hogi
Level XIII
Do you use lag(x)?
... seems that this is no longer possible:
tested with JMP18.1.1
JMP17:
hogi
Level XIII
Re: Do you use lag(x)?
The good thing:
It's not a general issue of "Lag"
... it seems to be caused by:
When I generate the Formula this way, the entries are empty.
When I create a new column and add the formula afterwards, the values are calculated.
added: video with different ways to generate the formula column
  1. new formula column: add lag via click      -> fail
  2. new formula column: add lag manually    ->  fail
  3. new formula column: delete code and write again    -> fail
  4. new column -> add formula manually -> works
  5. new column -> add formula column via click and write (like #2) -> works
(view in My Videos)
Seems like JMP will incorrectly evaluate the "missing" argument to Empty()
// Transform column
Data Table("Big Class") << Apply Formula(
	Columns(:weight),
	Formula(Lag(:weight, Empty())),
	Output(New Formula)
If you use Lag under Row this doesn't happen as it uses other method to create the column
// New formula column: Lag[weight]
Data Table("Big Class") << New Formula Column(
	Operation(Category("Row"), "Lag"),
	Columns(:weight)
Edit: And it does happen with other functions too (at least with Dif but there could be other)
// Transform column
	Columns(:weight),
	Formula(Dif(:weight, Empty())),
	Output(New Formula)
6 REPLIES 6
Jeff_Perkinson
Seems to work fine in all the versions I tried, including 18.1.1.
-Jeff
hogi
Level XIII
Ok, good.
And kind of strange ...
So, it's neither 100% gone - nor 100% working.
what makes the difference ?
PC vs. Mac?
... I will check my preferences - and compare with more colleagues.
hogi
Level XIII
The good thing:
(view in My Videos)
hogi
Level XIII
I submitted a ticket to JMP support: TS-00182750
let's see ...
// Transform column
	Columns(:weight),
	Output(New Formula)
	Columns(:weight)
// Transform column
	Columns(:weight),
	Output(New Formula)
hogi
Level XIII
Good point, thanks @jthi for digging deeper.
I never paid attention and noticed the 2 ways formula editor displays optional arguments:
  1. explicit:
  2. not [just in the description]:
