  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
make NewFormulaColumn/Character more flexible
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
If columns with type "character" are selected, the New Formula Column menu shows the submenu character.
Among other option, there is the function concatenate which concatenates the strings.
There are also 2 more functions. They concatenate with Space or comma.
My wish:
  • A more general function "concatenate with string ...".
    The idea: After selecting this function, a window pops up and asks the user to enter a string.
    Then one can concatenate also with "_" or "-" or ...
Contrary to what I wrote in a previous version of this post, "concatenate" is also available if characters AND numbers are selected.
If numbers are selected as well, a char(number) is added automatically. Cool :)
Unfortunately, the character/concatenate function is missing if all the selected columns are numbers.
Could you please make the concatenate function available also for this variant?
7 Comments
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
A workaraound can be found at: Col/Utilities/Combine Columns.
Most of the features are exactly matching:
- the user can specify the delimiter character
- the result column can be set  "multiple response"
- the function is also avalilable if all selected columns are "numbers"
The only disadvantage:
It generates the new colum by writing the values - i.e. not as a function.
Therefore, the table canot be used as a template and adding new data via tables/concatenate will not work.
hogi
Level XIII
new in JMP 17: concatenate with underscore  -> thanks :)
exactly the option that I wanted
backlog:
Could you please make the character/concatenate functions available also if just numbers are selected?
jthi
Wish List item which was marked as Duplicate due to this wish list item which is a bit more wide in scope: Enable string concatenation in "New Formula Column" -> "Combine" for numerical columns
hogi
Level XIII
@Sarah-Sylvestre , status of this wish can be set to delivered.
The part which is still open is covered by Enable string concatenation in "New Formula Column" -> "Combine" for numerical columns
Status changed to: Delivered
