  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
JMPer Cable
Expression Analysis with JMP Genomics
JMP Genomics is a specialized yet broad tool for analyzing genetic, genomic and other “-omic” data.
Whether it's expression analysis, GWAS, predictive modeling, or plant breeding, JMP Genomics has a tool to meet the need.
The second set of blog posts in our series deal with expression data. We import data from a text file, create an Experimental Design File outlining the details of the experiment, and perform an expression analysis.
Each installment of the series can be accessed below as it becomes available. The first series focused on Genetic Association with JMP Genomics.
Series Outline
Design
  1. Expression Analysis with JMP Genomics, Part 1: Experimental Design
Import
  1. Expression Analysis with JMP Genomics, Part 2: Importing Expression Data from Text Files
Expression Analysis
  1. Expression Analysis with JMP Genomics, Part 3: Basic Expression Workflow
    1. Quality Control
    2. Normalization
    3. Analysis/Model
Last Modified: Jul 2, 2019 5:09 PM
Comments
irinastl
Level II
Why JMPG is still not available for MACs?
Chris_Kirchberg
Hi @irinastl
JMP Genomics does not run natively on MacOS because JMP Genomics uses SAS in the background to process and analyze the expression and genotype data. SAS (Desktop SAS/Analytics Pro) cannot be installed on the  MacOS since it was never developed for that OS and because of this constraint and dependence, it will never run native on the Mac.
One can use Virtual Desktop software like VMWare or Parallels to run a Windows OS on the Mac and install JMP Genomics. Another alternative is to use Bootcamp on the Mac and install a Windows OS so it runs natively on the hardware.  A third option is to install it on a remote server (like AWS, Citrix or Windows Server OS) and install it there with remote access.
Hope that helps explain why.
Best,
