the most important DataView? NON-excluded rows!
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
The rows summary table on the bottom left of a table is very useful to get DataViews (subsets) for selected rows, excluded rows and so on.
The Data View
Unfortuntely, in my daily work it's much more often that I need a subset of non-excluded rows than of excluded rows.
So, I go:
3)
my wish: an additional entry for non-excluded rows,
like this
and by this: the opportunity to generate a DataView for non-excluded rows.
Additional benefit:
One can directly see the number of actually used (= non-excluded) rows and doesn't have to calculate it (all rows - excluded)
10 Comments
Sarah-Sylvestre
Level V
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
SamGardner
Level VII
I have been think about this one for a while, and on my short holiday I decided to work on a scripted approach to do this.
We are looking into this, however, to make this easier to.
 Here is my script:
SCRIPT NAME:  Row Selector Viewer
AUTHOR(s):
Sam Gardner, JMP Statistical Discovery LLC
JMP VERSION:
Built with JMP 17.0 and tested with JMP 16.2
PURPOSE:
To allow the user to be able to easily subset and see rows that are selected or excluded or hidden, OR unselected or unexcluded or unhidden
SPECIFICATION:
Views of the desired subset of the current data table are created using linked subsets and data box views within a report window.  Upon selecting an option, an invisible linked
subset of the desired rows to view is created, and then a new data view in a  data box is displayed in the scripted report window.
USAGE:
Must be run with a data table open.
Upon running, choose the subset of the rows to view by selecting the check boxes.  Note that this current version
only allows subsetting based in Selected/Excluded/Hidden or Unselected/Unexcluded/Unhidden
ASSUMPTIONS: None.
SCRIPT REVISION HISTORY:
VERSION	DATE		DESCRIPTION
1.0		2022 Dec 14	First Version
NOTES:
N/A
TO DO:
N/A
FUTURE IMPROVEMENT IDEAS:
None at this time.
Names Default To Here( 1 );
dt = Current Data Table();
// function definitions
// Loc Inverse Function
// This function converts a vector of positive integers (locvals) into an
// indicator vector of a specified length, n,  with the values
// v[I] = 1 if I is in locvals, and 0 otherwise
// example
//      Loc Inverse(6, [1,3])
// returns
//      [1, 0, 1, 0, 0, 0]
Loc Inverse = Function( {n, locvals},
	v = J( n, 1, 0 );
	v[locvals] = 1;
	v;
Loc Inverse( 6, [1, 3] );
// this gets the indicators of selected rows in the data table
LocInverse( N Rows( dt ), dt << Get Selected Rows );
// this gets the indicators of the excluded rows in the data table
Loc Inverse( N Rows( dt ), dt << GetExcludedRows );
// this gets the indicators of the hidden rows in the data table
Loc Inverse( N Rows( dt ), dt << GetHiddenRows );
nw = New Window( "Row Selector Viewer",
	<<On Close(
		Try(
			Close( dt_sub, nosave );
			Clear Symbols( dt_sub );
	vb = H List Box(
		V List Box(
			Text Box(
				"You can choose option from either the left or right set of check boxes.  If no options are selected then the entire table is shown.",
				<<Set Wrap( 200 )
			pbleft = Panel Box( "Choose Rows",
				H List Box(
					cbleft = Check Box(
						{"Selected", "Excluded", "Hidden"},
						Print( cbleft << get selected );
						Print( cbleft << get selected indices );
						viewchoice = cbleft << get selected;
						RowstoView = J( N Rows( dt ), 1, 0 );
						If( N Items( viewchoice ) > 0,
							For( i = 1, i <= N Items( viewchoice ), i++,
								RowstoView = RowstoView | Match( viewchoice[i],
									"Selected",
										cbright << Set All( 0, run script( 0 ) );
										Loc Inverse( N Rows( dt ), dt << Get Selected Rows );,
									"Excluded",
										Loc Inverse( N Rows( dt ), dt << Get Excluded Rows );,
									"Hidden",
										Loc Inverse( N Rows( dt ), dt << Get Hidden Rows );
							RowstoView = Loc( RowstoView );
							Print( RowstoView );
							RowstoView = 1 :: N Rows( dt );
						If( !Is Empty( dt_sub ),
						selectedrows = dt << get selected rows;
						dt << clear select;
						dt << select rows( RowstoView );
						dt_sub = dt << Subset( Output Table( "Data View" ), Selected Rows( 1 ), Selected Columns Only( 0 ), Linked, Private );
						dt << clear select;
						dt << select rows( selectedrows );
						pbright << Append( dt_sub << new data box() );
					cbright = Check Box(
						{"Unselected", "Unexcluded", "Unhidden"},
						viewchoice = cbright << get selected;
						RowstoView = J( N Rows( dt ), 1, 1 );
								RowstoView = RowstoView & Match( viewchoice[i],
									"Unselected",
										cbleft << Set All( 0, run script( 0 ) );
										!(Loc Inverse( N Rows( dt ), dt << Get Selected Rows ));,
									"Unexcluded",
										!(Loc Inverse( N Rows( dt ), dt << Get Excluded Rows ));,
									"Unhidden",
										!(Loc Inverse( N Rows( dt ), dt << Get Hidden Rows ));
						dt << clear select;
						dt << clear select;
			Button Box( "Close Viewer", nw << close window )
		pbright = Panel Box( "Data View", )
dt_sub = dt << Subset( All Rows, Selected Columns Only, Linked, Private );
hogi
Level XIII
I found this in the outbox - don't know if I posted it somewhere else?
In the same context - please also allow the user to  send
dt << Get nonExcluded Rows();
to a data table:
https://community.jmp.com/t5/Discussions/col-lt-lt-get-values-for-non-excluded-rows/m-p/556579/highl...
fastes single-line command for this important piece of code is ~ factor 10 slower:
allRows = dt << get rows where( Excluded() == 0 );
And first asking for the non-excluded rows and then "inverting" the list adds ~ 30% to the time budget
hogi
Level XIII
@SamGardner.
Thank you for the code - really nice menus.
should definitely go to the Subset menu of Jmp 18 :)
We could ask @jules if he wants to add it to the Dynamic subset Add-In as well :)
Concerning my post here, I actually thought about something much tinier - just to add an option for the non-excluded rows to the menu on the lower left of a data table.
To be honest, I am already so used to selecting the excluded rows and then to invert the selection - I would say that such a feature comes would come too late for me.
But as many of my posts - the wishes are not mainly for myself, but more for my co-workers ... and all the other users in the community :)
hogi
Level XIII
With the introduction of QuickSelect Toolbar  it got a bit easier:
The click count reduced from
- select excluded rows (2 clicks)
- invert selection (rows - row selection - invert row selection = 3 clicks)
- data view for selected rows (2 clicks)
➜ 7 clicks
to
- invert (1 click)
- data view for selected rows (2 clicks) with the new Quickselect Toolbar: 1 click
➜ 5 4 clicks
Outlook:
with non-excluded added to the menu on the bottom left, it will be 2 clicks :)
hogi
Level XIII
Hm, how about:
- don't add "non-Excluded" to the overview table
- but add Select non-excluded to the right click contect menu of Excluded
are there users who use the hidden functionality?
then add a similar option to select non-hidden rows
hogi
Level XIII
hogi
Level XIII
@Sarah-Sylvestre
with all these options available, from my point of view the topic can be closed.
There are other much more important entries in the wish list.
Sarah-Sylvestre
Level V
Status changed to: Archived
Thank you for the update @hogi!
