  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
consistent marker control in Graph Builder
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
At the moment, it is not possible to use a specific marker in Graph Builder
There are 2 options in JMP which can be used to assign markers:
1) manually assign a marker via the legend in Graph Builder:
2) Row States: this settings allows the user to override the marker setting for specific rows:
On the other hand, this setting is overruled by marker settings via the legend.
Actually there is a 3rd option to tune the marker settings: via preferences, one can choose a default marker setting
Surprisingly:
With all these options, there is no possibility available yet in JMP to control the marker settings for a specific plot like:
"In this plot I want to use Hollow markers".
Sure, the above 3 options can be used as a workaround to achieve the task - with more or less effort (just imagine there are 75 entries in the legend - and each of them has to be changed individually to prevent collateral effects on other subplots!)
... and with more or less collateral damage to other plots:
1) if the user accidentally selects a legend entry before assigning a new marker state, the new marker will be assigned to all selected entries:
So, if you assigned the new marker to 73 entries in the legend, be sure that you don't select an entry when assigning the marker to entry & # 74, 75 !!!)
2) For row states and preferences the collateral impacts on other plots is even more severe.
Please provide a framework that allows a consistent marker control in Graph Builder.
Something like
Elements( Position( 1, 1 ), Points( X, Y, Color( 1 ), Marker Graph Theme("Hollow") ) )
to pick a specific marker set for a plot.
and
Elements( Position( 1, 1 ), Points( X, Y, Color( 1 ), Marker("circle") ) )
to assign the same Marker to all items in a plot.
Another way to interpret "consistent marker control" is proposed in this wish:new Column Property: Value Markers
It suggests a column property to get a consistent link between column entries and the assigned markers.
It could be used as an alternative to the functionality proposed in this wish.
Why is this idea important?
JMP lacks consistent marker control.
3 Comments
Sarah-Sylvestre
Level V
Thank you for submitting this request!
hogi
Level XIII
Great: part of this wish as already implemented in JMP19 via Type Properties().
What is missing:
a less specific mode like
to use hollow markers for a specific plot type - or a similar command to use dashed lines.
Dashed lines: Great advantage for Parallel Y Axis
- color is needed for Overlay - and it's no good practice to paint the axis with color.
hogi
Level XIII
Important: the current mode in JMP19  interferes significantly with data filter selections and exploratory data analysis.
For more details please check
https://community.jmp.com/t5/Discussions/consistent-marker-and-style-control-type-properties/m-p/917... ff
and Support Ticket TS-00256956
The automatic mode is cool: any new item in the plot layer will inherit the settings of the existing items.
But its harmful. So, from my point of view, the automatic mode must be removed.
Instead: please add a functionality that allows the user to pick a setting and use it as type properties:
right click on an entry in the legend -> use as Type property.
This mode is almost as good as the automatic mode - and the users can decide if they want to activate it with the associated risk/ harm for  exploratory data analysis.
