  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Saving data tables with JSL
The current syntax for saving data tables with JSL is a bit clunky.
dt=current data table();
dt << Save(<filepath>);
This requires specifying the complete file path, which includes the JMP data table name.  To save the file with its current name it is even more clunky.
dt = current data table();
table_name=dt << get name;
dir="C:\temp\";
filepath=dir || table_name || ".jmp";
dt << save( filepath)
I would like a Save File( ) function that you can save data tables (and possibly any JMP file) with a more obvious and compact syntax.   For saving tables, it could look something like this
// save to default directory
Save File(dt);
// save to specific directory
Save File(dt, <directory path>)
//save to specific directory with data table name new name
Save File(dt, <directory path>, <new name>)
Why is this idea important?
It is for JSL coding efficiency and readability.
2 Comments
hogi
Level XIII
instead of
Save File(dt);
you can use
dt << save();
For the issue with path and filename, one could make the wish more general - way beyond "SAVE" -
... and ask for a framework to handle file pathes in JMP  like it's possible in other languages
(maybe there is an existing wish?).
Just have a look at  pathlib / Path in python. It's not rocket science - but it removes a lot of pain : )
Sarah-Sylvestre
Level V
Thank you for submitting this request!
