The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
View Original Published Thread
Craige_Hales
JMP's Recent File List (Windows)
This example uses Run Program to read the windows registry to get the files in JMP's recent file list.
temp=runprogram(executable("reg"),options({"query","\["HKCU\Software\SAS Institute Inc.\JMP\Recent\Files"]\"}),readfunction("text"));
names = {};
// typical line: "    File7    REG_SZ    C:\Users\v1\Desktop\Nanami01.jrn"
patmatch(temp,patrepeat(patregex("\s+File\d+\s+REG_SZ\s+")+patbreak("\!n\!r")>>path+pattest(insertinto(names,path);1)));
show(names,nitems(names))
names = {"F:\FileSnapper\Additional.jsl", "F:\FileSnapper\makeAddin.jsl", "F:\rectangula\virusmap3.jsl", "F:\rectangula\virusmap2.jsl", "F:\turtle\drawing.jmpprj", "F:\AVI\video.jmpprj", "C:\Users\v1\Desktop\Nanami01.jrn", "F:\chess\chessPlay.jsl", ...
The patmatch function skips over leading, non-matching text, then adds files to names as long as the pattern repeats. If the registry contained some other values (I don't know why it would) you might have to make the pattern more sophisticated to skip unknown keys and continue.
Running the reg query command in a command window looks like this
readfunction("text") returns that same text to the temp variable.
Comments
MathStatChem
Level VII
Well that is very cool and compact.  I could see this being useful in building a custom dialog for file selection.
Craige_Hales
Thanks! It is simpler than another approach I tried that was more fragile.
I also looked at  @Phil_Kay which got me close to similar information, but for .LNK files that, somehow, point to the actual files. In my case I need the path to the target file, and I don't know how to get the path from a .LNK using JSL.
