Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
In the menu Tables>Subset you can do "subset by a column", which is pretty much the same like "split by"
In Minitab you have the posibility to subset by formula, like in SQL, where column1 > 2 and column3<6 and genre=male and year>2016.
The only ways i know at the moment is to create a column with if then else formula in it or use the "JMP query Builder" for simple use Filters or create a new column under Available Columns" with the specific formula.
you could save 8-10 mouse clicks when there was an option in subset by formula...
