Reopen/restore the last closed window
Too many times I have accidentally closed a window/analysis then 2 seconds later realized I wasn't quite done with it.  Yes, I could use recall to redo it quickly, but would really like to be able to press a button and restore the last thing I closed.
9 Comments
Thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
The enhanced Log gives you the possibility to open again any window which you closed during the current session.
jules
Community Manager
Hi @amlee2008,
I know just how frustrating that is and have done it myself a number of times! I just shared an Add-In in the File Exchange that I've been using for a while to do just what you suggested (and behind the scenes it exploits the log, just as @hogi mentioned). I hope this will help you until there is another method available.
Menu Item to Reopen Last Closed Report
julian
@amlee2008 I have a quick question about this request. Are you wanting to mainly reopen report windows or multiple window types?
amlee2008
Level II
@Sarah-Sylvestre usually report windows or graph builder
MarginalFawn906
Level I
To reopen a closed window or tab, simply press Ctrl + Shift + T (Windows) or Cmd + Shift + T (Mac). You can also right-click on the browser tab bar and select "Reopen closed tab." For more tips and tricks on managing your tabs and windows, visit SmartWindows, your go-to site for efficient window management solutions!
hogi
Level XIII
Is  "Recall Last Platform" from the View menu what you want?
