Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
Support data filters in interactive HTML Reports
In order to be able to share the results with a non - JMP user , it will be very useful if the data filters in HTML reports are interactive.
dt= Open( "$SAMPLE_DATA/Big Class.jmp" );
Ana =  dt << Graph Builder(
							Size( 524, 450 ),
							Show Control Panel( 0 ),
							Variables( X( :weight ), Y( :height ) ),
							Elements( Points( X, Y, Legend( 8 ) ) ),
							Local Data Filter(
								Add Filter(
									columns( :age ),
									Display( :age, Size( 181, 102 ), List Display )
Rep = Ana << report ;
Rep << Save Interactive HTML("C:\Desktop\Test.html");
Tracking Number:
Defect ID:
6 Comments
Community Manager
Status changed to: Open for Voting
Thanks for your suggestion, @uday_guntupalli.
We'll need to know which reports, specifically, you're having difficulty with. Since saving as Interactive HTML was introduced in JMP 11 we continue to make more and more parts of the JMP reports interactive when exported to HTML. It will help to know which reports are a priority for you.
BTW: You can see examples of interactive HTML JMP reports in our gallery.
Community Manager
Status changed to: Needs Info
Level VIII
 @Jeff_Perkinson :
 My request should have said , preserve data filters in interactive HTML plots .
							Size( 524, 450 ),
							Local Data Filter(
								Add Filter(
									columns( :age ),
Community Manager
Thanks, @uday_guntupalli, that helps.
I've edited the request to reflect your clarification.
Community Manager
Community Manager
Status changed to: Delivered
In JMP 14 Local Data Filters are now included in Interactive HTML reports.
Read more about it here
