  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
least squares box-cox graphing improivement
JMP should support an improvement to the box-cox λ parameter when transforming the response in the least squares fit model, so that the reverse transformation is automatically applied to graphs. This would save messing around for hours withg the graph builder.
5 Comments
Sarah-Sylvestre
Level V
@Grumpybaldprof - Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
@Grumpybaldprof if you perform the fit on the Box Cox Transformed response (using the Refit with Transform or Replace with Transform) option under the Box-Cox transformation
and then you save the prediction formula for that fit (red triangle > Save Columns > Prediction Formula), that prediction formula has the appropriate inverse transform.  You can then use that column to create plots in Graph Builder.
Does that meet your needs?
SamGardner
Level VII
Status changed to: Needs Info
Grumpybaldprof
Level II
Thanks Sam,
Unfortunately no, this solutions does not help. The reason is simple, the transformation changes the axes values making them useless for biological interpretation. See screenshot below.
best wishes,
Paul
JMP® Pro 16.2.0
Grumpybaldprof
Level II
Hi Sam,
Ah now I see, but there seems to be no way in graph builder to have the raw points in the x axis, coded by colour for fetal sex and the 2 curves OVERLAID  from the predicted formula column coloured by sex. Please advise.
best wishes,
Paul
JMP® Pro 16.2.0
