  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Reopen/restore the last closed window
Too many times I have accidentally closed a window/analysis then 2 seconds later realized I wasn't quite done with it.  Yes, I could use recall to redo it quickly, but would really like to be able to press a button and restore the last thing I closed.
9 Comments
Sarah-Sylvestre
Level V
Thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
hogi
Level XIII
The enhanced Log gives you the possibility to open again any window which you closed during the current session.
jules
Community Manager
Hi @amlee2008,
I know just how frustrating that is and have done it myself a number of times! I just shared an Add-In in the File Exchange that I've been using for a while to do just what you suggested (and behind the scenes it exploits the log, just as @hogi mentioned). I hope this will help you until there is another method available.
Menu Item to Reopen Last Closed Report
julian
Sarah-Sylvestre
Level V
@amlee2008 I have a quick question about this request. Are you wanting to mainly reopen report windows or multiple window types?
amlee2008
Level II
@Sarah-Sylvestre usually report windows or graph builder
MarginalFawn906
Level I
To reopen a closed window or tab, simply press Ctrl + Shift + T (Windows) or Cmd + Shift + T (Mac). You can also right-click on the browser tab bar and select "Reopen closed tab." For more tips and tricks on managing your tabs and windows, visit SmartWindows, your go-to site for efficient window management solutions!
Sarah-Sylvestre
Level V
hogi
Level XIII
Is  "Recall Last Platform" from the View menu what you want?
