JMP 18 brings powerful new capabilities in its Python integration, including:
Today, I'm focusing on the jmp.DataTable object and the changes JMP 18 has made with respect to Python Send ( dt ) and Python Get( df ), where "dt" is a data table and "df" is a pandas.DataFrame.
Beginning with JMP 14 and up until JMP 17, users could transfer a copy of a JMP data table to the Python environment using the JSL command Python Send( dt );. It functioned behind the scenes with JMP writing the data table to a temporary CSV file in the file system and then invoking pandas to read the CSV file from disk into a DataFrame.
While that worked just fine for small files, it wasn't suitable for larger data. The first issue is that it required using the file system for data transfer. The second problem is a loss of precision when going from binary to text and then back to binary. Third, the CSV file is often dramatically larger than the original binary data. Finally, the data in Python is merely a copy, without any way to manipulate the original table. Bringing Python processed data back into JMP using Python Get ( df ); follows exactly the same process in reverse. Python Get( df ); was left intact for compatibility reasons.
But now with the advent of JMP 18, Python Get ( dt ); retrieves the data table reference to JSL of the actual table, which is is a zero-copy operation. By necessity, Python Send( dt ); no longer creates a pandas.DataFrame. In Python, you get a jmp.DataTable object, which is a live reference to the JMP data table. This too is a zero-copy operation, allowing direct access from Python to access, edit, and modify the JMP data table. You can create a jmp.DataTable object from Python while creating a new JMP table.
Below is a JSL script using the JMP 18.0 features to take a JMP data table and add a column that is the ratio of two columns from Python. It is performed live on the current data table:
// BigClass_hw_ratio.jsl
// Description: Show JMP 18 Python integration features
Names Default to Here(1);
dt = Open("$SAMPLE_DATA/Big Class.jmp");
Python Send(dt);
Python Submit("\[
import jmp
# print some information on data table properites
print(dt.__class__)
print(dt.name)
print(f'nrows: {dt.nrows}')
print(f'ncols: {dt.ncols}')
# data table object columns may be indexed either by
# column name or index. Note: slice is only supported
# when using indexes. Slice on both columns and rows is supported.
for x in dt[0:]:
print( x.name )
# As is Python convention, indexing is 0-based
print( dt['name'][0] )
# create a new column based on data from the original data.
# Because JMP is column centric, the access to
# jmp.DataTable object is [column][row]
dt.new_column('H/W ratio', jmp.DataType.Numeric)
for idx in range(dt.nrows):
dt['H/W ratio'][idx] = dt['height'][idx] / dt['weight'][idx]
It results in this log output:
/*: <class 'jmp.DataTable'> Big Class nrows: 40 ncols: 5 name age sex height weight KATIE 0
Next, let's see how to work directly from Python. Below is a Python script that:
The current table is the one just created in Python.
# dt2pandas2dt.py # Description: Example showing creating a pandas.DataFrame from a .jmp file, # then creating a new data table from the data frame. # This process happening live and in-memory. # import jmp import numpy as np import pandas as pd from pandas.api.types import is_object_dtype, is_numeric_dtype, is_bool_dtype, is_string_dtype # creating a Pandas dataframe from a JMP DataTable directly dt = jmp.open(jmp.SAMPLE_DATA + "Big Class.jmp") # create pandas DataFrame from Big Class df = pd.DataFrame() for idx in range( len(dt) ): df[ dt[idx].name ] = np.array( dt[idx] ) print(df) # we can close dt since we no longer need it open, we # have everyting in df dt.close(save=False) # create JMP DataTable from pandas DataFrame dt2 = jmp.DataTable('BC2', df.shape[0]) # get the column names from the data frame names = list(df.columns) # loop across the columns of the data frame for j in range( df.shape[1] ): # check if the coulumn data type is string or numeric if is_string_dtype(df[ names[j] ] ): dt2.new_column(names[j], jmp.DataType.Character ) else: dt2.new_column(names[j], jmp.DataType.Numeric ) # populate the JMP column with data dt2[j] = list(df.iloc[:,j])
# Just as JSL has a Python Submit(); to execute Python code # the jmp object has a run_jsl() command to execute JSL from Python jmp.run_jsl(''' Names Default to Here(1); Current Data Table() << Get Column Names; ''')
The following log output is the result:
/*: name age sex height weight 0 KATIE 12.0 F 59.0 95.0 1 LOUISE 12.0 F 61.0 123.0 2 JANE 12.0 F 55.0 74.0 3 JACLYN 12.0 F 66.0 145.0 4 LILLIE 12.0 F 52.0 64.0 5 TIM 12.0 M 60.0 84.0 6 JAMES 12.0 M 61.0 128.0 7 ROBERT 12.0 M 51.0 79.0 8 BARBARA 13.0 F 60.0 112.0 9 ALICE 13.0 F 61.0 107.0 10 SUSAN 13.0 F 56.0 67.0 11 JOHN 13.0 M 65.0 98.0 12 JOE 13.0 M 63.0 105.0 13 MICHAEL 13.0 M 58.0 95.0 14 DAVID 13.0 M 59.0 79.0 15 JUDY 14.0 F 61.0 81.0 16 ELIZABETH 14.0 F 62.0 91.0 17 LESLIE 14.0 F 65.0 142.0 18 CAROL 14.0 F 63.0 84.0 19 PATTY 14.0 F 62.0 85.0 20 FREDERICK 14.0 M 63.0 93.0 21 ALFRED 14.0 M 64.0 99.0 22 HENRY 14.0 M 65.0 119.0 23 LEWIS 14.0 M 64.0 92.0 24 EDWARD 14.0 M 68.0 112.0 25 CHRIS 14.0 M 64.0 99.0 26 JEFFREY 14.0 M 69.0 113.0 27 MARY 15.0 F 62.0 92.0 28 AMY 15.0 F 64.0 112.0 29 ROBERT 15.0 M 67.0 128.0 30 WILLIAM 15.0 M 65.0 111.0 31 CLAY 15.0 M 66.0 105.0 32 MARK 15.0 M 62.0 104.0 33 DANNY 15.0 M 66.0 106.0 34 MARTHA 16.0 F 65.0 112.0 35 MARION 16.0 F 60.0 115.0 36 PHILLIP 16.0 M 68.0 128.0 37 LINDA 17.0 F 62.0 116.0 38 KIRK 17.0 M 68.0 134.0 39 LAWRENCE 17.0 M 70.0 172.0 //:*/ Names Default to Here(1); Current Data Table() << Get Column Names; /*: {name, age, sex, height, weight}
Keep an eye out for more samples in future blog posts.
