%3CLINGO-SUB%20id%3D%22lingo-sub-594539%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EModulo%20di%20elaborazione%20del%20segnale%2FToolbox%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-594539%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%0A%3CP%3E%3CSTRONG%3ECosa%20ha%20ispirato%20questa%20richiesta%20di%20lista%20dei%20desideri%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EEsigenze%20personali%20passate%20ed%20esperienza%20con%20colleghi%20che%20stanno%20implementando%20algoritmi%20di%20analisi%20del%20segnale%20parziale%20per%20analizzare%20i%20dati.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQual%20%C3%A8%20il%20miglioramento%20che%20vorresti%20vedere%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFunzioni%20di%20elaborazione%20del%20segnale%20per%20risultati%20standard%20trovati%20in%20pythons%20scipy%2C%20inclusi%20filtri%20(digitali%20e%20analogici)%2C%20FFT%20(spettro)%2C%20rumore%2C%20convoluzione%2C%20correlazioni%2C%20trasformazioni%2C%20analisi%20dei%20picchi%2C%20SNR%2C%20THD%20e%20analisi%20delle%20vibrazioni.%3C%2FP%3E%0A%3CP%3ESe%20possibile%2C%20andrei%20oltre%20e%20aggiungerei%20anche%20funzioni%20per%20la%20simulazione%20dei%20segnali%2C%20questo%20sarebbe%20ottimo%20anche%20per%20insegnare%20e%20sintetizzare%20segnali%20per%20esigenze%20specifiche%20con%20un%20buon%20controllo%20e%20in%20modo%20intuitivo.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ECredo%20che%20uno%20dei%20principali%20punti%20di%20forza%20di%20JMP%20sia%20il%20basso%20livello%20di%20accesso%20che%20consente%20ai%20suoi%20utenti%20di%20essere%20in%20grado%20di%20eseguire%20rapidamente%20attivit%C3%A0%20complesse%2C%20garantendone%20l'integrit%C3%A0%20e%20aiutando%20anche%20gli%20utenti%20ad%20acquisire%20una%20profonda%20comprensione%20dei%20processi.Sento%20che%20l'area%20dell'elaborazione%20del%20segnale%20manca%20immensamente%20di%20questo%20e%20sento%20che%20le%20persone%20di%20JMP%20possono%20contribuire%20notevolmente%20a%20questo%20campo.Questo%20%C3%A8%20un%20campo%20importante%20con%20una%20crescente%20trazione%20e%20credo%20che%20ci%C3%B2%20si%20allineerebbe%20bene%20con%20la%20rinnovata%20enfasi%20di%20JMP%20per%20il%20targeting%20del%20mondo%20accademico.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-594539%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EModellazione%20predittiva%20e%20Machine%20Learning%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-598818%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Modulo%20di%20elaborazione%20del%20segnale%2FToolbox%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-598818%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECIAO%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F18510%22%20target%3D%22_blank%22%3E%20%40Giovanni89%3C%2FA%3E%20%2C%20grazie%20per%20aver%20dedicato%20del%20tempo%20per%20inviare%20questa%20idea!%20Esamineremo%20la%20tua%20richiesta%20e%20ti%20terremo%20aggiornato%20sul%20suo%20stato.%3CSPAN%20class%3D%22Apple-converted-space%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
Signal processing module/Toolbox
Past personal need and experience with colleagues who are implementing partial signal analysis algorithms to analyze data.
Signal processing functions for standard results found in pythons scipy, including filters(digital & analog), FFT (spectrum), noise, convolution, correlations, transformations, peak analysis, SNR, THD, and vibration analysis.
If possible I would go further and add functions for simulating signals as well, this would also be great for teaching and well as synthesizing signals for specific needs with good control and intuitively.
Why is this idea important?
I believe one of JMP's major strengths is the low entry level that it allows of it's users to be able to do complex tasks quickly while assure it's integrity and also assist users in gaining a deep understanding of processes.  I feel the area of signal processing lacks this immensely and feel that the folks at JMP can contribute greatly to this field.  This is a major field with increasing traction and I believe this would align well with JMP's renewed emphasis for targeting academia.
1 Comment
Hi @John89, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
