I have the column ,
I will record the position of my welding speed,
where I will record the strength, so everything is okay.
I will never visualize the point into the Graph Builder.
I put, once again, the laser power in the Y- axis,
the welding speed will in the X -axis.
Perfect, and we read curve.
I will also put the side here into the Color area.
I will add some details.
Okay, here we can see that this is the point
that has been selected by JMP within the framework of our Candidate set.
For each point, I have to perform three measurements,
on drive side, center, and operator side,
and JMP wants me to perform this test twice.
Okay , so this is what we have done.
I will now show you the result.
I go back to my JMP journal here.
This is our last step, the result analysis.
I will open the associated table.
Here, this is the same table as previously.
I have recorded the positions.
I have recorded the strength in absolute value in terms.
I have inserted two columns here.
This is our
reference strength,
the strength of our base material that we have previously determined.
This is 9.76 tons,
because, in fact, I will use it in order to create this extra column,
this is the strength, but in percent compared to the base material.
This is on this last column.
This is the first column that we will take into account in our optimizations.
I store my analysis into each column here.
Here are the results.
As a reminder, I put on the right part.
the irregular area as a reminder.
Here are the experimental points that we have performed.
I have colored the point using the strengths in percent.
I use the Fit Model platform in order to create my model.
Step by step, I have suppressed the non-significant interaction
of our parameter
using the p-values here.
Finally, I have a model
with an explicative power of two of 96 percent,
which is quite good because, in fact, it means
that only four percent of the wall variation
escape to our prediction power.
Concerning the collinearities , if I look to our VIF,
our variance inflation factor, all of them are below three.
We can be now confident
in our model and we can use it in prediction.
We can go to the prediction profiler here.
First of all, I will focus on this part,
on the interaction of the position with the side.
What you can see here,
if I move the position of the weld,
it seems that the resistance is not sensitive
to the positions on the drive side and center.
But on the contrary, on the operator side, this one is clearly
influenced by the positions.
This is exactly what we have seen in our plate.
This is a modeling of our waves.
Here we do not see this kind of shape because this can be easily explained.
Our weld are not so huge.
It's only a sample of six centimeters.
We do not consume a lot of material.
We do not go along the wall
with that shape.
We go from the bottom to the top only.
We are quite happy because we were able
to analyze and to model correctly this behavior.
This is interesting because
we can now have access to the pure effect of the laser power and welding speed.
For this particular material,
we can conclude that we can increase the resistance of this material
by decreasing the laser power or by increasing the welding speed.
Now what we have to do
this is to determine an optimal point using all the information we have.
To do that, we prefer to do it using the control profiler.
This is what I have mentioned here.
In this control profiler, once again, I put in the X- axis,
the welding speed, in the Y- axis, I have the laser power.
I have reproduced
my area, my irregular area
where I am defect- free.
To do that,
I have simply
implement a script.
Here is a list of points,
and I just asked JMP to use this point and to draw a polygon.
I have my black area where I am defect- free.
On that drawing, I have also inserted the ISO resistance curve.
Here in red, you can see the values of this ISO resistance.
We can see that, here, we go from 50 percent to nearly 100 percent.
Before doing the optimization, I will add another constraint.
It's not enough.
From the productivity point of view,
we want, of course, to go as fast as possible and we want to have
the highest welding speed.
Using all that information, we have selected
the point at six kilowatts and 11 meters per minute.
This is the point that has been located here.
Why?
Because this point is located in the black area,
where the w eld seam is free of defect.
We can see using our model that we expect this point
to have at least a resistance of 90 percent of the resistance
of the best material.
What is interesting also is at this point
we have enough safety merging around this point.
Of course, we have tested this point and this is the result.
But I'm going to show you right now.
I go back to my presentation, which is located here.
This is the result of the optimal point we are choosing.
First of all, on this slide, you can see on the left part,
the upper w eld bead pictures,
on the right side, the lower weld bead pictures.
You can see that the weld seam are free of defect.
We have no patterns, we have no droplet, no chain of pearl, no holes, et cetera.
This is what we wanted.
From a resistance point of view, first of all, if we focus on the pictures,
we can see that this is the material that breaks
and this is not the weld seam that opens, so this is the first good point.
Concerning the resistance, we can see that each of them
are higher than 90 percent.
This is exactly what we wanted,
let's say that we have achieved our target.
This is the end of this presentation. This is now time to conclude.
First of all, I go back to my JMP journal, I would like to mention that
with this presentation, you have the possibility to download an article
that will be located
on the website.
Here you have a full article explaining all the case studies.
I have added additional material.
If you are interested in knowing more, please feel free to download it.
A s a conclusion, I would like to mention
that if some of you are interested in knowing more about covariates,
I would like to mention two available sources.
The first one is an article that you can find
on the JMP user community
entitled
"What is a covariate in design of experiments?"
Also from the same offer,
you have a webinar entitled "H andling Covariates E ffectively
when Designing Experiments."
To conclude, I put here a quote from Mark Twain
that humorously tells us that
"Facts are stubborn things, but statistics are pliable"
Inspired by Mark Twain,
I would like to say that facts are certainly stubborn things,
meaning complex, but don't panic
because, in fact, JMP can easily adapt to the reality of the field.
In my case,
he was able to adapt to a very irregular study area
and also to a very imperfect study material.
This is the end of my presentation.
I will now answer your question, so please feel free to ask.
If we run out of time, I mentioned here my contact information,
so please feel free to contact me,
and so I'm waiting now for your question.
Thanks a lot. Bye bye.
1. Background and introduction
Steel strip manufacturing ever reinvents itself by propositing new metallurgical concepts, requiring to tackle technical limitations of production systems. As a provider of mechatronic solutions for steel plate processing, Clecim SAS recently expanded its laser welder line with a next-generation machine capable of cutting and welding heavy plate using a 12kW laser source. Addressing the usual drawbacks in maintenance, operation and safety of current welding system based on mechanical cutting and CO 2 laser welding, the newly developped LW21H (Heavy) welding machine benefits from a smarter approach by processing thicker strips up to 9 mm with solid-state laser cutting and welding. This new generation of welders, heir to Clecim SAS' 20 years of experience in welding and in particular its little sister - the LW21M (Medium) - pushes back the current limits of performance and technological drawbacks observed in solutions for thicker materials. It is materialized by a 1:1 scale pilot designed, manufactured and tested in Clecim SAS workshops [ Figure 1 .]
Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together.Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together. Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together. Figure 1b - A partial view of the inner part of the machine. Head and tail of the two plates will be cut by laser technology and then welded together.
Figure 1a –  An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder.Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder. Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder. Figure 1a – An external view of the containment of the heavy laser welder at Montbrison workshop. The size of the door gives an idea of the dimensions of this industrial welder.
In 2019, the laser cutting process was extensively studied and the use of Machine Learning techniques allowed for the conception of a model able of delivering robust cutting presets across the thickness range. Today, the focus is on the laser welding process and the acquisition of high-quality data that will soon allow the creation of a welding model, the final step for a completely automated machine. To achieve a good weld, two criteria must be met: a weld seam free of defects (such as spatters, droplets, etc.), and a good strength. To reach this result on a given material, many steps have been followed:
  • The determination of the welding flaws map and the weldability lobe, area where the weld seam is defect-free
  • The determination of the base material strength to ensure that the pieces of material are identical and homogenous
  • The analysis and modeling, via a DoE of the weld seam strength on the previously determined weldability lobe, which usually has a highly irregular shape
    Let’s now dive into the details of these exciting steps, all of them requiring the use of a JMP platform.
Notation
M Material type
F Focusing distance
H Material thickness
G Gap between the plates
P Laser power
T Thermal treatment
V Travel speed of the welding carriage
2. Laser welding process and factors
The welding process is made of 3 parts: the two plates to be welded which can be of the same nature and thickness or not, the laser welding head mounted onto a travelling carriage and connected to its 12kW laser source. To give an idea of the delivered power, a classic laser pointer used for a presentation has typically a power of 1mW. In comparison, the laser source used by Clecim SAS to cut and weld the pieces of material is 12 million times more powerful.
Generally speaking, the influencing parameters of laser welding belong to two categories, namely those related to the material to be welded itself, such as its nature M and thickness H , and those related to the process, such as the laser power used P , the speed of the welding carriage V , the focusing distance F , the heat treatment T or the spacing between the sheets G . To a lesser degree, other parameters are involved such as the inclination of the laser welding head, the type of shielding gas, its pressure, etc. Within the framework of this paper, only the used laser power P and travel speed of the welding carriage V will be considered. The materials to be welded will be identical and of the same thickness.
To put it in a nutshell, for the given pieces of material (M, H), two factors (P, V) have to be optimized with the goal of getting a flawless and resistant weld seam.
3. Weldability lobe
Figure 2 – Welding flaws map –  JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over.Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. Figure 2 – Welding flaws map – JMP Chart Builder is used to view the weld defect map. The major defect areas can easily be recognized: partial penetration (yellow), holes (orange), spatters (blue, purple), chain of pearls (horizontale stripes), defect-free area (black). Pictures of the top and bottom weld seam are displayed in the tooltip area when moving the mouse over. The first step of the experimental approach consists in performing tests in order to build a map of welding defects and thus determine the weldability zone, i.e. the defect-free zone. Depending on the thickness of the material, the number of tests to perform can quickly become important. In effect, the goal is to test all the pairs (P, V) and to visually observe the quality of the weld bead to know if the combination (P, V) generates a defect or not. In order to drastically reduce the number of tests and to save time, the so- called “power jumps” procedure is used. In a single trial, at fixed speed, 11 power jumps, from 2 to 12kW in 1kW steps, are carried out giving the possibility to perform 11 tests in one. Regarding the welding speed, steps of 2 m/min were used from 3 to 18 m/min. In the end, the upper and lower parts of 88 weld seams were visually inspected and qualified.
The results were stored in a JMP table and evaluated using the Graph Builder platform [ Figure 2 .] The welding speed V is shown on the x-axis and the used laser power P on the y-axis. For a given speed, we find the 11 visual observations corresponding to the 11 power jumps of the test protocol. Thanks to the association of a color and a shape, in one combined, it is possible to represent four welding flaws at the same time and to visualize hence the major defect areas in this way. For each pair (P, V), pictures from the top and bottom weld seam have also been taken and stored into two expression/vector columns so that they can simultaneously appear in the tooltip area. By moving the mouse over the points, the pictures are displayed. This functionality allows to easily compare the influence of a factor change on the weld bead facies and thus to progressively enter into the understanding of the laser welding process.
4. Base material strength analysis
Before going further in the analysis of the welds, it is necessary to evaluate the strength of the base material, and this for 3 reasons:
  • The first reason is to establish a reference strength so that we can make comparisons.
  • The second one is to make sure that the 2 plates sent to us by our customer are comparable.
  • And the third one is to make sure that the plates are homogeneous and that they do not have any resistance profile in their width for instance.
To do that, Erichsen-type cupping tests on plates without any welds. Stamping is done via a ball and the breakage resistance is automaticallyrecorded. The protocol provides for three measurements in the width of the plate. Positions are respectively DS (drive side of the welding machine), C (center) and OS (operator side). The various results are stored in a JMP table and summarized in a dashboard [ Figure 3 .]
Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ).Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ). Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ). Figure 3 – Base material strength analysis The dashboard is composed of various JMP platforms: Graph Builder, Distributions and ANOVA. The custom map shape[1] of the Graph Builder displays the two samples corresponding to each of the two plates and the position of the various cupping tests colored by strength. In the ANOVA, the overlap of the two diamond tips demonstrates that the plate can be considered as identical. The chart on the right shows that the strength variance is higher on operator side (OS). Once aggregated, data from the bottom distribution presents an average strength is 9.76±0.18 tons (at 2σ).
In summary, the two plates to be welded can be considered identical, but further investigations are needed to understand why the strength variance is higher on the operator side.
Figure 4 – Appearance of the plate –  The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength.Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength. Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength. Figure 4 – Appearance of the plate – The plates present a relatively flat aspect on the drive side and waves on the operator side. The history of the plates is unknown but there must have been a rolling of planishing issue with a higher force applied on the operator side, which created this appearance and a periodic modification of the strength.
To understand the differences in resistance on the operator side, it is necessary to pay attention to the visual aspect of the plate [ Figure 4.] Due to potential force variations during its treatment, the plates are inhomogeneous in term of strength in their width and length.
4. Weld bead strength analysis
The construction of the test plan requires taking into account all the various constraints, 4 in number:
  • The first constraint is related to the irregularly shaped
    region [4-Ch.5] of the weldability lobe. The traditional way to do it would be to delimit the study area using multiple linear constraints. Although possible, it is the technique of the candidate points, also called covariates [2,3,4-Ch.9] in JMP, that has been chosen for the simplicity sake.
  • The second one, due to the plate inhomogeneity, is related to the strength changes in the width. To take this effect into account, a 3 levels (DS, C, OS) categorical parameter is envisaged.
  • The third one, also due to plate inhomogeneity, is related to the periodic and incurred strength changes in the length. This parameter cannot be controlled but it must nevertheless be considered in the future test plan.
  • Finally, the fourth one is related to the fact that the 3 values of the categorical parameter are not independent since they belong to the same treatment (i.e. weld). Subsequently, a split-plot design [4-Ch.10] with parameters hard or easy to change has to be considered.
Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements.Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements. Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements. Figure 5 – Building of the custom design of experiments – The Custom Design platform allows the creation of a completely customized test plan. The Responses part provides the list of responses to be optimized, in this case the goal is to look for the maximum strength. The Factors part presents the way how the four constraints have been addressed. As the position is uncontrolled, no values are input into the limits. The Model part displays all the factors and interactions considered in the model. RSM (Response Surface Methodology) is used, the interactions between the laser power, the welding speed and the side have been removed as they have been considered not significant. Finally, the Design Generation part proposes 8 trials and 24 measurements.
The creation of the custom design of experiments is explained in [ Figure 5 .] A total of 8 tests and 24 measurements is lastly considered. The test plan is executed and for each triplet (P, V, Side) the following data are recorded: the position of the weld (in mm, from one end of the plate), the value of the strength (in absolute and in percent of the base material strength). The strength of the welds is then modeled using the Fit Model platform [ Figure 6 .]
Figure 6 – Building of the custom design of experiments –  The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists).Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists). Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists). Figure 6 – Building of the custom design of experiments – The results are presented into a dashboard. The irregular shape of the weldability lobe is reminded in the top right chart. The experimental points, proposed by the Custom Design platform, and the associated strength values, in percent, are summarized in the bottom right chart. Finally, the Fit Model platform on the left displays the modeling result. An explicative power R2 of 96% has been reached, meaning that only 4% of the variations escape its predictive power. The Effect Summary shows that the main effects (laser power, welding speed and position) are significant. The side factor is not directly significant, but becomes so when associated with the position. The VIFs (Variance Inflation Factors, not displayed here) have all a value smaller than 1.6, showing no multicolinearity issue (no linear relationship among two or more explanatory variables exists).
The resulting model being of good quality, it can be used in prediction. After correcting for the effects of weld position and sides, the trends attributable to laser power and traveling speed are clearly visible in the Prediction Profiler [ Figure 7 .] Figure 7 – Checking the model's behavior with the Profiler –  The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases.Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. Figure 7 – Checking the model's behavior with the Profiler – The upper profiler refers to low position values, the lower to high position values. The model response (strength in %) is shown on the y- axis, the factors on the x-axis. Weld after weld (increasing position), the strengthes on the DS and C sides remain mostly unchanged while the strength on the OS side changes dramatically, as observed visually. This phenomenon being well modeled, it is now possible to access the pure effects of laser power and welding speed. The weld strength increases when the laser power decreases and the traveling speed increases. For the considered material, there does not seem to be any interaction between the laser power and the welding speed. The weld strength therefore increases with the travelling speed and when the laser power decreases.
However, that being said, the work is not over yet. The limits of the weldability lobe must also be carefully considered in the search for an optimum. On the basis of the Prediction Profiler alone, this is not easy, so it is the Contour Profiler's turn to play!
The use of the Contour Profiler allows to superimpose the iso-resistance curves from the strength model with the weldability lobe [ Figure 8 .] Finding the optimal point requires locating a point that is not only within the weldability lobe but that also has the highest strength.
Figure 8 – Optimization with the Contour Profiler –  The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph.Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph. Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph. Figure 8 – Optimization with the Contour Profiler – The Contour Profiler displays the welding speed on the x-axis and the laser power on the y-axis, with the position and side values fixed. Arbitrarily, the side value was set to DS. As for the position, it was set to the latter. The weldability lobe where the weld bead is free of defects was reproduced in black using a script and the polygon drawing function.The iso-resistance curves of the model, in red, are also plotted. The associated resistance percentages are also displayed in red. The welding speed and laser power sliders are set to the coordinates of the optimal point, materialized by the black cross in the center of the graph.
If we add to this the fact that the welding speed should be as fast as possible for a maximum productivity, the coordinate spot (11 mpm, 6kW) proves to be ideal. Not only does it meet all the above criteria, but it also offers a satisfactory safety margin for an industrial process.
Of course, these settings have been tested. The results are presented [ Figure 9 and Figure 10 .] In summary, the weld seam has a defect-free surface with a strength across the entire width comparable to that of the base material. The objective has been achieved!
Figure 9 – Optimum preset and weld seam appearance –  The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects.Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 9 – Optimum preset and weld seam appearance – The figure shows the upper (left) and lower (right) weld bead facies. The latter are free of the main welding defects. Figure 10 – Optimum preset and weld strength –  The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one.Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one. Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one. Figure 10 – Optimum preset and weld strength – The figure shows the results of the 3 Erichsen-type cupping tests performed on the DS, C and OS sides. Visually, it can be seen that it is the material that breaks and not the weld. Moreover, all the tests show a strength level comparable to the base material one.
5. Conclusion
Finding the optimal laser welding parameters for a given material is not easy. Fortunately, JMP offers a suite of platforms that, in one combined, provide a rigorous approach to achieving our goal.
The use of the Graph Builder, Personal Map Shape and Dashboards allowed us to visually organize our data both in terms of welding defects (welding flaws map, weldability lobe) and strength (Erichsen-type cupping tests).
The ANOVA and Distribution platforms were used to make informed decisions about the equivalence of the plates to be processed and their level of strength.
Once the weldability zone was determined (zone where the weld beads are free of defects), the strength of the weld bead was studied using the design of experiments methodology. In this paper, only 2 parameters were considered (laser power, welding speed).
The Custom Design platform allowed for a high degree of customization of the tests in relation to the encountered constraints. The highly irregular shape of the study area gave the opportunity to use the candidate point method (covariates), in addition to other features such as split-plot design and uncontrolled factors.
The modeling of the weld strength via the Fit Model platform allowed not only to understand the involved physical phenomena but also to proceed to a multi-criteria optimization via the Contour Profiler. Finally, the objective was achieved since all the steps allowed to propose and validate a set point with a maximum productivity and a good weld, both defect-free and resistant.
This step is part of an extensive, very high-value data acquisition program that will allow, just as it did in 2019 with the laser cutting process, the development of a laser welding model that will provide robust welding instructions, regardless of the incoming product, the final step to fully automate the machine.
6. About Clecim SAS
Clecim SAS, based in Montbrison (Loire), joined the Mutares group on April 1, 2021. It is an engineering and production company, bringing its expertise in services and manufacturing in particular for the metallurgical industry. Its main activity is the operational support of the performance of its flat steel producer customers, in particular for the automotive market. This support takes the form of studies and advice on the improvement of their production tools, the supply of special machines to optimize performance and, if necessary, the supply of complete production lines based on the latest technologies.
For decades, Clecim SAS has been promoting innovation in the steel industry and is constantly looking for new solutions to provide metal producers with state-of-the-art equipment, allowing them to gain a competitive advantage. Our latest areas of focus include new technologically differentiated solutions, advanced process analysis and optimization. Of particular note in this area are world-renowned high-level solutions such as special laser welding machines, surface inspection systems, rolling equipment, and galvanizing lines for flat steel for the automotive market.
With its own factory, Clecim SAS is able to manufacture and test complete machines. The company has many skills (engineering, manufacturing, testing) allowing it to master the entire value chain. Clecim SAS can also provide its customers with a pilot rolling mill for the development and confirmation of flattening, rolling and tribology models.
Figure 11 – Clecim SAS (Montbrison city, France)Figure 11 – Clecim SAS (Montbrison city, France) Figure 11 – Clecim SAS (Montbrison city, France) Figure 11 – Clecim SAS (Montbrison city, France)
About the author
Stéphane Georges.png Graduated from Grenoble INP in Materials Science and Process Engineering, Stéphane GEORGES (47y) joined Clecim SAS in 2001. After holding several positions in the Automation, Modeling and Process Control department, and after 3 years of expatriation in Erlangen at Siemens in Germany, Stéphane moved to the position of R&D Project Manager. His various missions related to industrial processes lead him to use his skills in smart experimentation, statistical analysis and modeling, coding, machine learning and deep learning to make the most of data.
Acknowledgment
We would like to express our thanks and gratitude to Florence Kussener of JMP for her support in using the software and preparing us for our first ever participation in the Discovery Summit.
References
[1] André Augé, JMP Addict: Tips and Tricks Workshop: Customize Your Reports and Chart Builder Tips, Webinar, 2021, shorturl.at/jqAZ2
[2] Lekivetz Ryan, What is a covariate in design of experiments, article, JMP Community, 2021, shorturl.at/hqvH4
[3] Lekivetz Ryan, Developer Tutorial - Handling Covariates Effectively when Designing Experiments, webinar, JMP Community, 2021, shorturl.at/fvEZ0
[4] Peter Goos, Bradley Jones, Optimal Design of Experiments: A Case Study Approach, Wiley, 2011
CLECIM ® is an internationally registered trademark owned by company Clecim SAS.
Clecim SAS all rights reserved 2022-feb-02
