Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Getting Started with Graph Builder
Presented in English
Published on ‎11-24-2025 02:25 PM by Community Manager Community Manager | Updated on ‎02-25-2026 04:25 PM
Video using JMP 19 was posted in February 2026.
Graph Builder is a versatile way to interactively create visualizations to explore and describe your data. Drag and drop data to predefined zones to visually identify relationships between variables. Quickly create, undo, redo, and experiment with plots that link to your data, until you find the one you want. Then, save and share your results with others. Graph Builder capabilities have increased over the years and can’t be covered in one session.  This session gets you started with the basics and includes integrating graphs into dashboards.
See how to:
  • Understand the purposes of the main Graph Builder window areas.
  • Identify and use the table properties that are key to building graphs.
  • Use and preview results of dragging and dropping to zones.
  • Customize graph axis and table labels and graph titles.
  • Use new JMP 19  jitter, smoother and multiple Y-axis capabilities.
  • Build graphs
    • Explore and create using drag and drop
    • Understand the areas and zones
    • Scatter plots, bars, trend lines & heat maps
  • Customize graphs
    • Prepare data table  and properties (like labels)
    • Customize axes, labels and titles
    • Add pictures
  • Share graphs
    • Create graph filters
    • Save scripts, paste images
    • Save as interactive HTML & LIVE
    • Combine windows & create dashboards
This webinar covers: Graph Builder and uses movies.jmp in the JMP Sample Data.
Suggested Prerequisites: Basic experience using JMP data tables, distributions and simple analyses.
Resources
Start:
Fri, Feb 20, 2026 02:00 PM EST
End:
Fri, Feb 20, 2026 03:00 PM EST
0 Comments
