  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Subset by formula
Why it is not possible to subset directly fromt he menu table>Subset> subset by formula
This way you need first to create a new column with the formula in there and the criterias for subsetting and then subset by the created column.
6 Comments
Jeff_Perkinson
Community Manager
Status changed to: Needs Info
I'm afraid I don't know what you mean, "Subset by Formula". Can you clarify?
Splerin
Level III
Hi Jeff_Perkinson
In the menu Tables>Subset  you can do "subset by a column", which is pretty much the same like "split by"
In Minitab you have the posibility to subset by formula, like in SQL, where  column1 > 2 and column3<6 and genre=male and year>2016.
The only ways i know at the moment is to create a column with if then else formula in it or use the "JMP query Builder" for simple use Filters or create a new column under Available Columns" with the specific formula.
you could save 8-10 mouse clicks when there was an option in subset by formula...
hope my point is now cleare...
XanGregg
In the Subset dialog, turn on Subset By.
Then right-click on a column name and choose Formula.
That will bring up the formula editor so you can enter a custom expression.
When you OK the subset dialog you will get a subset for each formula result value, usually 0 or 1 if your formula is a false or true expression.
Splerin
Level III
Perfekt, many thanks for showing this hidden future ;-)...
So this Idea can be closed or maybe do a select option on the mask and not hidden by right mouse click...
Jeff_Perkinson
Community Manager
Status changed to: Already Offered
Closing as already offered and explained above.
Ryan_Gilmore
Community Manager
Status changed to: Delivered
