    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
🙏 optimized syntax highlighting in JSL editor
☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2022
Please add this functionality to JSL editor:
When a user Double-Clicks a bracket, the code inside the brackets is analyed, clustered ind highlighted with differnet colors.
Example for "if":
- conditions are highlighted green to separate the code blocks in-between
- else code is highlighted red to separate is from the other code
https://community.jmp.com/t5/Discussions/JSL-if-else-gt-find-the-commas/m-p/573510/highlight/true#M7...
Similar highlighting could also be applied to many  other functions:
Match: highlight each match to separate the code blocks.
Substitute: highlight the search patterns to separate the replacement blocks
6 Comments
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
hogi
Level XIII
hogi
Level XIII
another way of syntax highlighting - I think it will help even more : )
Advanced syntax highlighting in JSL Editor
hogi
Level XIII
90% of the functionality is already available:
https://community.jmp.com/t5/Discussions/If-statement-comma/m-p/824212/highlight/true#M100363
-> low prio to get the remaining 10%
