Welcome to the JMP User Community!
Ask questions, get answers, meet other JMP usersLearning Resources
Find courses, tutorials, and lots of other methods of learning JMP.
view all learning resourcesLatest Discussions
Do you use lag(x)?
... seems that this is no longer possible: tested with JMP18.1.1 JMP17:
hogi70 views | 2 replies -
How Can I Get The Lag Function to "Reset" With Each New Batch?
Hello, I have the following data and I want to use the Lag function to calculate the difference between each result and the result prior to it (the da...
jeff_gross99 views | 3 replies -
How to have 2 labels on the graph?
How can I display 2 labels on a graph? There are so many formatting options for the Y-axis variable labels, but if I added a categorical or numerical ...
Waferswafers88 views | 2 replies -
associate a symbol type to a dot color
Hi all, this might be extremely trivial but would really appreciate the help. I am trying to plot ( in graph builder) a dot plot , where i have the sy...
JMPBeginer94 views | 3 replies -
fossile - solar - wind
It almost looks like art - but it is data !
hogi
from: Fraunhofer ISE: solar / wind / fossile energy generation in Germany per bin of 15 mit to several hou...102 views | 3 replies
Latest Discussions
Do you use lag(x)?
hogi
Latest Discussions
Exceptions are the utilities Show, Write, and Print ...
from: https://www.jmp.com/support/help/en/18.1/?os=win&source=application#page/jmp/advanced-expressions-macros-and-lists.shtml# If you assign the exp...
hogi73 views | 0 replies -
Extract Expr: Issue with scoped variable
This works:
hogiExtract Expr(:height << set name( "new" ), :height );
But this one doesn't *):Extract Expr(myDataTable:height << set name( "new" ), myDat
...69 views | 0 replies -
A custom function evaluates the return value
fyi While debugging @replace Head, I noticed that a custom function evaluates the return values +1x compared to a standard function:
hogimyFunction = funct
...97 views | 0 replies -
txt import - point and comma ?
MultiFileImport (MFI())
hogi
independent of the settings in the operating system and the settings in the preferences,
text files with point as decimal separ...159 views | 0 replies
JMP Events
EuropeBerlin 11-13 March
1:00PM - 2:00PM ESTJan 17Getting Started with JMP
New JMP users will learn how to: Easily navigate JMP using the JMP Starter. Import all types o...
12:00PM - 1:00PM ESTJan 23Resources for Teaching with JMP
REGISTER HERE: https://www.jmp.com/en_us/events/live-webinars/academic/teaching-resources-23jan2025....
2:00PM - 3:00PM ESTJan 24Designing Process Optimization Experiments Using Models Based on Production Data
Do you have historical or real time production data? Have you wondered how to leverage these data to...
1:00PM - 2:00PM ESTJan 31Getting Started with JMP
