  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
reverse option for Display Boxes
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
When reshape the appearance of existing report, the Horizontal 0/1 option helps a lot:
The horizontal option is not only available for ListBoxes, but also for oher DisplayBoxes, e.g. ColumnSwitcherContextBoxes.
Do I want the Column Switcher on the left or on the top? -> just enable or disable the Horizontal option :)
For Lineup Boxes it's similar:
Just send <<NCol(N) to a lineup Box and the items will be aligned horizontally instead of vertically (if the setting before was NCol(1))
You can imagine what comes next?
How do I get the Column Switcher below the graph or to the right?
option 1)
For DisplayBoxes which can contain multiple sub-items, please provide an option Reverse 0/1 to specify if the items appear 1->N inside the report or in the reverse order.
option 2)
please provide a functionality to specify the precise order of the sub-items. Maybe even with the possibility to specify a different number M of items to display - for a Display Box with originally N available items. *)
<<order({x,y,z}) where the user can specify the number of the sub-item that should appear at position x, the item that should appear at position y and so on.
e.g. with the option order ({1,1,1}), the first sub-item of the Listbox should appear 3 times (making sense or not).
*) I think it's easier to be open here than to throw an error if M=N and if a specific item is listed multiple times.
Why is this idea important?
More flexibility when re-formatting a report window that already exists.
Giving more flexibility for the placement of e.g. Column Switcher menus.
1 Comment
hogi
Level XIII
@Sarah-Sylvestre .
-> wish can be closed.
