Naohiro Masukawa
%3CLINGO-SUB%20id%3D%22lingo-sub-824127%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3EUna%20nueva%20perspectiva%20sobre%20el%20an%C3%A1lisis%20de%20disparidad%3A%20interpretaci%C3%B3n%20del%20sesgo%20en%20el%20n%C3%BAmero%20de%20jonrones%20de%20la%20MLB%20utilizando%20el%20coeficiente%20de%20Gini%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-824127%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20size%3D%224%22%3EEn%20este%20blog%20explicaremos%20la%20%22curva%20de%20Lorenz%22%20y%20el%20%22coeficiente%20de%20Gini%22%2C%20que%20se%20utilizan%20para%20analizar%20las%20disparidades%20en%20el%20ingreso%20y%20el%20ahorro%20en%20los%20campos%20econ%C3%B3mico%20y%20social.%20Adem%C3%A1s%2C%20para%20analizar%20el%20sesgo%20en%20el%20n%C3%BAmero%20de%20jonrones%20de%20cada%20equipo%20de%20la%20MLB%20(Major%20League%20Baseball)%2C%20presentaremos%20un%20ejemplo%20del%20uso%20de%20JMP%20para%20visualizarlo%20usando%20una%20curva%20de%20Lorenz%20y%20cuantific%C3%A1ndolo%20usando%20el%20coeficiente%20de%20Gini.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%225%22%20color%3D%22%23FF6600%22%3EIndicadores%20para%20medir%20la%20desigualdad%3A%20coeficiente%20de%20Gini%20y%20curva%20de%20Lorentz%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEl%20%60%60%20%3CFONT%20color%3D%22%23FF0000%22%3Ecoeficiente%20de%20Gini%3C%2FFONT%3E%20''%20es%20un%20indicador%20bien%20conocido%20para%20cuantificar%20el%20sesgo%20y%20la%20desigualdad%20de%20los%20datos.%20La%20%22%20%3CFONT%20color%3D%22%23FF0000%22%3Ecurva%20de%20Lorentz%3C%2FFONT%3E%20%22%20se%20utiliza%20para%20expresar%20visualmente%20esta%20desigualdad.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEl%20coeficiente%20de%20Gini%20tambi%C3%A9n%20se%20denomina%20%22%20%3CSTRONG%3E%C3%ADndice%20de%20desigualdad%3C%2FSTRONG%3E%20%22%20y%20se%20utiliza%20para%20indicar%20el%20grado%20de%20disparidad%20en%20diversos%20campos%2C%20como%20la%20disparidad%20de%20ingresos%20y%20la%20disparidad%20educativa.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3ELa%20siguiente%20figura%20es%20una%20curva%20de%20Lorenz%20(azul)%20que%20visualiza%20la%20disparidad%20de%20ingresos%20de%20los%20hogares.%20El%20eje%20horizontal%20muestra%20la%20participaci%C3%B3n%20acumulada%20de%20los%20hogares%20y%20el%20eje%20vertical%20muestra%20la%20participaci%C3%B3n%20acumulada%20del%20ingreso.%3C%2FFONT%3E%3CFONT%20size%3D%224%22%3EEn%20el%20caso%20de%20igualdad%20y%20ausencia%20de%20disparidad%20de%20ingresos%2C%20la%20curva%20de%20Lorentz%20coincide%20con%20la%20l%C3%ADnea%20de%20puntos%20de%2045%20grados%20(llamada%20%60%60%20%3CSTRONG%3El%C3%ADnea%20de%20igualdad%20perfecta%3C%2FSTRONG%3E%20'').%20Por%20otro%20lado%2C%20cuando%20la%20disparidad%20de%20ingresos%20es%20grande%2C%20es%20decir%2C%20hay%20desigualdad%2C%20la%20curva%20de%20Lorenz%20se%20aleja%20de%20la%20l%C3%ADnea%20de%2045%20grados.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_0-1734509627839.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_0-1734509627839.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71349i0FC0538AF1D7290C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_0-1734509627839.png%22%20alt%3D%22Masukawa_Nao_0-1734509627839.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%225%22%20color%3D%22%23FF6600%22%3ERelaci%C3%B3n%20entre%20la%20curva%20de%20Lorentz%20y%20el%20coeficiente%20de%20Gini%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEl%20coeficiente%20de%20Gini%20se%20calcula%20a%20partir%20del%20%C3%A1rea%20encerrada%20entre%20la%20curva%20de%20Lorentz%20y%20la%20l%C3%ADnea%20de%20perfecta%20igualdad.%20Se%20define%20como%20el%20%C3%A1rea%20encerrada%20cuando%20el%20%C3%A1rea%20del%20tri%C3%A1ngulo%20rect%C3%A1ngulo%20inferior%20se%20establece%20en%201%20y%20se%20calcula%20mediante%20la%20siguiente%20f%C3%B3rmula.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%224%22%3ECoeficiente%20de%20Gini%20%3D%201%20-%202%C3%97%20(%C3%A1rea%20bajo%20la%20superficie%20de%20Lorentz)%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEn%20el%20caso%20de%20igualdad%20perfecta%2C%20la%20curva%20de%20Lorentz%20es%20igual%20a%20la%20recta%20de%20igualdad%20perfecta%2C%20y%20en%20el%20caso%20de%20desigualdad%20perfecta%2C%20la%20curva%20de%20Lorentz%20se%20convierte%20en%20un%20tri%C3%A1ngulo%20rect%C3%A1ngulo%2C%20por%20lo%20que%20el%20coeficiente%20de%20Gini%20se%20puede%20interpretar%20de%20la%20siguiente%20manera.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3EEl%20coeficiente%20de%20Gini%20es%200%3C%2FSTRONG%3E%20%3A%20igualdad%20perfecta%20(todos%20tienen%20los%20mismos%20ingresos%20y%20recursos)%3C%2FFONT%3E%3C%2FLI%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3ECoeficiente%20de%20Gini%20de%201%3C%2FSTRONG%3E%20%3A%20desigualdad%20total%20(una%20persona%20monopoliza%20todo)%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EPor%20cierto%2C%20el%20coeficiente%20de%20Gini%20de%20Jap%C3%B3n%20en%20materia%20de%20ingresos%20ha%20ido%20aumentando%20a%C3%B1o%20tras%20a%C3%B1o%2C%20de%200%2C433%20en%201990%20a%200%2C526%20en%202003%20y%200%2C570%20en%202021*.%20Estas%20cifras%20muestran%20que%20la%20desigualdad%20de%20ingresos%20se%20est%C3%A1%20ampliando%20en%20Jap%C3%B3n.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E*Las%20cifras%20presentadas%20aqu%C3%AD%20son%20el%20%22coeficiente%20de%20Gini%20del%20ingreso%20inicial%22%20y%20%3CSPAN%3Eson%20diferentes%20del%20%22coeficiente%20de%20Gini%20de%20redistribuci%C3%B3n%22%2C%20que%20se%20basa%20en%20el%20ingreso%20despu%C3%A9s%20de%20pagar%20impuestos%20y%20primas%20de%20seguro%20social.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EComo%20se%20mencion%C3%B3%20al%20principio%2C%20%3CSTRONG%3Ela%20curva%20de%20Lorenz%20y%20el%20coeficiente%20de%20Gini%20se%20utilizan%20a%20menudo%20en%20el%20%C3%A1mbito%20econ%C3%B3mico%20y%20social%2C%20pero%20tambi%C3%A9n%20pueden%20usarse%20como%20indicadores%20para%20medir%20la%20desigualdad%20y%20el%20sesgo%20en%20otros%20campos.%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EPor%20lo%20tanto%2C%20esta%20vez%20presentar%C3%A9%20un%20ejemplo%20de%20c%C3%B3mo%20calcular%20la%20curva%20de%20Lorentz%20y%20el%20coeficiente%20de%20Gini%20usando%20JMP%20usando%20datos%20de%20MLB.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%225%22%20color%3D%22%23FF6600%22%3EEjemplo%20de%20uso%20del%20coeficiente%20de%20Gini%3A%20Sesgo%20en%20el%20n%C3%BAmero%20de%20jonrones%20en%20MLB%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEn%20la%20temporada%20regular%20de%20la%20MLB%202024%2C%20analizamos%20el%20sesgo%20en%20el%20n%C3%BAmero%20de%20jonrones%20de%20los%20bateadores%20de%20los%20cuatro%20equipos%20que%20participaron%20en%20la%20Serie%20Mundial%20y%20la%20Serie%20de%20Campeones%20de%20Liga.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEl%20siguiente%20histograma%20muestra%20la%20distribuci%C3%B3n%20de%20jonrones%20de%20los%20bateadores%20de%20cada%20equipo.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_0-1734573378488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_0-1734573378488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71398iF4E08E433CF6FCAF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_0-1734573378488.png%22%20alt%3D%22Masukawa_Nao_0-1734573378488.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3ESi%20sabes%20algo%20sobre%20b%C3%A9isbol%2C%20sabr%C3%A1s%20qui%C3%A9nes%20son%20los%20valores%20at%C3%ADpicos%20de%20los%20Dodgers%20(50-55%20hits)%20y%20los%20Yankees%20(55-60%20hits).%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EA%20continuaci%C3%B3n%20se%20detallan%20los%20pasos%20para%20calcular%20el%20coeficiente%20de%20Gini%20y%20crear%20una%20curva%20de%20Lorentz%20en%20JMP%20usando%20el%20ejemplo%20de%20los%20Dodgers.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%224%22%20color%3D%22%230000FF%22%3E1.%20Preparar%20datos%20y%20crear%20f%C3%B3rmulas%20de%20c%C3%A1lculo.%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EA%20continuaci%C3%B3n%20se%20muestran%20los%20datos%20que%20son%20la%20fuente%20del%20histograma%20anterior%2C%20incluidas%20las%20columnas%20%22Homeruns%22%20(n%C3%BAmero%20de%20jonrones)%20y%20%22N%22%20(n%C3%BAmero%20de%20personas).%20Ahora%20usaremos%20la%20f%C3%B3rmula%20para%20crear%20las%20columnas%20que%20se%20muestran%20en%20amarillo.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_1-1734574086892.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_1-1734574086892.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71399iD8C7BEA473123038%2Fimage-dimensions%2F701x305%3Fv%3Dv2%22%20width%3D%22701%22%20height%3D%22305%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_1-1734574086892.png%22%20alt%3D%22Masukawa_Nao_1-1734574086892.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3ECada%20columna%20amarilla%20tiene%20aplicada%20la%20siguiente%20f%C3%B3rmula*.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3EColumna%20%22%20%3CSTRONG%3ECum_N%3C%2FSTRONG%3E%20%22%3A%20Muestra%20el%20porcentaje%20acumulado%20de%20personas.%20Utilizado%20para%20el%20eje%20horizontal%20de%20la%20curva%20de%20Lorentz.%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_0-1734574858446.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_0-1734574858446.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71400iC68494A8A882FA37%2Fimage-dimensions%2F302x133%3Fv%3Dv2%22%20width%3D%22302%22%20height%3D%22133%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_0-1734574858446.png%22%20alt%3D%22Masukawa_Nao_0-1734574858446.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3EColumna%20%E2%80%9C%20%3CSTRONG%3ECum_Homeruns%3C%2FSTRONG%3E%20%E2%80%9D%3A%20Muestra%20el%20porcentaje%20acumulado%20de%20jonrones.%20Utilizado%20para%20el%20eje%20vertical%20de%20la%20curva%20de%20Lorentz.%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_1-1734575024947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_1-1734575024947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71401iE3576837689E632D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_1-1734575024947.png%22%20alt%3D%22Masukawa_Nao_1-1734575024947.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3EColumna%20%22%20%3CSTRONG%3Etrapezoide%3C%2FSTRONG%3E%20%22%3A%20Calcula%20el%20%C3%A1rea%20bajo%20la%20superficie%20de%20Lorentz%20usando%20la%20f%C3%B3rmula%20del%20trapezoide.%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_2-1734575157610.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_2-1734575157610.png%22%20style%3D%22width%3A%20521px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71402iCA63AEF0DF5F1942%2Fimage-dimensions%2F521x95%3Fv%3Dv2%22%20width%3D%22521%22%20height%3D%2295%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_2-1734575157610.png%22%20alt%3D%22Masukawa_Nao_2-1734575157610.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CFONT%20size%3D%224%22%3EColumna%20%E2%80%9C%20%3CSTRONG%3EGiniCoef%3C%2FSTRONG%3E%20%E2%80%9D%3A%20Calculando%20el%20coeficiente%20de%20Gini%20a%20partir%20del%20%C3%A1rea%20del%20trapezoide.%3C%2FFONT%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_3-1734575243405.png%22%20style%3D%22width%3A%20312px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_3-1734575243405.png%22%20style%3D%22width%3A%20312px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71403i8BC289E7656AEB0C%2Fimage-dimensions%2F312x92%3Fv%3Dv2%22%20width%3D%22312%22%20height%3D%2292%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_3-1734575243405.png%22%20alt%3D%22Masukawa_Nao_3-1734575243405.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEl%20coeficiente%20de%20Gini%20obtenido%20es%200%2C584.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%222%22%3E*Estas%20f%C3%B3rmulas%20de%20c%C3%A1lculo%20se%20pueden%20combinar%20en%20una%20sola%2C%20pero%20para%20que%20sea%20m%C3%A1s%20f%C3%A1cil%20de%20entender%2C%20utilizamos%20deliberadamente%20varias%20columnas%20en%20el%20c%C3%A1lculo.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%224%22%20color%3D%22%230000FF%22%3E2.%20Creando%20una%20curva%20de%20Lorentz%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3ECree%20un%20gr%C3%A1fico%20de%20l%C3%ADneas%20usando%20el%20%22Creador%20de%20gr%C3%A1ficos%22%20usando%20las%20columnas%20reci%C3%A9n%20creadas%20%22Cum_N%22%20y%20%22Cum_Homeruns%22.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_4-1734575469068.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_4-1734575469068.png%22%20style%3D%22width%3A%20522px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71404i525B5A017444972C%2Fimage-dimensions%2F522x335%3Fv%3Dv2%22%20width%3D%22522%22%20height%3D%22335%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_4-1734575469068.png%22%20alt%3D%22Masukawa_Nao_4-1734575469068.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EAqu%C3%AD%2C%20la%20l%C3%ADnea%20de%2045%20grados%20(l%C3%ADnea%20de%20puntos%20negra)%20se%20puede%20mostrar%20haciendo%20clic%20derecho%20en%20el%20gr%C3%A1fico%2C%20seleccionando%20%3CSTRONG%3E%5BPersonalizar%5D%3C%2FSTRONG%3E%20en%20el%20men%C3%BA%20que%20aparece%20y%20escribiendo%20el%20siguiente%20script.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_5-1734575657965.png%22%20style%3D%22width%3A%20462px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_5-1734575657965.png%22%20style%3D%22width%3A%20462px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71405iF7AC0E3DB7168F00%2Fimage-dimensions%2F462x150%3Fv%3Dv2%22%20width%3D%22462%22%20height%3D%22150%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_5-1734575657965.png%22%20alt%3D%22Masukawa_Nao_5-1734575657965.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EAdem%C3%A1s%20de%20los%20Dodgers%2C%20realizamos%20los%20mismos%20c%C3%A1lculos%20para%20los%20Yankees%2C%20los%20Mets%20y%20los%20Guardianes%2C%20y%20los%20resultados%20de%20las%20curvas%20de%20Lorenz%20se%20muestran%20a%20continuaci%C3%B3n.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Masukawa_Nao_0-1734575925216.png%22%20style%3D%22width%3A%20747px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Masukawa_Nao_0-1734575925216.png%22%20style%3D%22width%3A%20747px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71406iE9C7FFA5DCA40316%2Fimage-dimensions%2F747x397%3Fv%3Dv2%22%20width%3D%22747%22%20height%3D%22397%22%20role%3D%22button%22%20title%3D%22Masukawa_Nao_0-1734575925216.png%22%20alt%3D%22Masukawa_Nao_0-1734575925216.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEn%20la%20curva%20de%20Lorenz%2C%20cuanto%20m%C3%A1s%20hacia%20abajo%20est%C3%A9%20la%20curva%2C%20mayor%20ser%C3%A1%20el%20sesgo.%20Puedes%20ver%20que%20el%20sesgo%20para%20los%20Guardianes%20(l%C3%ADnea%20roja)%20es%20menor%20en%20comparaci%C3%B3n%20con%20los%20otros%20tres%20equipos.%20Si%20tambi%C3%A9n%20nos%20fijamos%20en%20el%20coeficiente%20de%20Gini%2C%20los%20Dodgers%2C%20Yankees%2C%20Mets%20y%20Guardians%20son%20los%20m%C3%A1s%20sesgados.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3ELos%20Dodgers%20y%20los%20Yankees%2C%20que%20avanzaron%20a%20la%20Serie%20Mundial%2C%20tienen%20ciertos%20jugadores%20que%20conectan%20una%20cantidad%20abrumadoramente%20grande%20de%20jonrones%2C%20lo%20cual%20es%20un%20factor%20importante%20en%20el%20sesgo.%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EEn%20este%20blog%2C%20mostramos%20un%20ejemplo%20del%20uso%20del%20coeficiente%20de%20Gini%20y%20la%20curva%20de%20Lorentz%20para%20visualizar%20y%20cuantificar%20el%20sesgo%20en%20el%20n%C3%BAmero%20de%20jonrones%20en%20la%20MLB.%20Este%20m%C3%A9todo%20se%20puede%20aplicar%20no%20s%C3%B3lo%20a%20los%20campos%20econ%C3%B3mico%20y%20social%2C%20sino%20tambi%C3%A9n%20al%20an%C3%A1lisis%20de%20datos%20en%20deportes%20y%20otros%20campos.%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3EConsulte%20la%20tabla%20de%20datos%20de%20JMP%20que%20calcul%C3%B3%20los%20coeficientes%20de%20Gini%20para%20los%20cuatro%20equipos%20adjunta%20a%20este%20blog%20(MLB2024_4teams.jmp).%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3Epor%20Naohiro%20Masukawa%20(JMP%20Jap%C3%B3n)%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20size%3D%224%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FNaohiro-Masukawa%2Fbg-p%2Fnmasukawa-blog%22%20target%3D%22_blank%22%3ENaohiro%20Masukawa%20-%20Comunidad%20de%20usuarios%20de%20JMP%3C%2FA%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-824127%22%20slang%3D%22ja-JP%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAn%C3%A1lisis%20y%20modelado%20de%20datos%20b%C3%A1sicos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
格差分析の新視点:MLBホームラン数の偏りをジニ係数で読み解く
このブログでは、経済や社会分野で所得や貯蓄の格差を分析する際に用いられる「ローレンツ曲線」と「ジニ係数」について説明します。併せてMLB(メジャーリーグベースボール)の各チームにおけるホームラン数の偏りを分析するために、JMPを用いてローレンツ曲線で視覚化し、ジニ係数で定量化した例を紹介します。
不平等さを測る指標:ジニ係数とローレンツ曲線
データの偏りや不平等を定量化する指標として、「ジニ係数」がよく知られています。そして、その不平等を視覚的に表現するために「ローレンツ曲線」が用いられます。
ジニ係数は「不平等の指標」とも呼ばれ、所得格差や教育格差など、さまざまな分野で格差の度合いを示す際に使われています。
下図は、家庭における所得格差を視覚化したローレンツ曲線(青色)です。横軸は家庭の累積割合、縦軸は累積所得割合を示します。所得格差がなく平等の場合、ローレンツ曲線は点線で示した45度線(「完全平等線」という)に一致します。一方、所得の格差が大きい、つまり不平等の場合、ローレンツ曲線は45度線から遠ざかります。
ローレンツ曲線とジニ係数との関係
ジニ係数は、ローレンツ曲線と完全平等線の間に囲まれた面積を基に計算されます。右下の直角三角形の面積を1としたときの囲まれた面積と定義され、次の式で求められます。
ジニ係数 = 1 - 2×(ローレンツ曲面下の面積)
完全に平等のときはローレンツ曲線が完全平等線に等しくなる、完全に不平等のときはローレンツ曲線が直角三角形になることから、ジニ係数は次のように解釈されます。
  • ジニ係数が0:完全に平等(全員が同じ収入や資源を持つ)
  • ジニ係数が1:完全に不平等(1人がすべてを独占している)
ちなみに日本の所得に関するジニ係数は、1990年:0.433、2003年:0.526、2021年:0.570 と年々上昇しています*。これらの数値は、日本で所得格差が拡大していることを示しています。
※ここで提示した数字は「当初所得ジニ係数」であり、税金や社会保険料を支払った後の所得を基準にした「再分配ジニ係数」とは異なります。
最初に述べたとおり、ローレンツ曲線やジニ係数は、経済や社会分野で用いられるケースが多いですが、それ以外の分野でも不平等さや偏りを測る指標として用いることができます。
そこで、今回はMLBのデータを使い、JMPでローレンツ曲線とジニ係数を求める例を紹介します。
ジニ係数の利用例:MLBのホームラン数の偏り
2024年のMLBレギュラーシーズンにおいて、ワールドシリーズおよびリーグチャンピオンシリーズに出場した4チームの打者のホームラン数の偏りを分析しました。
以下のヒストグラムは、各チームにおける打者のホームラン数の分布を示します。
野球に詳しい方であれば、Dodgersの外れ値(50-55本)、Yankeesの外れ値(55-60本)は誰だかわかりますよね?
Dodgersの例を用いて、JMPでジニ係数を計算し、ローレンツ曲線を作成する手順を以下に示します。
1. データの準備と計算式の作成
以下は、上記ヒストグラムの元となるデータであり、「Homeruns」(ホームランの本数)と「N」(人数)の列を含みます。これから計算式を用い、黄色で示した列を作成します。
黄色の列は、それぞれ次の計算式を適用しています*。
  • 列「Cum_N」: 人数の累積割合を示しています。ローレンツ曲線の横軸に用います。
  • 列「Cum_Homeruns」:ホームランの累積割合を示しています。ローレンツ曲線の縦軸に用います。
  • 列「trapezoid」:台形公式を用いてローレンツ曲面下の面積を計算しています。
  • 列「GiniCoef」:台形の面積からジニ係数を計算しています。
求められたジニ係数は、0.584です。
*これらの計算式をまとめて1つの式にすることもできますが、ここでは分かりやすさを優先し、あえて複数の列を用いて計算しています。
2. ローレンツ曲線の作成
新しく作成した列「Cum_N」、「Cum_Homeruns」を用い、「グラフビルダー」を使って折れ線グラフを作成します。
ここで、45度線(黒色の点線)はグラフ上で右クリックし、表示されるメニューから  [カスタマイズ] を選択し、次のようなスクリプトを記述することにより表示できます。
Dodgersに加え、Yankees、Mets、Guardiansの3チームについても同様に計算し、ローレンツ曲線を重ね合わせた結果を以下に示します。
ローレンツ曲線では下側にたるんでいるほど、偏りが大きいことを示しています。ガーディアンズ(赤線)の偏りは他の3チームと比べて小さいことがわかります。併せてジニ係数を見ると、偏りが大きい順にDodgers、Yankees、Mets、Gardiansとなっています。
ワールドシリーズに進出したDodgers、Yankeesは、一部の選手が圧倒的に多くのホームランを打っており、それが偏りの大きな要因です。
本ブログでは、ジニ係数とローレンツ曲線を使い、MLBのホームラン数の偏りを視覚化・定量化する例を示しました。この手法は、経済や社会分野だけでなく、スポーツやその他の分野のデータ分析にも応用できます。
4つのチームに対するジニ係数を算出したJMPのデータテーブルは、本ブログに添付していますのでご参考にお願いします(MLB2024_4teams.jmp)。
by 増川 直裕(JMP Japan)
Naohiro Masukawa - JMP User Community
Last Modified: Dec 23, 2024 7:00 PM
