Warn me if executing a command / running an analysis is going to take a long time.
I find on larger data sets that some analyses take a long time to run.  For example, running a Binomial or Poisson generalized linear model on a data set with ~20 million rows can take over an hour on my machine.  It would be great if JMP could (1) warm me if executing a command was going to take longer than 10 minutes and give me the option to cancel; and (2) if I choose to continue, give me an estimate of how long the analysis was going to take to complete.
10 Comments
jwiltsie
Level III
Or could be a status bar with an option to cancel for platforms that involve potentially difficult analyses. Like what is implemented in the custom design platform.
john_madden
Level VI
It would also be nice if there were a JSL busy widget (a.k.a. wait widget, spinning wheel widget, etc.) that could be used to give the user assurance that a script is still executing. Even better would be a JSL progress bar widget.
vince_faller
Super User (Alumni)
Often Pushing Esc during the run will cancel the platform.  It will take a 5-15 seconds to respond usually but it normally works.
Try this:
names default to here(1);
dt = open("$SAMPLE_DATA\Probe.jmp");
g = dt << Get Column Group("Responses");
YExpr = Expr(Y());
for(i=1, i<=nitems(g), i++,
	insert into(YExpr, g[i]);
Eval(EvalExpr(
	dt << Hierarchical Cluster(
		Expr(nameexpr(YExpr)),
		Method( "Ward" ),
		Standardize Data( 1 ),
		Dendrogram Scale( "Distance Scale" ),
		Number of Clusters( 20 ),
		SendToReport( Dispatch( {}, "Dendrogram", OutlineBox, {SetHorizontal( 1 )} ) )
SamGardner
Level VII
Delivering this capability will need to be on a platform-by-platform basis, but we have created an overall tracking category for this type of issue and will be working on improving the user experience when this occurs.
hogi
Level XII
Agree, for user defined scripts there is the easy solution by @vince_faller to press ESC long enough till it stops.
But for standard platforms this doesn't work. So, along the idea of the wish:
but independent of the warning:
 every standard platform should have a cancel button while running.
This way, a user will have the option top stop a platform whenever he wants - no need to wait hours and hours till a platforms finishes.
Speed up Tables/Update
hogi
Level XII
alternative idea: a Timeout setting in the preferences or a timeout option for Try.
hogi
Level XII
candidate of the Wish List Prioritization Survey - pilot run:
Introducing the JMP Wish List Prioritization Survey!
hogi
Level XII
For several platforms I could identify the root cause of a slow execution - avoiding these trapdoors can save you hours:
  1. Speed up Tables/Update : for every column, it scans again for the matching rows and merges ALL matches into the main table.
    -> rows x # matches x  # columns
    instead of 1x last first or last match (like in Tables / Join)
    -> can take hours instead of seconds
    - the GUI starts with all options enabled
    - the preview
  2. Why is Tables/Concatenate so slow?
    new issue in JMP18: it takes extremely long time to scan the Table Scripts.
    And the platform scans the table scripts while creating the GUI, when a user adds a table and a last tie when the user clicks on OK
    -> can take several second to minutes
  3. Re: Recode - Parse as Number
    if a user executes multiple steps and converts a string into a number it takes much more time than doing the same in 2 steps
    -> can take minutes to hours
hogi
Level XII
Live Distribution: it's very slow if the table has many thousand rows.
new (in JMP18?) : if many rows belong to one value, JMP can "bundle" the values -> less points in the plot and much (!!!) faster
hogi
Level XII
@mia_stephens still under consideration?
could help a lot!
