Have you ever experienced an issue importing data from Excel or other sources? I bet you are not alone, at least I had mine. In my previous blogs Part 1 and Part 1 cont. I showed in general how to import spreadsheet data into JMP. Let’s now talk about typical challenges importing data I come across over and over again, both working with data on my own or when listening to our customers and users.
Most often I faced challenges when the system of the creator of the file has different language settings than the receiver of the file aka I. E.g. someone in Germany gets a file from someone in the US. Then you probably get in trouble with the dates or numbers format. Although this is not only a challenge restricted to JMP Users, it can be frustrating. Changing system settings would often do the trick but is not the preferred way for several reasons – e.g. it will affect also other software. So what can you do?
What is your experience? What challenges do you face?
Living in Germany (and that’s true for most non-US countries) there are some other typical issues with Umlaut, special characters, comma vs. decimal separated floating point, date formats (especially month vs. day defaults) and I’m sure you know more. If so please post them as comments so we can collect those and check if we can find ways to improve importing international data – as I want to call it.
However, now I will try to describe how I dealt with several of those. At all they are meant to be suggestions and may not be valid for all cases. However, I found them quite helpful in most of the cases I worked with international data.
Floating Point Numbers
In US and other English based countries you will find a number format separated with decimals rather than comma, which is commonly used in European countries. Why is this important?
If the language setting aligns with the decimal format (US with decimals, GER with comma, …) the data will be imported and displayed correct as continuous and like in the source table. If the language setting differs, e.g. US number format in the spreadsheet and GER setting in JMP and/or the system, you will recognize that the data type changes from continuous to nominal character.
Usually you would use Column Info and change the Data Type from character to numeric and Modeling Type from nominal to continuous. In this case this will result in empty data as the Language setting cannot interpret the comma or the decimal, depending on the language.
So there are two things you could do to work around this:
How to do this?
Preferences(Use JMP Locale Settings( 1 ))
Two Digit Year numbers
In case of two-digit year numbers you should take care that JMP recognize the correct 100 years. To do so there is a setting for the underlying two-digit year rule JMP should refer to:
The third topic of date formats will be part of my next blog. Please share your experiences using the comment option below. I also would like to know if you found the scripts valuable. Thank you!
