  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Tables join: option to update main table
☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2023
as we have a workaround for Tables/Update, this one is no longer needed
Tables/Join is a powerful tool to merge different data tables.
The only disadvantage: it generates a new data table instead of updating the main table.
I often have a table, with table dozens of table scripts which evolved over time - and Dashboards which refer to this table.
To widen the analysis, I want to add a column to the table - but Tables/Join generates a new table.
Please add an option in Tables/Join: Update main table.
If the option is enabled, the platform should update the main table instead of generating a new one.
If Jmp developers fear that Tables:Join gets too crowded by this option, they could hide the option behind a shift-click or invisible to other users.
Why is this idea important?
There is no fast way to merge new columns to a data table.
Table/Join is almost the perfect tool - but it generates a new table.
The additional setting will solve the issue.
15 Comments
hogi
Level XIII
cool!
Fuzzymerge for time + "Match columns" for some additional columns :)
hogi
Level XIII
@FN There is already a separate Wish for FuzzyMerge:
Add fuzzy join / asof merge / join by columns which do not have exact matches
... from 2022.
Unfortunately, the status was still "New" (Juliy 2023) - perhaps due to 0 Kudos up to now?
Sarah-Sylvestre
Level V
SamGardner
Level VII
Sarah-Sylvestre
Level V
