This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Created:
Jul 29, 2020 12:48 PM
| Last Modified: Oct 25, 2023 12:42 PM
Model Driven Multivariate Control Chart.zip
See how to compare and contrast situational usefulness of two methods for looking at lots of process variables at the same time: Model Driven Multivariate Control Charts (MDMCC) and Process Screening.
@Byron_JMP@Ben_Sagalovsky A thought from August 20 live webinar: I am curious about the role of autocorrelation for Principal Components calculations, etc. And associated with this, the issue of subsampling process data and deciding on what is the most appropriate interval to sample, and how to determine it.
@gail_massari that's an interesting question to be sure. there are a litany of ways to sample from a process but how to avoid autocorrelation? best way looking back is simply to plot the residuals either by row (no limits, connecting line)or use the studentized residuals plot that JMP produces in the Fit Model Platform. I prefer saving the residuals and making a run chart in Graph Builder or using the Control Chart Builder (I-MR with Limits or Turn Off limits entirely for I chart and ignore MR chart).
Another more "statistical approach" is to use the Durbin Watson Test:
Among the many sampling approaches include: Systematic, Stratified, Cluster, and Multi-stage.
I've tried generating Column Formulas in JMP using JSL to mimic each of these sampling strategies:
Consider a random sample of 1000 test data with a sample of size 250 for each of 4 Lots.
Systematic Sample:
If(Sequence(1, 5) == 5, 1, 0)
Stratified Sample:
If( Col Shuffle( :Lot ) <= 50,
1,
0
Cluster Sample Select Lots 1 or Lot 3:
If( :Lot == 1 | :Lot == 3,
1,
0
Random Sample Cluster Lots 1 or Lot 3:
If(
:Cluster Select Lot 1 or Lot 3 == 1 & If( Col Shuffle( :Lot ) <= 50,
1,
0
1,
0
