Secondary x-axis in Graph Builder
I would like to plot two overlayed graphs in the Graph Builder using individual, overlayed x-axes. This would be doable, if I could choose a secondary x-axis, just like I can choose a secondary y-axis. See How do I make a graph with secondary x-axis?
9 Comments
Byron_JMP
I have a script that kind of does this, Multiple Y-Axis Graphs.
bobmorrane
Level V
This would be good to have indeed. Excel can do it, so why not JMP??
Byron_JMP
@bobmorrane In graph builder, put both variables on the Y axis, then right click and choose Move Right.
https://community.jmp.com/t5/Discussions/Where-is-Move-Right-in-the-Graph-Builder/td-p/19930
bobmorrane
Level V
thanks @Byron_JMP
Sarah-Sylvestre
Level V
Hi @Morten, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
please note:
candidate of the Wish List Prioritization Survey - pilot run:
Introducing the JMP Wish List Prioritization Survey!
hogi
Level XIII
One of the 3 winners of the 2024 Wish list Prioritization Survey:
Help shape the future of JMP: Take this year’s Wish List Prioritization Survey!
hogi
Level XIII
use cases:
- 1/T [K] + T[°C]
- wavelength in nm  + wavelength in 1/cm
- deviation in % + factors of sigma:
Do you know how many seconds add up to one month?
No need to remember - with a combined time scale like this one:
hogi
Level XIII
One can create such a plot by using the functionality for the Y axis, and then rotate the graph by 90°. (doesn't feel like "JMP" - but generates the plot. Just the final Y axis looks strange).
Some Tricks with Parallel Y Axes
