Redo / ReLaunch Analysis with Local Preferences
Hello,
Can the Redo / ReLaunch Analysis (including the ByGroup options) be enhanced to use locally set preferences instead of the global defaults where the two differ? I've noticed that within projects, when one of these commands is invoked, it uses the global preferences even though the previous analysis had locally changed preferences.
Regards
Mehul Shroff
1 Comment
Sarah-Sylvestre
Level V
Hi @MShroff, thank you for your suggestion! We have captured your request and will take it under consideration.
