This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
A common practice is to run a regular analysis using data where the number or names of the inputs differ. This recipe provides a general method for getting columns into an analysis platform without knowing how many there are or their names. This is accomplished through the power of expression handling.
Ingredients:
Expression handling
Sample Data Tables: Cars 1993
Difficulty – Hard
Video Length – 4:25
Steps:
Start with the following three lines
Names Default to Here(1);
tblRef = Current Data Table();
colList = tblRef << Get Column Names();
This code scopes the variables created within the script to this script window, creates a reference to the current table, and gets a list of column references, respectively.
Open a data table with at least one continuous, one ordinal, and one nominal column. The Cars 1993 sample data table can be used. Run Distribution with one of each of these types of columns. Because the report output differs depending on column type, the platform may treat them differently. Save the script to a script window.
Distribution treats all categorical (Ordinal and Nominal) columns identically. This is the case for most platforms.
Create an expression for the empty platform message
distributionExpr = Expr(Distribution())
Loop over each column and insert into the expression created in the step above, an expression corresponding to the column analysis. The column analysis expression can be taken from the code saved after Distribution was run interactively. Substitute will be used to build the column analysis expressions. The value returned from Substitute is then inserted into the main expression.
When Substitute is used for expression handling it takes an odd number of arguments. The first argument corresponds to the expression into which substitutions are made. Substitute evaluates its first argument; we’ll need the Expr function to treat it as an expression. The remaining pairs of arguments give the expression within the first argument to be replaced and the value to use. Name Expr is used to keep nextColExpr from evaluating when inserted into the main expression.
At the end of the loop, insert the argument into the Distribution expression. Use Name Expr, so the contents of the variable nextColExpr are inserted as an expression and not fully evaluated.
When the Distribution expression is complete, create an expression explicitly messaging the data table then evaluate it.
Name Expr is needed for the value of anExpr because we want its contents as an expression not its evaluated value. Leaving it off would cause the expression in distributionExpr to evaluate prematurely, before being explicitly sent to the data table. This would not cause a problem in the current script because the current data table has not changed. To see how this could go wrong and what would happen, remove Name Expr from the third argument and insert
Open("$SAMPLE_DATA/BIG CLASS.JMP");
after creating the variable for the current data table. Run the code. The Big Class data table will open but the report window will not be created. An error message will be written to the log indicating that the data table does not recognize the message.
The code below shows an alternative more succinct way of looping through the columns.
Name Expr is used with the first argument to Substitute because we want to use the value stored in nextExpr, not (literally) nextExpr, which is what Expr(nextExpr) would return.
Hints for Success:
Expression handling is a difficult topic. The more example you see, the more you should understand.
Substitute can be used to build expressions. The first argument holds the expression and the remaining argument pairs hold the expression to replace and the value to use.
Expr and Name Expr can be used to control evaluation. The contents of Expr are taken literally, as is the once evaluated contents of Name Expr.
