Check out the JMP® Marketplace featured Capability Explorer add-in
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Transforming Data to Make Better Predictions
See how to:
  • Understand why transformations stabilize variance, make the error more uniform across the design region, remedy lack of fit and plot predictions in a way that does not violate physical limits, display negative counts or erroneously report yields as greater than 100%donn
  • Transform data on the fly using Graph Builder and change scales to improve graph readability and interpretability
  • Use square root transformation to eliminate negative values and examine how using Box-Cox power transformation on response might change fit
  • Compare no transformation, log transformation with prediction in raw units and log transformation with prediction in log units
  • Use square root transformation to construct model effects using Polynomial to Degree 2 macro, identify best transformation, use selected transformation, save residuals to data table and evaluate results using distributions
  • See how square root transformation might display a more uniform count spread and more linear relationship
Why Transforrmations Can Be UsefulWhy Transforrmations Can Be Useful
Comments
MSN
Super useful and clear presentation.
Great presentation!  Thanks so much for taking the time to share with us all.
