Anudeep Maripi, Magic Leap
This paper presents how Magic Leap’s Eyepiece Manufacturing team leverages the changepoint detection and correlation matrix functions in the multivariate control charts to easily detect process drift, diagnose issues, and detect the exact moment when an issue occurred -- a previously impossible functionality. Magic Leap’s lithography double-side imprinting process requires precise wafer placement, highly accurate photoresist dispension, and master-template to wafer alignment. Process drifts such as robot wafer placement errors, wafer alignment variation, master-template alignment errors, and measurement metrology variability can cause excursions that result in significant yield loss. These process drifts are often subtle, gradual and interdependent on other parameters that traditional control charts fail to detect.
Our team used changepoint detection and correlation matrix to create an interactive dashboard that collects changepoint time stamps for output parameters and creates a phase in the existing control charts for input parameters. Multiple changepoints are handled using phase columns and correlations with input parameters, template changeovers, and PM or hardware upgrade activities. The dashboard’s correlation coefficient matrix between inputs and outputs compares the correlation before and after a detected changepoint. This dashboard became our daily driver to quickly find faults/process drifts and achieve high yield standards.
Hello, everyone. This is Anudeep Maripi.
I'm a senior process engineer for optics lithography at Magic Leap.
Today, I'm going to demonstrate
fault detection by upgrading control charts
with change point detection in JMP,
and show you how the change point detection integration
with control charts
is highly useful on our manufacturing shop floor.
I'll start the presentation
with a brief introduction about our company, Magic Leap,
and the optics manufacturing,
the DMAIC problem- solving approach
and the JMP tools that we use in the manufacturing,
our challenges that we face in the control phase of DMAIC,
upgrading existing control charts with change point,
and by doing so, detecting and diagnosing the faults in a process
some case studies that we regularly use at Magic Leap and a JMP demonstration
on how to create a change point dashboard
and integrate change point into your control charts,
and few takeaways.
To start with, at Magic Leap,
we envision a world with physical and digital are one.
Our mission is to amplify human potential
by delivering a most immersive AR wearable platform,
so people can intuitively see, hear,
and touch digital content in the physical world.
Our wearable device transforms enterprise productivity
by providing AR solutions.
For example, collaboration and co- presence
between remote teams to work together as if they are in the same room,
3D visualizations to optimize processes,
augmented workforce that helps train and upskill workers
using see- what- I- see capability.
These are only a few examples.
The device has industry's leading optics with large field of view,
best image quality,
high color uniformity,
and dynamic dimming
which helps display a high- quality virtual content
in our real world.
The optical lens that is used in this device
is a small component
but a very critical component of Magic Leap 2,
enabling best- in- class image performance.
The optical lens goes through 25 plus complex
manufacturing process and metrology stations
during the manufacturing.
It is tested over 100 plus critical- to- quality parameters.
Each individual process needs to reach high 99% yield targets
to attain 90% Rolled Throughput Yield targets.
We cannot achieve these high yields and process capability
without the help of JMP statistic tools.
One of these high- yielding processes is imprint lithography
where I' m responsible for quality and delivery tools.
This process has many steps,
and that is visualized on the right- hand side of your…
The first step is where we align the mask to the template
and then dispense fo r resist,
lower the template and EUV cure to replicate the exact pattern
from the mask template to the wafer.
This imprint process alone has 22 critical- to- quality parameters
that operates between tight control limits such as just 20 nanometers film thickness
and 100 microns drop accuracy.
As you could see, these tolerances are extremely small.
For reference, human hair is just 20 microns to 100 microns.
Thus, the imprint lithography requires a precision placement and alignment
that are indistinguishable to the human eye.
Meaning we rely a lot upon onboard metrology and vision systems
that generate tons of data from large numbers of input parameters.
JMP helps us to easily analyze these large data sets
in our problem- solving processes.
We use DMAIC approach in our problem- solving process.
Following are the JMP tools
that we use in every phase of our DMAIC processors, respectively.
Like many manufacturing teams,
we found out Control phase as most challenging and overlooked phase,
because at a start up like Magic Leap, we continuously evolve, make improvements,
and iterate several new designs and revisions.
The control phase is overlooked
because it takes longer time for the confirmation.
For example,
we find a problem or an issue, say like process exceeded control limits
and giving low CPK values,
resulting in low CPK during our Control phase.
We define the problem,
we measure the historical data,
analyze the problem
by multivariate methods and correlation matrices,
improve the problem by implementing the corrective actions,
by conducting DOEs and response screening.
But once this is resolved,
we move on to our next severe problem and move on to severity 3 problem
once you resolve the severity, severity 2 problem,
and the cycle continues,
overlooking the most important phase of DMAIC,
which is the control phase.
This was the reason we came up with the change point detection dashboard,
which is fast and efficient.
It pinpoints issues faster, easier to visualize faults and changes.
Even operators who are not proficient with the statistics
can use this dashboard to diagnose the issues.
For example, before introducing this change point dashboard
on our manufacturing shop floor,
the escalation progress is like the left sideway,
where the operator monitors the yield dashboard
and identifies the yield losses and faults.
Operator reports to technician to look into the faults.
If technician unable to resolve escalates the engineer,
engineer analyzes the control charts data using control charts alarms and trends,
and then manually join these outputs to inputs and do the correlation
and find out and diagnose the fault.
And then engineer implements the corrective actions.
But after introducing our change point dashboard
on the manufacturing floor,
the operator, technician, and engineers
monitor the change point dashboard on the shop floor.
If change is found,
they look into correlation of inputs before the change and after the change
and easily diagnose the issue,
and then easily improve the corrective actions.
This helped us easily to transition into our TPM model,
where operators, technicians and engineers
are all coming together to minimize the faults.
The change point dashboard makes our control phase very efficient.
I'm going to demonstrate in the following slides
on how this is efficient
as well as how to make this change point dashboards.
Before showing the change point dashboard,
I want to show you our journey from traditional control charts monitoring
to change point detection dashboard.
While the traditional control charts are very helpful to monitor excursions
in our process using Westgard rules,
they show the immediate out of control points,
but they often miss the subtle drifts in the process,
which are very gradual but still significant.
These control charts are very helpful to monitor the time based
and also give us what parts are impacted by this.
But as I mentioned before,
we have 22 critical parameters in this process alone
and there are tons of input parameters
that impacts these 22 critical parameters,
which means we need to have many control charts monitoring,
at the same time, to have a stable process.
But then we move on to model- driven multi variate control charts.
These control charts, we monitor both inputs and outputs together,
and we immediately get a correlation between them.
But unfortunately, these doesn't have any time series or port IDs
to help and deploy this in the manufacturing shop floor.
The multivariate correlation is very important for us,
giving the relationship
between our outputs and inputs in the process.
And this again doesn't have the time series data
like the control charts to identify when the issue has started.
The change point detection, whereas we found very helpful
to easily detect when that fault or change
or significant abrupt drift happened in our process.
But it only gives a value when a change point occurred,
it doesn't have the time series and not very valuable
as a monitoring tool on our manufacturing shop floor.
Each one has its own disadvantages and advantages.
We combine all of these control charts into one dashboard
and leveraging the control point detection functions values into these.
Our next logical step is regression which is cause and effect analysis.
Find out the cause and effect and interlock the tool inputs,
stopping the failure on your CTQs critical- to- quality parameters
or on your outputs
and also move to prediction analysis.
This is one example to show you how the control charts looks different
when you integrate the change point detection.
For example, on the left, I have a control chart
without the change point detection.
You can see there are few ups and downs between the control limits.
But when I take this value of 256,
which the change point detection gives you when you run for the same data,
and take this and integrate into the same control chart,
you could see the visualization got better.
In this case, before the change point, you have a demo of variation,
you have a baseline,
you have the mean is below your target line,
and after the change point, your mean is above the target line now
and your variation has reduced.
In this way, you could easily find out and visualize
what is the change in your existing control charts.
Once we found out how valuable this change point is,
quickly telling us where the change happened
or where the fault happened in your process.
We started using some use cases.
We started with some use cases such as this
where we introduced a change and we want to validate the change.
In this example, we have a process where it is giving low Cpk value
because of the population is mostly distributed towards your positive side.
We identified it as a mean shift.
It needs to mean shift, and we introduced the known change mean shift.
When we introduced this mean shift,
you could see the process became more capable,
about 2.3 or 1.5.
You could see when we deploy the change point detection function
for the same data,
the change point gives you value and the direction
whether your change has taken place or not in your process.
This is highly visual for us
to evaluate whether my known change, which I just introduced,
is impacting my process, the positive or negative.
The second use cases, as I mentioned,
we have lot of onboard metrology tools in our process,
which is giving a lot of data.
We do periodical measurements and testing in these metrology tools,
but we always rely upon
the repeatability and reproducibility data,
which is Gase R&R data
from these charts.
But the Gase R&R data is not finding us any faults in the process
or when the metrologist tools started drifting
in either positive or negative.
But for the same data,
when we deployed the change point function,
it immediately tells us when the subtle changes
and abrupt significant drifts happened in this metrology, too.
That is very high or highly helpful data to identify
and make sure our metrologist tools are still stable and not drifting the data.
The third and most important one
is to detect and diagnose the faults with ease.
This is a dashboard that we worked on to deploy on our manufacturing shop floor.
Our workflow would be, we monitor multiple response parameters
or critical- to- quality parameters as outputs,
and then we identify if there are any changes
using the change point dashboard.
At the same time,
we also look into model- driven multivariate change point dashboard
where it will tell us what are the excursions
and easily correlate that excursions to the input parameters.
But the true value came in
when we take this change point values
and integrate them into our existing control charts.
In this example, we have a baseline data before the change and after the change,
which means when the fault occurred, you could see there is a slight mean shift
and there's a huge variation in our process.
At this point, we go to our correlation matrix.
It is correlating our output parameters to our input parameters in the process.
The correlation matrix will immediately tell you
which factor has a strong positive or a negative correlation
during this phase when compared to during your normal phase.
That will immediately tell you what input parameter has gone wrong
or that might have contributed a lot to this fault area.
That is how we are able to quickly find the faults and diagnose the issues.
From here on, I'm going to demonstrate in JMP
on how to create these kind of dashboards,
at the same time, how to create multiple change points.
As you could see in our previous slides,
the change point function is giving only one value.
Let me turn on to JMP.
In this example, I'm using Boston Housing data which is from 1978.
This is one good example as a beginner learner
for correlation and regression.
Many tutorials use this example.
So I thought I could use this example which is readily available.
Everybody's JMP sample data sets and see how the correlation is,
and if there are any multiple change points in the data,
at the same time, correlate to the practice.
The sample data table looks like this.
In our case,
I want to see the median market value or median prices
of the owner-occupied homes in Boston and see how it is variating with time.
At the same time, there are corresponding factors
like what is the crime rate in the town or what's the pollution rate in the town
or the age of other factors such as age of the homes
or dis tance in these regions.
You can read the data about these column names
in the column notes that is presented over here.
I'm going to run the script which gives us…
Before running the script, I also want to tell you
that I'm attaching the entire script as part of my presentation,
where you could go through the script or run the script
and it will give you a nice dashboard about Boston Housing values variation
and also a correlation.
You could download the script and look into my score
and you could use the same methodology and the logic
on how I'm able to detect multiple change points
from the dashboard using the JS Subscript.
When I run the script,
runs and I get a nice dashboard like this.
As I mentioned,
our problem- solving framework would be like look at the change points
in our median value of the homes in Boston.
You could see it gave us the median value that there are a big change here
and it tells you the change point appears to be on row 373,
and also there are several second of small change.
When you look at the model- driven control chart data,
you could see there are high excursions
in this medium value of the housing markets.
You could easily tell what caused this excursion
by looking into your inputs parameter, that is crime rate.
You could hover on any of these and find out what is impacting
these huge excursions
in your monitoring variable, which is median value of the houses.
As I mentioned, the real value comes out when we take these
and integrate into our control charts.
See this one, this control chart will give you
these integrated change points from here.
We'll give you a good visual.
You could see now in Boston Housing market example,
we have a baseline housing median value changes,
a baseline value at 20 million.
And then when the housing boom happened, or when the change point 1 occurred,
you could see there is a good amount of variation in the housing market.
At the same time, there is a mean shift, too.
But soon, there is another change happen and the housing market crash
resulting in your median value is below your baseline.
This is easily telling us, giving us a visual into parts
where what is the baseline data, when the first change occurred,
what is and how much is the change?
The second change occurred and how much is the change now.
You can compare with your previous two changes.
If you as a prospect to homebuyer in Boston
and you're looking into this kind of data,
you want to know what might have happened that have impacted these kinds of changes.
In your data set, you have some nice factors
about the crime zone,
the crime rate in that same area in the same period of time,
and the pollution rates, et cetera.
If you look at our before change
you could see the market value, how it is correlating with your factors.
In this case, you can see there's a good amount of negative correlation
with the crime
and the negative correlation with the industry area and also pollution.
And there is a strong positive correlation which is about 0.8 with this phase.
Now, look at the second change point 1 phase
where the housing boom occurred [inaudible 00:22:46] mean shifted upwards.
You could see in this time frame
your crime rate is low or no correlation with these changes.
Your pollution is low again,
but your rooms still same strong positive correlation in these two phases.
If you ask me what would have happened this time,
I would say maybe the crime has increased in the area
or the pollution has increased in the area,
such kind of dominant factors that are visible ,
that are not favorable for a prospective home.
That's going on to the housing crash when it happened.
A comparison between this phase to this phase,
change point to see how the correlation just changed.
You can immediately tell, "Okay, my comparison
with the median market value from this phase,
my correlation with the client is pretty low,
my rooms has very positive correlation,
and there is lstat and other factors."
But if you come to the change point 2 time,
you could see the crime rate has increased again,
your pollution has increased again,
which resulted in the negative linear correlation of this change.
When you look at your rooms,
which has been positively contributing for your change has fell down completely.
In this way, this is telling you a lot of information data about these changes
that occurred in 1978.
Also, easy correlationship data with your factors
that might have impacted these changes.
I'll repeat.
Our framework is detecting, for any time series data,
we first detect number of changes,
if it is one change or two change or more changes,
and then integrate these change points
into our control chart to get a better visualization about the changes.
Is it a mean shift or variation shift, or what is happening?
And then look into your factors that might have contributed to these changes
and see what factors a strong contribution for this change
or weak contribution or no contribution or negative contribution.
Now that you know the crime rate, your market value
—the median market value is impacted by the crime rate,
pollution, and the rooms—
let's look at a simple visualization.
When you go here, you can see this is a simple graph plot.
I'm taking my change point and visualizing it in a better way.
I'm comparing my median value
with the nox, the pollution value in the same towns,
in the same time period and the rooms and the crime rate.
You could see when my housing median market values increase
or the housing booming phase,
you could see the pollution is very low and the rooms for dwelling has increased
and your crime rate is at least possible state.
As a prospective homebuyer,
these are all favorable factors for me,
no pollution area, no crime area or safe area,
and then I'm getting a bigger home with a convenient number of rooms.
But let's see, in this phase, when the housing market crashed,
at the same time, your pollution rate has increased.
The number of rooms for dwelling has decreased.
And then there's an astronomically high crime rate
which is impacting the same thing.
This is a clear visual,
but you landed up in this problem or with this kind of conclusion
with the help of your correlation matrices.
Correlation matrix and then a change point.
Your correlation matrix and then the change point
and then a better resolution like this.
Let me go and show you
how the JSL script is pooling multiple change points.
You could find the change point data
in your control charts, multivariate control charts.
And again, this is a multi variate control chart.
You could use as many as variables
as your multivariate control chart input parameters.
But in my case, I'm using median market value,
and I get a multivariate correlation and a change point.
Clearly, see, it gives me 373 as a number.
How I am taking or extracting this 373 number
is using this kind of JMP or JSL can extract any of the text box columns
from any of your reports and then put it into your data table.
In this case, I collected this data point.
You could see the equation 1 holds the phrase call or the text box call.
The change point appears to be 373.
This one simple code will hold or extract that value from the report.
And then I take that into my columns
in the change point 1 column,
and I extract the numerical value out of it.
I wrote the JSL as simple as possible.
I'm very beginner with scripting and coding.
You could see I used simple formulas and simple methods to get this.
You can see the change point report is only giving you
one change point value.
But you could see in your process, there are other changes, too,
that you might be interested in and we want to find them out.
What I do is once you get your first value,
you hide and exclude everything after your change point.
After this 373, you exclude everything.
Now you're left with this phase.
You want to see what is my change in this phase,
and the cycle continues.
For example, in my equation 2 from my report 2,
I'm pulling the text box phrase called the change point.
Sorry, this is hard to show.
When you hover on this,
you can see that variable has the phrase [inaudible 00:29:49].
Variable has the phase of the change point appears at row 157.
You take the value and then put it in your column call,
CP Text, something like that,
where you could extract your second change point.
Once you get a data like that,
it is very easy to construct a dashboard like this,
where you create your control chart dashboard,
each individual components, model- driven multivariate control chart,
and create the dashboard using the new dashboard application.
Once you create a nice dashboard like this,
you just go here and you just take everything into the script.
I'm switching down to my presentation.
I hope the Boston Housing data example is very clear,
because how easily you can detect changes in any time series data
and correlate those with your input parameters.
In real life or manufacturing scenario,
you would have several input parameters like this.
In this case, in my dashboard,
we look into around 50 input parameters comparing with our output parameters.
We also monitor the multivariate control charge.
You could see I'm monitoring multiple CTQs together
instead of each individual traditional control chart.
I'm exporting these values into my existing control chart
and then immediately diagnosing my faults.
This dashboard, as you can see, it's pretty self- explanatory,
easy to read, easy to deploy on your manufacturing floor.
Technicians even not comfortable with statistical analysis,
and doing this kind of building control charts and everything,
they'll just look at the process saying that,
"O kay, I have two changes in my process,
and let me see what are the input parameters
that are correlating these changes and see if I can change them
or manipulate them so that my process back to stable state like this.
Again, the correlation coefficients are pretty easy to explain to anyone
on the manufacturing shop floor.
For example, a strong positive correlation would give you a blue number closer to 1,
or a strong negative correlation would be something like -0.7,
but the variation would be something like this
when you increase something.
With subtle bit of variation,
you would see a negative correlation there,
and then a weak negative correlation would be something like this,
a lot of variation instead of a straight line like this.
And then there's no correlation.
The number would be pretty much close to 0.
You would see,
even if you increase one, the other might be decreasing.
It is very easy to explain.
It is very visual on the manufacturing shop floor
to find out these kind of numbers,
looking to see what input has changed and what input has a strong correlation.
There is an added bonus with the change point integration.
As you can see, these are all numerical data,
which is getting a numerical correlation like this.
But the change point is telling you when the fault has occurred
and when you know when the fault has occurred,
you just look into your data such as template change or your load port IDs,
and you will get a correlation with your non- numerical data [inaudible 00:34:10] .
You would start a discussion on your manufacturing floor.
Hey, when this time occurred, I did this change over PM
or the tool is setting idle,
or I did a prevent day to maintenance at this exact time.
Maybe that prevent day to maintenance time,
some issue has occurred.
This is giving you a full picture.
You're looking into tons of 50 plus input parameters
and easily getting a correlation with your CTQs
and easily detecting the faults.
At the same time, you have non- numerical data such as like this,
and you find out and you relate to like,
what was I doing when this change or fault has occurred in my process?
The final takeaway
is by integrating change point function to our existing control charts.
We're quickly finding faults and diagnosing them faster,
saving millions of dollars in our fast- paced manufacturing.
With JSL scripting,
we're able to find out there are multiple change points in our process
and integrate them to our control chart dashboards.
This change point and multivariate methods can be used in any time series,
as I was mentioning.
For example, when I'm preparing for this presentation,
I gave a small set of our monthly savings data set to my wife
who is not familiar with statistics and control charts.
Upon tracking this dashboard,
my wife easily found there are change points in our savings.
But at the same time, she did not like the fact
that when the dashboard pointed out that our Amazon spending
is well correlating for our low saving months.
As you can see, like this time, this change point,
you could use it on any time series data.
You could find out your changes in your time series
and when the change has occurred
or when the significant change has occurred,
and then you can correlate to your input parameters.
In our case, we are just correlating your Amazon spending or take- out dinners
and several other factors [inaudible 00:36:18] .
That's pretty much, and I hope you found this presentation very useful,
and you also learned how you can easily find multiple change points
through JSL scripting and create easy dashboards
to where demonstrators
to find out faults and easily diagnose them.
Thank you.
0 Comments
Published on ‎05-20-2024 07:53 AM by | Updated on ‎07-23-2025 11:13 AM
with control charts
and few takeaways.
best image quality,
and dynamic dimming
in our real world.
For example,
analyze the problem
If change is found,
or on your outputs
about 2.3 or 1.5.
for the same data,
from these charts.
At the same time,
In our case,
As I mentioned,
with the crime
I'll repeat.
You would see,
The final takeaway
With JSL scripting,
Thank you.
