  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
functionality to cut the connection between a linked table and the main table
https://community.jmp.com/t5/Discussions/linked-data-table-how-to-cut-the-quot-link-quot/m-p/573180#...
Summary Tables and Subsets have an option to "link" the new table to the original data table.
"Data views" have such a link enabled by default.
Cool:
Row Selections and changes to the values are automatically linked between the tables.
But sometimes one needs to remove such a link
- to add additional rows to the main table
- edit entries in the columns which were used for summary grouping
- to rename columns of the linked table
my wish:
remove the link via right click on
and click on a command like "cut the link".
workarounds:
- generate a (100%) subset of the linked table and delete the linked table itself
- a Links cannot be saved, so, one can save the tables, close both tables and open the "linked" table again - without the link.
9 Comments
Sarah-Sylvestre
Level V
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
hogi
Level XIII
Another application for an easily accessible function to cut the link between data tables:
If plots are exported as Interactive HTML files, they get significantly larger if they are linked to another table,
see this comment by @John_Powell_JMP
https://community.jmp.com/t5/Discussions/interactive-HTML-file-size/m-p/596368/highlight/true#M80004
Cutting the link can reduce the file size from several MB to 1.5MB (minimum size due to interactive HTML overhead?).
hogi
Level XIII
Another application:
  • pre-select a subset of a data table and click on data view to get a short overview (definitely the fastest way to get it :)
  • ah, there are 2 more rows which I don't need, just mark them and delete the rows
    ARGH !! - there is a protection shield due to the link to the original data table.
hogi
Level XIII
not anymore :)
QuickSelect Toolbar is twice *) as fast:
*) by thumb -  1 click instead of 2 clicks
under real condition, the gap is even larger
1 click -> no mouse movement between 2 clicks
Sarah-Sylvestre
Level V
hogi
Level XIII
Thanks. Will help ...
BHarris
Level VII
Bumping this, my team and I spent some time today scratching our heads trying to break the link and couldn’t find a way other than save-as/close/reopen, which is both tedious and surprising.
hogi
Level XIII
yes, no good idea to keep such obvious bugs in a Software for years!
sure, there are workarounds like save/close or Subsets - but for every new JMP user such bugs are significant issues - blocking the workflow.
This approach competes now with AI driven data analysis!
Wish list - new Label: user experience
