  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
%3CLINGO-SUB%20id%3D%22lingo-sub-809994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUtilizzo%20di%20MSA%20per%20situazioni%20che%20richiedono%20prove%20distruttive%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%22%3E%3CDIV%20id%3D%22lia-vid-6268180898001w480h270r900%22%20class%3D%22lia-video-brightcove-player-container%22%3E%3CVIDEO-JS%20data-video-id%3D%226268180898001%22%20data-account%3D%226058004218001%22%20data-player%3D%22default%22%20data-embed%3D%22default%22%20class%3D%22vjs-fluid%22%20controls%3D%22%22%20data-application-id%3D%22%22%20style%3D%22width%3A%20100%25%3B%20height%3A%20100%25%3B%22%3E%3C%2FVIDEO-JS%3E%3C%2FDIV%3E%3CSCRIPT%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F6058004218001%2Fdefault_default%2Findex.min.js%22%3E%3C%2FSCRIPT%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2F6268180898001%22%20target%3D%22_blank%22%3E(vedi%20in%20I%20miei%20video)%3C%2FA%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EScopri%20come%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EAffrontare%20le%20ipotesi%20chiave%20per%20MSA%20(le%20parti%20non%20cambiano%20forma%20nel%20tempo%20e%20non%20vengono%20modificate%20misurandole)%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ESuperare%20l'impossibilit%C3%A0%20di%20ripetere%20le%20misurazioni%20quando%20vengono%20violati%20i%20presupposti%20chiave%20dell'MSA%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3EEseguire%20e%20interpretare%20test%20distruttivi%20che%20presuppongono%20un%20materiale%20perfetto%20e%20probabilmente%20sovrastimano%20%3CSPAN%3Ela%20variazione%20da%20parte%20a%20parte%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3ESupponiamo%20che%20il%20materiale%20all'interno%20di%20un%20lotto%20o%20di%20una%20partita%20sia%20uniforme%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ERaccogliere%20pi%C3%B9%20lotti%20in%20cui%20ogni%20lotto%20rappresenta%20una%20parte%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ESuddividere%20i%20lotti%20in%20modo%20che%20ogni%20suddivisione%20rappresenti%20una%20misurazione%20ripetuta%20quando%20testata%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EProvare%20tutte%20le%20parti%20in%20ordine%20casuale.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EAnalizzare%20utilizzando%20il%20metodo%20EMP.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3EEseguire%20e%20interpretare%20test%20descrittivi%20che%20presuppongono%20un%20test%20perfetto%20e%20probabilmente%20sottostimano%20la%20variazione%20da%20parte%20a%20parte%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3EUtilizzare%20un%20test%20non%20distruttivo%20che%20sia%20ben%20correlato%20al%20test%20distruttivo%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ECostruire%20una%20curva%20di%20calibrazione%20da%20dati%20di%20test%20distruttivi%20e%20non%20distruttivi%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ETestare%20le%20parti%20in%20modo%20non%20distruttivo%20in%20un%20ordine%20casuale%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ETestare%20le%20parti%20in%20modo%20distruttivo%20in%20un%20ordine%20casuale%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EUtilizzare%20la%20formula%20della%20curva%20di%20calibrazione%20per%20ridimensionare%20i%20dati%20non%20distruttivi%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ECombina%20i%20risultati%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EAnalizzare%20utilizzando%20il%20metodo%20EMP%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%3ENote%3A%20Le%20domande%20sono%20incluse%20alla%20fine%20della%20demo%2C%20a%20partire%20da%20~%20Ora%2032%3A30.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERisorse%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EVideo%20e%20risorse%20di%20Mastering%20JMP%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FMastering-JMP-Videos-and-Files%2FUsing-the-EMP-Method-for-Measurement-System-Analysis%2Fta-p%2F407690%22%20target%3D%22_self%22%3Eutilizzo%20del%20metodo%20EMP%20per%20l'analisi%20del%20sistema%20di%20misurazione%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fibisuva.nl%2Fassets%2Fpublicaties%2Fartikelen%2F2005-demast-gauge.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EStudi%20R%26amp%3BR%20di%20Gauge%20per%20misurazioni%20distruttive%3C%2FA%3E%20di%20Jeroen%20De%20Mast%20e%20Albert%20Trip%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscovery-Summit-Americas-2020%2FMeasurement-Systems-Analysis-for-Curve-Data-2020-US-30MP-573%2Fta-p%2F281520%22%20target%3D%22_self%22%3EAnalisi%20dei%20sistemi%20di%20misura%20per%20dati%20di%20curve%3C%2FA%3E%20(presentazione%20JMP%20Discovery%20Summit)%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EUn%20promemoria%3A%20per%20contattare%20Jason%20Wiggins%20nei%20commenti%2C%20includi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13731%22%20target%3D%22_blank%22%3E%40Jason_Wiggins%3C%2FA%3E%20.%20nel%20tuo%20commento.%20%3CEM%3EMeasurement%20Systems%20Analysis.zip%3C%2FEM%3E%20%C3%A8%20una%20versione%20compressa%20del%20progetto%20JMP%2016%20di%20Jason%20utilizzato%20nella%20sessione.%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EIngegneria%20della%20qualit%C3%A0%20e%20dei%20processi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-855802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Utilizzo%20di%20MSA%20per%20situazioni%20che%20richiedono%20prove%20distruttive%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-855802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEcco%20un%20altro%20link%20valido%20che%20puoi%20utilizzare%20per%20accedere%20alla%20pubblicazione%20a%20cui%20si%20fa%20riferimento%20nella%20presentazione%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDe%20Mast%2C%20J.%20e%20Trip%2C%20A.%20(2005).%20Studi%20R%26amp%3BR%20di%20misura%20per%20misurazioni%20distruttive.%20Journal%20of%20Quality%20Technology%2C%2037(1)%2C%2040-49%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20class%3D%22break-word%20hover%3Atext-super%20hover%3Adecoration-super%20dark%3Ahover%3Atext-superDark%20dark%3Ahover%3Adecoration-superDark%20underline%20decoration-from-font%20underline-offset-1%20transition-all%20duration-300%22%20href%3D%22https%3A%2F%2Fwww.vitalentusa.com%2Flinks%2Fpdfs%2FGage_RR_Destructive%2520Measurement.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.vitalentusa.com%2Flinks%2Fpdfs%2FGage_RR_Destructiva%2520Measurement.pdf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
Using MSA for Situations Requiring Destructive Testing
Presented in English
Published on ‎11-07-2024 03:30 PM by Staff | Updated on ‎11-07-2024 05:40 PM
See how to:
  • Address key assumptions for MSA (Parts do not change form over time and are not changed by measuring them)
  • Overcome inability to repeat measurements when key MSA assumptions are violated
  • Perform and interpret desctructive test that assumes perfect material and likely overestimates part-to-part variation
    • Assume material within a lot or a batch is uniform
    • Gather multiple lots where each lot represents a part
    • Subdivide lots so that each subdivision will represent a repeat measurement when tested
    • Test all parts in a random order.
    • Analyze using EMP method.
  • Perform and interpret desctuctive test that assumes perfect test and likely underestimates part-to-part variation
    • Use a nondestructive test that correlates well with the destructive test
    • Build a calibration curve from destructive and nondestructive test data
    • Test parts nondestructively in a random order
    • Test parts destructively in a random order
    • Use the formula from the calibration curve to scale the nondestructive data
    • Combine results
    • Analyze using the EMP method
Notes: Questions are included at the end of the demo, beginning at ~ Time 32:30.
Resources
A reminder that to contact Jason Wiggins in comments, include @Jason_Wiggins. in your comment. Measurement Systems Analysis.zip is a zipped version of Jason's JMP 16 Project used in the session.
Start:
Fri, Aug 13, 2021 02:00 PM EDT
End:
Fri, Aug 13, 2021 03:00 PM EDT
1 Comment
PatrickGiuliano
Here is another valid link that you can use to access the publication referenced in the presentation:
De Mast, J. and Trip, A. (2005). Gauge R&R Studies for Destructive Measurements. Journal of Quality Technology, 37(1), 40-49
https://www.vitalentusa.com/links/pdfs/Gage_RR_Destructive%20Measurement.pdf
