  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Scripting Index and online Help: "see also"
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
The scripting index is a great source of knowledge and the examples are very useful to understand what the functions do and how they can be used (with some code context around the actual function).
On the other hand, for a user who wants to find a function for a specific application, the functionality of Scripting Index feels a bit like:
If you don't know the correct function name, I cannot give you the correct info.
https://community.jmp.com/t5/Discussions/Collection-of-quot-funny-quot-JSL-newbie-questions/m-p/5593...
With some more "links" between the entries, a user can be guided through the Scripting Index and finally get to the function that he wants.
-> Please add fill "see also" with more alternatives along the idea:
What possible confusions could have led users to search this function?
e.g. there should be a link between Length/NItems  and  NRow/Dim
examples:
https://www.mathworks.com/help/matlab/ref/length.html
https://reference.wolfram.com/language/ref/Length.html
compare:
https://www.jmp.com/support/help/en/16.2/index.shtml#search/length
21 Comments
hogi
Level XIII
Visibility / Get visibility:
see also: Set Property
to set the visibility
hogi
Level XIII
close data grid and close summary panels
wrong desriptions in the scripting index (see screenshots)
(description is the same as for close side panels)
hogi
Level XIII
column<< set selected
add a link to
dt << Clear Column Selection();
hogi
Level XIII
Lineup Box:
The "example" is definitely a nice application case for lineup boxes.
But: Is N=1 really the best possible example for N Cols Lineup Box?
Does it make sense to add a second (slightly more general) example?
jthi
N Col(1) is a good example, because it will make all displays have similar width BUT there should be first example with larger N Col and this N Col(1) is more like a special case (even though it is very common and usable case).
Also noticed that we have Line Up Box in Scripting Index which uses N Col(2) and then Lineup Box which uses N Col(1).
hogi
Level XIII
hogi
Level XIII
good examples:
For some commands, there are plenty of example codes listed, all the possible options are listed as comments in the examples and there are even some explanatory comments
-> very helpful  :)
hogi
Level XIII
for normal variables, there is no difference between creating the variable or changing the value of a variable:
x=1;
for table variables, there is:
new table variable ("x",1);
and
set table variable ("x",1);
Unfortunately, in the see also, nothing is listed.
Ah, x=1 works as well :)
any difference to set table variable?
Craige_Hales
https://community.jmp.com/t5/Discussions/difference-between-set-and-new-table-variable-strange-resul...
(difference between set and new table variable - strange results in writing string?  )
describes how strings and numbers are handled by the functions and variables. It would be great if the doc(s) were updated with the info.
hogi
Level XIII
How good for Jmp that some wise guy set up the community :)
