Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
New in JMP 18 and JMP Pro 18
Presented in English
Published on ‎11-07-2024 03:32 PM by Community Manager Community Manager | Updated on ‎08-28-2025 11:45 AM
JMP 18 and JMP Pro 18 offer many new capabilities .  See a video of some of the key new capabilites and download the Journal to try some of the techniques yourself in JMP 18. Note, for several capabilites you will need JMP Pro 18.
Watch the whole video below, or click on titles in the bullet list to see only the segments on the topic in the list.
See how to use:
  • New capabilites for tables,  reports and contextual help
  • New capabilities for process optimization, modeling and reliability
    • Precision Recall Curves – Useful when you have unbalanced data.
    • Profiler Visualizations – Interact with variables to optimize for variability using overlaid interactions and examine data points to see how well data supports model interactions.
    • Fatigue Modeling - Create, view results for, and select from 24 different models, choose from six S-N curve types together with one of four distributions to assemble a model, get detailed information on, and compare, all models.
  • New for Data Import, Engineering and Production
  • New  for Spectral, Peaked and High-Dimensional Data (JMP Pro)
  • New Python Integration
    • Python Library and Integration Enhancements – Use version of Python that ships with JMP for a consistent environment that will work immediately. Get direct memory access to Python data tables in a live environment and use Python Script Editor that uses Python conventions and an embedded log.
Questions answered by @HydeMiller and @MikeD_Anderson  at the live webinar.
Q: How do I use Collapsible Annotiations?
A: From a graph in Graph Builder, start with the Annotations icon. To collapse an annotation, right click on an annotation and select Minimized. The collapsed annotation will appear as an “i” icon. See video below.
Q:  Please clarify how confidence intervals are used?
A:   The shaded zones on the Profiler are the confidence interval on the line itself. So, there's a line of fit through the data and the confidence interval shows where that line of fit it could be. That is confidence on the line. It's not a confidence interval on the values. Now, if you go to the Red Triangle menu, Prediction Intervals are available and they show the confidence interval for the predicted values themselves. There is an  aqua color line, and then the numbers that correspond to the lines that show the confidence for the prediction interval. In JMP 18 you now can kind of show both of them on the Prediction Profiler.  See video:
Patrick Guiliano @PatrickGiuliano , JMP Technical Support sent this information after the webinar:
The following commentary came from another JMP user. The "Confidence" lines (see image) are slightly curved, and define a 2-dimensional space in which we claim the true linear regression line exists; that is, if we imagine that the observed linear regression line can rotate about the point that is Xavg, Yavg but only within that space (i.e., the rotating line has to stay completely within the confidence lines),  then the true parameter slope of the line is said to be somewhere between the largest and smallest slope possible by performing such rotations, at a confidence level = to whatever confidence value we used to calculate those confidence lines. The confidence lines can therefore be used to predict the worst-case scenario for an AVG Y-value at a SPECIFIC X value.
The Prediction interval lines are also slightly curved; they define a 2-dimensional space in which we PREDICT the next single X,Y-value we obtain will occur. Our prediction is more confident, the closer we are to the Xavg,Yavg point, and is less confident the further away we are, which is why the lines looked curved.
Q: Do the equations come over to use Profiler?
A:  Not with this release. They were focusing on the core framework. You could add a request for that to the JMP wishlist for a future release.
Q:  Is it possible to call JMP from Python? IE the opposite of what you showed, where JMP calls Python.
A: There are certain calls that go either direction. The documentation will indicate  what all is allowed.
Resources
Start:
Tue, Jun 4, 2024 02:00 PM EDT
End:
Tue, Jun 4, 2024 03:00 PM EDT
6 Comments
markschahl
Great overview. Can you please post a link to the journal file?
gail_massari
Community Manager
Hi @markschahl .  I added the zip file that should give you what you need.
Nita_Natchanok
Is there a presentation about new feature of JMP Workflow Builder? I'm looking for a guide specific to the Prompt feature under the Show Messages.
I noticed that it was not on the presentation of the JMP 17 version.
This is from the 17-version tutorial (Developer Tutorial: Using Workflow Builder to Share Analysis Steps for Replay – No Coding Required)
and this is on JMP 18, I can't seem to make it work and looking for a document or guideline.
I'll try sending question to Technical Support team. If there is no document or guide on that.
I'm about to send an email to JMP Technical support team.
And found out that I need to put caret sign at the start-end of the JSL variable.
and when to use this user input in the Step Code script, I need to put the name inside the "..."n (include that caret signs).
which I don't know why but it just solved the problem. believe it is new in JMP 18 for this feature in the Workflow Builder.
gail_massari
Community Manager
Hi @Nita_Natchanok .  I did not see it in the documentation.  I am copying two people who may know why and where this is documented. @HydeMiller and @MikeD_Anderson
