Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Thank you for the suggestion. Where do you think would be a good place or places to include these outlier tests? Should it be a standalone platform and report, or incorporated into other platforms?
We have a platform, under Analyze > Screening > Explore Outliers that does do some outlier detection methods. Could this be a place for that feature?
That seems like a reasonable platform in which to include the Dixon and Grubbs' tests. This would be very helpful in the pharma world because these two are specifically mentioned in the USP.
I just wanted to second this. It would be very usefull to have the Grubbs test added to the Outlier plattform (and allow to select the identified outliers - which is not an option in the add-in, sadly).
This is also an issue at my company, we need to direct users to Minitab for these tests, this is in our training materials currently and I would love to be able to change it!
Do we have plans to update this feature to a new version? One of my pharmaceutical clients has raised the same demand, as mentioned by the person above
