Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Thank you for the suggestion. Where do you think would be a good place or places to include these outlier tests? Should it be a standalone platform and report, or incorporated into other platforms?
We have a platform, under Analyze > Screening > Explore Outliers that does do some outlier detection methods. Could this be a place for that feature?
That seems like a reasonable platform in which to include the Dixon and Grubbs' tests. This would be very helpful in the pharma world because these two are specifically mentioned in the USP.
I just wanted to second this. It would be very usefull to have the Grubbs test added to the Outlier plattform (and allow to select the identified outliers - which is not an option in the add-in, sadly).
This is also an issue at my company, we need to direct users to Minitab for these tests, this is in our training materials currently and I would love to be able to change it!
Do we have plans to update this feature to a new version? One of my pharmaceutical clients has raised the same demand, as mentioned by the person above
