  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Restore data-grid behavior: Cmd-Opt-Click (or Ctrl-Alt-Click) to select intersections of rows
What inspired this wish list request? In JMP 18 and earlier, holding down Cmd+Option (Mac) or Ctrl+Alt (Windows) while clicking on a column header graph item allowed you to select the intersection of that item with the existing selection. This was an incredibly helpful shortcut when working with large tables and making precise sub-selections. In JMP 19, this functionality is gone. The modified-click now does nothing, breaking that workflow.
Example use case:  To select all 17-yo males in Big Class, I click on "M" in the row header graph, then cmd-opt-click "17" in the row header graph of the age column.  This is a quick way to isolate a subtable or group of values. Without this, there’s no simple, interactive way to get that intersection, esp. in a large dataset.
What is the improvement you would like to see? Please bring back the behavior where Cmd+Opt+Click (or Ctrl+Alt+Click on Windows) sets the selection to the intersection of the clicked header graph rows and the current row selection.  This feature enabled clean and efficient workflows when working with big data tables and visually selecting subsets of data. It doesn’t conflict with other shortcut behaviors and was intuitive once discovered.
Why is this idea important? It enables precise sub-selection in large tables using intuitive modifier keys, making complex table interactions much faster and more visual.
10 Comments
hogi
Level XIII
wow!
An "And" Filter for the Header graphs!
I always wished to have this one. Now it's gone before I can use it ...
hogi
Level XIII
nathan-clark
Level VI
@hogi All great comments / thoughts!
hogi
Level XIII
JMP Support will report this issue as a bug to JMP development group: TS-00246839.
Should be fixed in one of the next bugfixes.
This will be restored in 19.1.
BHarris
Level VII
@Sarah-Sylvestre :  Thank you!
hogi
Level XIII
Thanks a lot for bringing it back.
And CTR + Click is toggling.
BHarris
Level VII
It’s back in 19.1!
I assume this is documented somewhere, but I wasn’t able to find it, so sharing here for anyone interested.
Intersection.  In JMP 19.1, holding Cmd+Option (Mac) or Ctrl+Alt (Windows) and clicking a column header graph item returns the intersection of the current selection and the item clicked. For example, in Big Class, you can select all 14-year-old males by clicking sex = “M” and then Cmd+Option-clicking age = 14.
Union.  Holding Shift while clicking gives the union of selections. For example, to select anyone who is male or 14 years old, select sex = “M” and then Shift-click age = 14.
Inverse.  Holding Cmd (Mac) or Ctrl (Windows) while clicking selects the inverse of the clicked rows relative to the current selection. For example, if all males are selected and you want to switch the selection of 14-year-olds to be the females, Cmd-click age = 14. This deselects the 14-year-old males and selects the 14-year-old females.
Thank you, JMP devs!
BHarris
Level VII
@Sarah-Sylvestre  This can be marked as "Delivered".
Status changed to: Delivered
