Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Level up your Python game with JMP: Visualize and communicate Python models in JMP
Once you build your models in Python, you can bring them into JMP to visualize, understand, and communicate them.
Below are two examples:
  1. Building two models in Python and then visualizing and exploring an Actual by Predicted plot in JMP Graph Builder.
  2. Building a model in Python and then visualizing and communicating it with JMP Prediction Profiler.
Example 1: Using JMP Graph Builder to visualize and explore models built in Python
Example 2: Using JMP Prediction Profiler to visualize and communicate a model built in Python
To learn more about using the Prediction Profiler, check out the following Mastering JMP recorded webinars:
Using Prediction Profiling to Maximize Model Proficiency - Part 1
Using Prediction Profiling to Maximize Model Proficiency - Part 2
Last Modified: Sep 24, 2024 1:00 PM
