🙏 X group: restrict the values on the axis to the respective group
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2022
#myTop10_2024
#myTop10_2025
#myTop10_2026
Short:
get rid of all this white space !!!
Long:
View more...
With nominal values on the x axis and X group activated, the axes of the sub-plots share a common list of values.
All plots show all values.
In the example below, X group says that girls are in the left plot and boys are in the right plot.
But due to axis sharing between both subplots, boys and girls show up on the axes of both plots.
This is counter-intuitive and consumes unnecessary space.
With some steps the underlying data table can be changed to generate a plot with girls just on the left and boys on the right:
https://community.jmp.com/t5/Discussions/X-group-gt-adjust-axis/m-p/542262
Would be great to have a right click option to directly "disentangle" the axis settings such that each axis gets (just) its own values.
similar topics:
- same effect for y axis values and Y group
- different axis scaling for continuous values in different sub-plots.
example: Plot with male and female students.
Unfortunately, the plot on the left (F!) lists also all the  male students - and the plot on the right (M!) all the female students !??!
25 Comments
shampton82
Level VIII
@hogi I agree, this is much needed!  Any update would be appreciated @Sarah-Sylvestre !!
It would help out the new page "row" option as well as you can split out the different levels to be on their own Y axis but unless you are using a continuous Y axis you still have the same gaps in the X axis.
Here the Page is arrange by two rows and the x axis is the lot number.  Each panel is by the part number.  Each panel should only respect the lots associated with it.
I have to switch to a continuous X axis to make it useful
hogi
Level XIII
Why does Graph builder ignore the link axis setting for categorical values ?!?!
hogi
Level XIII
as an interim solution till the new functionality is available ....
there is a workaround which I just learned from JMP support [TS-00156288]:
thanks @ Sarah
- use nested values on the x axis
- use page for the main groups
- use the new page layout
- link Y axes
- don't replicate the linked axes
- for each subplot: adjust the x range MANUALLY (!!!) to show the subset
... and then remove the nested axis labels to hide your tracks.
- cross your fingers that all data points are in the view and that NOBODY updates the data table without adjusting the x axis ranges in every subplot
View more...
Graph Builder(
	Size( 770, 357 ),
	Show Control Panel( 0 ),
	Link Page Axes( "Y Only" ),
	Replicate Linked Page Axes( 0 ),
	Variables(
		X( :sex ),
		X( :name, Position( 1 ) ),
		Y( :height ),
		Page( :sex, Levels per Row( 2 ), Show Title( 0 ) ),
		Overlay( :sex )
	Elements(
		Points( X( 1 ), X( 2 ), Y )
hogi
Level XIII
We tried the workaround several times. VERY (!!) fragile, extremely dangerous!
Sarah-Sylvestre
Level V
hogi
Level XIII
Many thanks - will be a nice improvement for Graph Guilder : )
hogi
Level XIII
Candidate of the 2025 Wish List Prioritization Survey:
Help shape the future of JMP: Take this year’s Wish List Prioritization Survey!
hogi
Level XIII
related issue:
Remove empty subplots in Group X graph
Can it be fixed as well?
hogi
Level XIII
hogi
Level XIII
