Stack Tables option for Multiple Series Stack, for the 2 options show which columns would go where in a preview panel box
Under Tables > Stack, the option for "multiple series stack" is  very helpful in some data situations. Would it be possible when "multiple series stack" is selected to have a preview box to show where the columns would go for the two options: (1) every nth column vs (2) n columns in a row (contiguous)?
If Number of Series is used, preview panel box would show which columns would go in 2, 3, ... n groups, or highlight the first of the series in the upper column dialog. So if 3 was entered, the 1st, 4th, 7th, etc column selected would be highlighted above to safe space.
If Contiguous is checked, would show which columns in how many groups of contiguous columns are being stacked.
From the JMP on Air topic: https://community.jmp.com/t5/JMP-On-Air/The-Tables-Menu/m-p/261014#U261014
5 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
hogi
Level XIII
JMP 17 brought it.
Vball247
Level V
Thanks for commenting, I forgot to track this request after it was archived. Yes, in JMP17 the "Preview" for all the Table menu options is immensely helpful. I repeated the same Blood Pressure sample data analysis from the JMP15 webinar, and it is exactly what was needed to see the changes using Multiple series stack and the Contiguous option in the preview, no need to launch each table to see if it is what you wanted.
This Wish List item is closed
hogi
Level XIII
Yes, helps extremely to find the right settings :)
@Sarah-Sylvestre , might be changed to "delivered"?
Status changed to: Delivered
Thanks for bringing this to my attention! Changing to delivered.
